POV-Ray : Newsgroups : povray.windows : Multi-user compatibility Server Time
21 Jul 2026 05:31:44 EDT (-0400)
  Multi-user compatibility (Message 1 to 7 of 7)
Subject: Multi-user compatibility
Date: 18 Jun 2004 14:31:41
Message: <40d3350d$1@news.povray.org>
Hello,
I installed POV-Ray 3.6.0 on Windows XP, and I have the impression that
it doesn't follow the basic guidelines for multi-user compatibility in
WinXP, since it keeps trying to write to its installation directory. The
resulting problems are obvious: users are forced to share their
settings, and non-Administrators cannot even save them!
Is there a way to correct this that I have overlooked? If not, what is
the proper way to report it to the POV-Ray developers? (The fix is
pretty obvious: move the config files to their proper location, inside
the user profile directory).
Thanks in advance!
   Lionel Fourquaux
Subject: Re: Multi-user compatibility
Date: 18 Jun 2004 14:43:24
Message: <5kd6d05edqt3ac5kht15dhqd9r8ho0dva1@4ax.com>
On Fri, 18 Jun 2004 20:31:40 +0200, Lionel Fourquaux
No, users are not forced. See details at,
http://www.povray.org/documentation/view/3.6.0/136/
ABX
Date: 18 Jun 2004 15:11:33
Message: <40d33e65$1@news.povray.org>
Thanks. It's a partial solution, however, since the settings cannot be
changed from the GUI. Moreover, I've been unable to make it work using
an INI file in POV-Ray's current directory: according to Filemon, it
doesn't even try to open it.
Date: 18 Jun 2004 15:19:57
Message: <2pf6d0hfus7utmic6c2mmguhv799i2fhlb@4ax.com>
On Fri, 18 Jun 2004 21:11:32 +0200, Lionel Fourquaux
There is input for typing options below menu.
http://www.povray.org/documentation/view/3.6.0/141/
Do you know how to set current directory for exacutables? It's in properities.
Also you can type pvengine.exe from commandline.
ABX
Date: 18 Jun 2004 15:45:02
Message: <40d3463e$1@news.povray.org>
Thanks again, but still, it's not very handy.
Precisely in the shortcut properties.  :)
That's what I tried. Either I made a mistake somewhere (the current
directory, at least, is ok), or it doesn't work.
I tried that, too. I can see _a lot_ of accesses
(open/lock/read/unlock/close) to INI files in the installation
directory, and none in the current directory.
Date: 18 Jun 2004 15:55:13
Message: <l0i6d0d2rj2e8k8uc4pq8vn4rhlvfk235p@4ax.com>
On Fri, 18 Jun 2004 21:45:02 +0200, Lionel Fourquaux
I missed something. IIRC, the current directory, is that where active scene
file of active ini file is located.
ABX
Date: 18 Jun 2004 16:26:37
Message: <40d34ffd@news.povray.org>
Now, it's my turn to say I don't understand what you mean... For me, the
"current directory" is a parameter passed when a program is started,
until the program changes it. E.g. if I type
cd Z:\Foo
pvengine
then the current directory should be Z:\Foo , and it looks like
pvengine.exe doesn't try to open anything in Z:\Foo , while part 3.3.1
of the documentation (which you pointed out) seems to say otherwise.
