I recently worked up a bump_map{} scene for the yuqk fork documentation.
Attached is an image with positive and negative bump_size crackle
pattern in the top row. Lower left is wrinkles. Lower right leopard.
All of the pattern implementations used are somewhat different in the
yuqk fork, but I've attached a scene file which will work with v3.8 beta
2 should folks want to play (it 'probably' works back to v3.7).
Of note there is some sort of top / right bug in the way the bump_map{}
is being handled for use in the normal{} block which has existed for a
long time. In the attached 'yuqk' fork generated image the seam has been
rotated into full view. I've not attempted to debug it. There is a note
in the code about samples falling outside the mapped area needing to be
handled correctly.
The bump_size as applied to bump_map{}s is a bit funky in that for many
image types coming in with values in the 0 to 1 range, very large
bump_size multipliers are needed.
Internally there is a value/255 kind of thing going on. Guess is some
formats / options (idexed?) come in as integers where the divisions by
255 makes sense. The bump_size of +-127 equates to an effective
bump_size of +-0.5 internally where values in the 0-1 range.
Due the sampling, the normals at changes in slope direction are
sometimes noisy.
Bill P.
Download 'bump_mapstory.jpg' (151 KB)
Download 'bump_map_v38.pov.txt' (2 KB)
Preview of image 'bump_mapstory.jpg'
