POV-Ray : Newsgroups : povray.windows : Problem with animations Server Time
12 Jun 2026 00:35:08 EDT (-0400)
  Problem with animations (Message 1 to 6 of 6)
Subject: Problem with animations
Date: 3 May 2006 20:22:45
Message: <44594955$1@news.povray.org>
Whenever I try to start any animation, POV-Ray freeze.
Both using command-line (+kffxxx) or using an *.ini file.
Does anybody have a similar problem? Did you resolved it? How?
Does anybody have any hint about what setting or file can cause that?
Running on Windows 2000 sp4.
CPU: AMD thunderbird 1400 MHz
RAM: 512 Mb
Note: I can run animation if I use beta 3.7.xx but I can't do animation using file I/O
to pass
information from one frame to the next.
A clear conscience is usually the sign of a bad memory.
Subject: Do you want me to test your scene?
Date: 7 May 2006 13:58:32
Message: <445e3548@news.povray.org>
Greetings, Alain.
I used the beta version 12a for an animation, and my scene file worked -
Povy created - one after the other - around 200 pictures.
Hmm.. Maybe it depends on the resolution, or on the scene? I wiuld be
willing to test your scene file, if you want.
My system is Windows XP, Dual Intel Pentium 4 @ 3.06 GH, 1.25 GB RAM.
If you want me to test your scene, publish it here or sedn it to me, Alain.
Please send me also the settings as an INI file.
Greetings,
Sven
"Alain" <ele### [at] netscapenet> schrieb im Newsbeitrag
news:44594955$1@news.povray.org...
> RAM: 512 Mb
> using file I/O to pass information from one frame to the next.
> Alain
Subject: Re: Do you want me to test your scene?
Date: 7 May 2006 17:38:39
Message: <445e68df$1@news.povray.org>
Sven Littkowski nous apporta ses lumieres en ce 07/05/2006 13:58:
> Greetings, Alain.
> Greetings,
> Sven
>>RAM: 512 Mb
>>Alain
My tests where with some sample scenes that comes with the installer.
I tried with different resolutions.
Every scenes from the \animations\ folder cause my POV-Ray 3.6.1a to freeze BEFORE the
parsing even
starts. It freezes during the preleminary display of the scene options. (it must be
something funky
with my system)
With 3.7 beta 12a, when I try to run bounce.pov or bounce.ini, frame 1 and 2 are
rendered normaly,
then it exits on parceing frame 3 with a message telling me that it can't find the
file
"bounce.txt". this file hold the previous coordinates. Instead of writing the file
normaly, it write
a file pvxx.tmp to the tmp path. (xx is some arbitrary, sequential hex value)
Dogs crawl under gates, software crawls under Windows.
Date: 17 May 2006 12:10:31
Message: <446b4af7$1@news.povray.org>
normaly, it write
There is an issue with file output. It will be fixed in a future beta.
-- Chris
Subject: Re: Problem with animations
Date: 27 Jul 2008 15:50:01
Message: <web.488cd06cf8ac8cc0d053c6640@news.povray.org>
> RAM: 512 Mb
I/O to pass
> Alain
I have this problem also with 3.6.1c on a Dell C2D notebook running Vista. It
seems to be a problem at the message window. If I clear the message window and
turn off console messages with -GA I can get through a dozen or so frames
before the msg window fills up with 'rendering frame n of m' and the sequence
freezes. I haven't tried to solve it any further yet. No problem when I do
multiple files without animation (i.e. manually) that overfill the msg window.
Date: 29 Jul 2008 16:53:13
Message: <488f8339$1@news.povray.org>
tticknor nous illumina en ce 2008-07-27 15:47 -->
>> RAM: 512 Mb
I/O to pass
>> Alain
That post is about 2 years old! For me, the problem cleared itself away.
At the time, my problem was totaly different than your's: I got the freezes
immediately whenever I started any animation, before the parsing even started.
The xx in beta 3.7.xx was around 07 to 12 at the time.
A typican scenario was, at the time:
Launch POV-Ray.
Load the scene file.
Start the animation. Instant FREEZE!
In your case, try reinstalling POV-Ray into a custom folder instead of somewhere
inside program files. Vista don't let a programm alter it's own ini files.
You know you've been raytracing too long when your source files are starting to
get bigger than the image files.
     -- Matt
