POV-Ray : Newsgroups : povray.advanced-users : What is happening? Server Time
17 Nov 2026 19:16:48 EST (-0500)
  What is happening? (Message 1 to 4 of 4)
Subject: What is happening?
Date: 18 Oct 2026 19:40:00
Message: <web.6ad557d6223b6f46f594e74ff712fc00@news.povray.org>
This code acts funky!
//scr 600*600
#version 3.8;
global_settings {assumed_gamma 1 max_trace_level 20}
#default {finish{ambient 1 diffuse 0 emission 0}}
#background{rgb 1}
#declare Size=5;
camera{orthographic
        location <0,0,-Size>
        look_at <0,0,0>
        right Size
        up Size
        //sky y
        scale <1,1,1>
sphere{-x*2,1 pigment{Red}}
sphere{0,1 pigment{Blue}}
scale the camera with <-1,1,1> and the Red sphere is where it should be
Does anyone else have this problem or is it just me?
I've got a 3Rd party build of PovRay v3.8.0 -beta.2+tgh7.msv14.win64
Download 'test.png' (2 KB)
Preview of image 'test.png'
Subject: Re: What is happening?
Date: 19 Oct 2026 03:24:36
Message: <6ad5c5b4$1@news.povray.org>
On 10/18/26 19:35, Leroy wrote:
>          right Size
>          up Size
The right and up settings are vectors so 'Size' for both is getting
promoted to <Size,Size,Size>.
My guess is that POV-Ray internally sees the identical promoted vectors
as an invalid right/up vector combination and you end up with some
parser de-mangled right/up vectors. I see no warnings that this is
happening though, for which I'll give the parser ten demerits.
I think the de-mangling of the <Size,Size,Size> vectors might also be
creating a sqrt(2) multiplier of the resulting, internal, right and up
vectors. Or maybe this multiplier comes about otherwise - I don't know.
If I'm guessing well, using:
right <Size*sqrt(2),0,0>
up    <0,Size*sqrt(2),0>
would be valid right and up vectors where the orthographic camera scale
will match what you are seeing currently for a confusing result - except
now, with the red sphere showing up on the left as you expect.
Bill P.
Date: 19 Oct 2026 11:31:59
Message: <6ad637ef$1@news.povray.org>
> would be valid right and up vectors...
Ugh, not quite correct - what I get for winging it. Those sqrt(2)
multipliers should be sqrt(3) to match your original orthographic image
scale.
Bill P.
Date: 19 Oct 2026 15:20:00
Message: <web.6ad66cbcc54173e5f594e74ff712fc00@news.povray.org>
> > up��� <0,Size*sqrt(2),0>
> scale.
> Bill P.
I knew It was a simple problem. I just couldn't see it.
right x*Size
up y*Size
This does what I wanted.
It amazing that this worked at all.
right Size
up Size
And the strange way it acted with the x values inverted but not the y or z
values(I tested them) After I posted I tried the code on POV 3.7 win and it did
the same. So POV handles this problem the same way for a long time.
Thanks for your help!
Have Fun!
