POV-Ray : Newsgroups : povray.windows : Question about Povray for windows Server Time
1 Jun 2024 20:30:57 EDT (-0400)
  Question about Povray for windows (Message 1 to 8 of 8)
Subject: Question about Povray for windows
Date: 1 Jul 2006 22:10:02
Message: <web.44a72af6650a3e33c69ac230@news.povray.org>
If you want to edit something were do you do this and how? I have read all
of the documentation with povray but I still don't get it. Is it in the
command line or one of the editors????? I feel really silly not getting
this.
Subject: Re: Question about Povray for windows
Date: 2 Jul 2006 03:47:17
Message: <44a77a05$1@news.povray.org>
> this.
   I think you are giving too little information in order to give you
a good answer.
   What is it that you are seeing when you start povray? What have you
tried? Explain step by step both of these questions.
Date: 2 Jul 2006 10:15:00
Message: <web.44a7d4aa218e5a3b3c69ac230@news.povray.org>
> > this.
> a good answer.
OKay, I've created a scene and didn't like the way the lighting turned out
and I
want to change the settings and positions.
In povray for windows whould I edit the light in "Edit last scene file"? Or
would these changes need to be made using the "command line options" in the
POvray for windows render settings?
Thank you
Date: 2 Jul 2006 13:08:56
Message: <44a7fda8$1@news.povray.org>
I don't understand what you want to edit in command line.
How did you create the scene ? With POVRAY or another software ?
news:web.44a7d4aa218e5a3b3c69ac230@news.povray.org...
all
the
getting
> > > this.
> > a good answer.
> and I
Or
the
> Thank you
Date: 2 Jul 2006 14:22:02
Message: <44a80eca$1@news.povray.org>
   With what?
Date: 2 Jul 2006 16:52:20
Message: <44a83204@news.povray.org>
> and I
   I think you could if you wanted to, (not sure, not ever having used it),
but most would just open their *.pov file which would open the onboard
editor. You would change your lighting (or anything else) parameters within
that editor. As soon as you open a *.pov file, that IS your editor. :o)
Or
> the
     No, command line options are really for 'refining' your scene. For
instance, if you leave the line blank and pick a resolution of [800 x 600,
No AA] for your scene, and THEN put '+A0.0' (without the quotes), in the
command line, this will reduce a lot of the jagged (pixelated) edges in that
scene. Try it on your present scene, you will then see the difference.
(There are even finer inputs for this, see your PoV docs for 'aa' or
'antialiasing').
    ~Steve~
> Thank you
Date: 2 Jul 2006 17:05:50
Message: <44a8352e$1@news.povray.org>
Just had a thought; Under 'Options' and then 'Other settings', you have
checked 'Use Editor'?
    ~Steve~
Date: 3 Jul 2006 18:04:45
Message: <44a9947d$1@news.povray.org>
> this.
When you launch POV-Ray, you ARE in the editor. Here, you can edit your scene all you
want. If the
light is not to your liking, change it's definition: light_source{Location Position
[options]}
The command line, the box beside the resolution list, let you enter some rendering
options. This can
be dimentions, AA options, quality level,...
Fundamentalism #3: Shit must be born again.
