POV-Ray : Newsgroups : povray.windows : pov editor highlight/rightclick suggestion Server Time
2 Mar 2026 23:06:51 EST (-0500)
  pov editor highlight/rightclick suggestion (Message 1 to 5 of 5)
Subject: pov editor highlight/rightclick suggestion
Date: 15 Sep 2002 09:48:55
Message: <Xns928A63DAAF374POVMIKA@204.213.191.226>
Me again!
The right-click options in the povray for windows editor has options for
indenting undenting etc... what about an option for
commenting/uncommenting code.
Hmmm...
Food for thought.
(I splurt these out as they come along)
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Subject: Re: pov editor highlight/rightclick suggestion
Date: 15 Sep 2002 10:14:59
Message: <a459ou437q5nnljg1t9uh8tbn263d2sk5a@4ax.com>
On 15 Sep 2002 09:48:55 -0400, Marc Champagne <nos### [at] pleasecom>
I've also given this idea some thought and decided not to bother the
Team with it. Why? Because it's just too much work for what it does.
Basically, you can comment a block of code in several ways, and what
happens if there are already comments inside (even worse, you comment
a closing comment)?
The current alt-drag CodeMax functionality pretty much makes the idea
obsolete anyway. Go to the beginning of a road, hold Alt and drag
vertically through the lines you want to comment. Do not select a
block, just drag vertically. The cursor is now, say, 20 lines high -
just tap '/' twice and you have your block commented. Uncommenting is
the same, only this time drag to block-select the // section.
Hope it works for you - it works like a charm for me.
Peter Popov ICQ : 15002700
Date: 15 Sep 2002 11:16:46
Message: <Xns928A72BF92314POVMIKA@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in
news:a459ou437q5nnljg1t9uh8tbn263d2sk5a@4ax.com:
> obsolete anyway
  Section 1.5.1.
    Column Selection and Manipulation.
      Columns of text can be selected with the mouse and then
      manipulated. Empty columns (columns with a width of zero
      characters) can be selected, causing subsequent typing and
      deletion to occur over multiple lines at the same time.
  Section 1.6.4
      Alt + Left Button down, hold and drag -- Select columns of text
I find the manual very hard to ingest at times, unless I once again
failed to locate the proper section...
Thanks for the tip, it works very well!
Montreal, CANADA
Date: 15 Sep 2002 16:37:33
Message: <anr9ouco1789pmkovln4t1061i3e4pal57@4ax.com>
On 15 Sep 2002 11:16:46 -0400, Marc Champagne <nos### [at] pleasecom>
well, it *is* actually a tip - or it was, I think - one of those that
show at startup the first time you start the program. I am one of
those people who read all tips at the beginning, usually to check
whether the last one is like "Oh, so you've actually read all tips? I
thought it was only me." :)
Date: 17 Sep 2002 08:13:20
Message: <Xns928C53A937486POVMIKA@204.213.191.226>
news:anr9ouco1789pmkovln4t1061i3e4pal57@4ax.com:
You deserve a bigger chunk of cake for that!
Montreal, CANADA
