POV-Ray : Newsgroups : povray.windows : can pov-ray be run on background automatically Server Time
17 Jun 2024 06:29:22 EDT (-0400)
  can pov-ray be run on background automatically (Message 1 to 5 of 5)
Subject: can pov-ray be run on background automatically
Date: 31 Jul 2007 01:45:01
Message: <web.46aecbd08479afb2c200930f0@news.povray.org>
Hi all,
Can pov-ray application be run on background automatically
when the rendering is started?
Because I would like to set up a task to do the job
without pop up the main gui window.
If can, how to set up the options?
Thanks in advance.
Subject: Re: can pov-ray be run on background automatically
Date: 31 Jul 2007 16:48:14
Message: <46afa00e$1@news.povray.org>
start pvengine.exe /render World.pov /exit
That should do it. Tweak to satisfaction.
     I bet exercise equipment would be a lot more
     expensive if we had evolved from starfish.
Date: 2 Sep 2007 04:25:00
Message: <web.46da72e15e1661281ddfe9a90@news.povray.org>
>    Darren New / San Diego, CA, USA (PST)
Any hints on how to disable the focus of the gui? whenever a new render is
spawn, on my SP1, I can still continue working (focus not moved) while the
render continue on it's way. But for SP2 machine, the new render gui will
grab focus (and thus hiding my current open window). And prevent me from
continuing my work.
I am running 3.7 beta 22 on 2 machine.
one is running a XP Pro SP1 in classical taskbar mode
the other is XP Pro SP2 in classical taskbar mode
both the povray settings are identical as far as I can tell
option>>single instance, toolbar
option>>render window>> hide when main is min
ini: Display=off
cmd: /exit
is this a window setting problem thingy? or could there be something I can
set?
Date: 2 Sep 2007 13:49:45
Message: <46daf7b9@news.povray.org>
> set?
Possibly. Download "Powertoys for XP" from Microsoft. Install TweakUI.
Go to General->Focus and check "Prevent applications from stealing
focus". There's undoubtably a way of doing it by prodding the registry
directly, but I'll leave it to you to google.
That *should* prevent the problem, unless POV-for-windows goes out of
its way to steal the focus or does something Microsoft didn't expect.
Which is possible.
I kind of remember being annoyed by this myself. Something in the
configuration of the splash screen steals the focus unnecessarily, I think.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 29 Sep 2007 18:26:21
Message: <46fed10d@news.povray.org>
> continuing my work.
I'm probably late answering this, but I will anyway. Try this:
start /min pvengine.exe /render World.pov /exit
