POV-Ray : Newsgroups : povray.windows : how to create a random coil Server Time
30 Aug 2025 07:10:13 EDT (-0400)
  how to create a random coil (Message 1 to 10 of 16)
Subject: how to create a random coil
Date: 17 Oct 2007 20:30:01
Message: <web.4716a7eca1216bf14f7090800@news.povray.org>
Anybody knows how to draw a random coil in povray? I am very interested in
doing this but not capable of doing it. I need help. Thanks in advance.
Subject: Re: how to create a random coil
Date: 17 Oct 2007 23:06:33
Message: <4716cdb9$1@news.povray.org>
"zj905" <zj9### [at] hotmailcom> wrote in message
news:web.4716a7eca1216bf14f7090800@news.povray.org...
   Google Is Your Friend:
http://www.geocities.com/ccolefax/download/coil.txt
    (Note that the code shown there is for pov3.1 but it shouldn't be a
problem).
    Or, you could experiment with this:
 #declare Ball =
 sphere{<0,0,0>,0.15 scale <1,1,1> rotate<0,0,0> translate<0,0,0>
 texture{pigment{ color rgb<1,0.7,0>}
                finish { diffuse 0.9 phong 1}}}
union{
 #local Nr = 0;            // start
 #local N_per_Rev = 500;   // Number of Elements per revolutions
 #local N_of_Rev  = 4.25;  // Total number of revolutions
 #while (Nr< N_per_Rev*N_of_Rev)
   object{Ball translate<1,Nr*0.45/N_per_Rev,0>
               rotate<0,Nr * 360/N_per_Rev,0>}
 #local Nr = Nr + 1;    // next Nr
 #end // ---------------  end of loop
rotate<0,0,0>
translate<0,0,0>} // end of union
    ~Steve~
Date: 19 Oct 2007 17:20:01
Message: <web.47191ece144555e34849a21c0@news.povray.org>
Thanks. But it looks like a helix. How to get a "random" coil?
> problem).
>  #declare Ball =
> union{
> rotate<0,0,0>
>     ~Steve~
Date: 19 Oct 2007 18:06:56
Message: <47192a80$1@news.povray.org>
news:web.47191ece144555e34849a21c0@news.povray.org...
  Ok, sorry that didn't help. It really depends on what you mean by
'random'.
   ~Steve~
Date: 19 Oct 2007 19:05:00
Message: <web.471937b9144555e34849a21c0@news.povray.org>
I am doing some work on chemistry. The random coil looks like... It is
better to give a sample. Please see this picture:
http://www.psc.edu/science/Darden/bpti_spline_dense2.GIF. In this graph,
the white-yellow chains are random coils. How to draw that? Thanks.
> 'random'.
>    ~Steve~
Date: 19 Oct 2007 19:16:27
Message: <47193acb@news.povray.org>
I typed something up but seeing this picture makes me think it might not
be quite what you're looking for either.  (Looks like my lines are a
little too long.) I'm posting it anyway in case it might still have some
relevance:
Charles
//****   o-/--   ************************
//        o
global_settings {
   assumed_gamma 1.0
   location  <0.0, 0.5, -4.0>
   direction 1.5*z
   look_at   <0.0, 0.0,  0.0>
sky_sphere {
     gradient z
     color_map {
       [0.0 rgb <0.6,0.7,1.0>]
       [0.7 rgb <0.0,0.1,0.8>]
light_source {
   <0, 0, 0>            // light's position (translated below)
   color rgb <1, 1, 1>  // light's color
   translate <-30, 30, -30>
// ^^^^^ The above is modified from the POV-Ray for Windows insert menu
#declare Wraps = 10;
#declare BallRad = 1;
#declare Increment_Val = 0.001;
#declare Ctr = 0-Increment_Val;
#declare MyRand = seed(0);
#declare ThisRandVec = <rand(MyRand),rand(MyRand),rand(MyRand)>;
#declare MySpline =
spline{cubic_spline
   //Ctr,
vrotate(<BallRad,0,0>,<rand(MyRand),rand(MyRand),rand(MyRand)>*360),
   Ctr, vrotate(<BallRad,0,0>,ThisRandVec*360*Ctr*Wraps),
   #declare Ctr = Ctr+Increment_Val; //now 0.... could'a just written 0.
   #while(Ctr <= 1+Increment_Val)
       //Ctr, vrotate(<1,0,0>,<rand(MyRand),rand(MyRand),rand(MyRand)>*360),
   #end //end while
}//end spline
#declare SphereRad = .01;
#declare NumOfSpheres = 10000;
#declare Ctr = 0;
#declare A_Random_Coil =
union{
  #local Ctr = 0;
  #while (Ctr <= 1)
    sphere {
      MySpline(Ctr),SphereRad
      pigment { rgb <1-Ctr,Ctr,0> }
    #local Ctr = Ctr + 1/NumOfSpheres;
} //end union
#object{A_Random_Coil}
//        o
Date: 19 Oct 2007 20:35:00
Message: <web.47194d14144555e34849a21c0@news.povray.org>
Thanks. It is pretty close to what I want. Here is a beautiful image
demonstrating what I want to plot:
http://web.mit.edu/newsoffice/2003/smartsurface.html. Lots of chains were
grafted on a surface. They are rooted on the surface and grow upward
randomly. Any good suggestion?
> relevance:
> Charles
> //        o
> global_settings {
>    assumed_gamma 1.0
> camera {
>    direction 1.5*z
> sky_sphere {
>    pigment {
>      gradient z
>      color_map {
> light_source {
> #declare MySpline =
> spline{cubic_spline
>    //Ctr,
>    #end //end while
> }//end spline
> #declare Ctr = 0;
> union{
>   #local Ctr = 0;
>   #while (Ctr <= 1)
>     sphere {
>   #end
> } //end union
> //        o
Date: 19 Oct 2007 21:31:17
Message: <47195a65@news.povray.org>
Hmm, have a look at this.   I hope you don't mind rough inline-code
examples rather than a paragraph descriptions.
Charles
//        o
global_settings {
   assumed_gamma 1.0
   direction 1.5*z
sky_sphere {
     gradient z
     color_map {
light_source {
//#declare Wraps = 100;
//#declare BallRad = 1;
//#declare Increment_Val = 0.001;
//#declare Ctr = 0-Increment_Val;
//#declare MyRand = seed(0);
//#declare ThisRandVec = <rand(MyRand),rand(MyRand),rand(MyRand)>;
//#declare MySpline =
//spline{cubic_spline
//  //Ctr,
//  Ctr, vrotate(<BallRad,0,0>,ThisRandVec*360*Ctr*Wraps),
//  #declare Ctr = Ctr+Increment_Val; //now 0.... could'a just written 0.
//  #while(Ctr <= 1+Increment_Val)
//      //Ctr,
//  #end //end while
//}//end spline
//#declare SphereRad = .001;
//#declare NumOfSpheres = 100000;
//#declare Ctr = 0;
//#declare A_Random_Coil =
//union{
// #local Ctr = 0;
// #while (Ctr <= 1)
//   sphere {
//     MySpline(Ctr),SphereRad
//     pigment { rgb <1-Ctr,Ctr,0> }
//   #ifdef(LastSpot)
//        cylinder{
//          MySpline(LastSpot),MySpline(Ctr), SphereRad
//   #end //end ifdef
//   #local LastSpot = Ctr;
//   #local Ctr = Ctr + 1/NumOfSpheres;
// #end
//} //end union
//#object{A_Random_Coil}
#local TheHeight = 1;
#local Wiggliness = .2; //it's a scale factor
#local GridLength_X = 7;
#local GridLength_Z = 7;
#local GridDiv_X = 10;
#local GridDiv_Z = 10;
#local Ctr_X = 0;
#local Ctr_Z = 0;
#declare NumOfSpheres = 10;
#declare CtrS = 0;
#declare TheBigGrid =
union{
   #local Ctr_X = 0;
   #while (Ctr_X < 15)
         #local Ctr_Z = 0;
         #while (Ctr_Z < 15)
             #local MySpline =
                 spline{ cubic_spline
                         -.1,                           //pos
                         <Ctr_X*GridLength_X/GridDiv_X, //x
                         -TheHeight/10,                 //y
                         Ctr_Z*GridLength_Z/GridDiv_Z>, //z
                         0,                             //pos
                         0,                             //y
                         .5,                            //pos
                         <Ctr_X*GridLength_X/GridDiv_X  //x
                         +(rand(MyRand)-.5)*Wiggliness, //x
                         TheHeight/2,                   //y
                         Ctr_Z*GridLength_Z/GridDiv_Z   //z
                         +(rand(MyRand)-.5)*Wiggliness> //z
                         1,                             //pos
                         TheHeight,                     //y
                         1.1,                           //pos
                         TheHeight*1.1                  //y
                       }//end spline
                       union{
                       #local CtrS = 0;
                       #while (CtrS <= 1)
                         sphere {
                           MySpline(CtrS),SphereRad
                           pigment {rgb <1-CtrS,CtrS,0>}
                         #ifdef(LastSpot)
                              cylinder{
                                MySpline(LastSpot),
                                MySpline(CtrS),
                                SphereRad
                         #end //end ifdef
                         #local LastSpot = CtrS;
                         #local CtrS = CtrS + 1/NumOfSpheres;
                      } //end union
                      #undef LastSpot
                      sphere{MySpline(1),
                            SphereRad*7
                            pigment{rgb <1,1,0>}
                      } //end sphere
                 #local Ctr_Z = Ctr_Z + 1;
         #end //end #while (Ctr_Z < 15)
         #local Ctr_X = Ctr_X + 1;
   #end //end #while (Ctr_X < 15)
} //end union TheBigGrid
object{TheBigGrid
        translate <-GridLength_X/2,0,-GridLength_Z/2>
        rotate y*50
//        o
Date: 19 Oct 2007 21:51:33
Message: <47195f25@news.povray.org>
PS I'd meant to put #while (Ctr_X < GridDiv_X) instead of #while (Ctr_X
< 15).  Same for Z.
Date: 19 Oct 2007 22:45:01
Message: <web.47196b8b144555e34f7090800@news.povray.org>
You are a really expert!! Admire! Thanks.
If I have new problem, where can I find you?
> < 15).  Same for Z.
