POV-Ray : Newsgroups : povray.windows : Announce: MegaPOV v0.7 Ready for download (win,mac,dos) Server Time
14 Jul 2025 03:44:36 EDT (-0400)
  Announce: MegaPOV v0.7 Ready for download (win,mac,dos) (Message 1 to 1 of 1)
Subject: Announce: MegaPOV v0.7 Ready for download (win,mac,dos)
Date: 6 Feb 2001 01:28:50
Message: <1enyalk.d4sf1618pbty8N%smellenbergh@skynet.be>
MegaPOV version 0.7 can be downloaded at:
Windows:
http://nathan.kopp.com/patched.htm
Macintosh (also look in povray.macintosh for more info):
http://users.skynet.be/smellenbergh
DOS (if not already, real soon!):
http://www.stuartgibson.com/
The archive with the demo scenes has not changed. We will make a few
demo scenes available at:
http://users.skynet.be/smellenbergh (click on the "Demos" link in the
navigation bar on the left)
Go grabb it! :-)
The MegaPOV-Team.
Bug fixes in this version:
* Fixed precision bug in scallop_wave and sine_wave;
* Fixed bug in media method 3 (by J. Berger);
* Fixed bug in noise that appeared when using huge translations (by J.
  Berger);
* Fixed bug in isosurface causing a crash when parsing exp without
  braces;
* Fixed bug in isosurface intersections. Spherical containers were not
  translated correctly;
* Fixed bug in isosurface difference, where the differencing object
  enclosed the original completely: it left a ghost  shadow;
* Input files for idat_3D can be in all library paths. Previously they
  had to be located in the same folder as the scene file. All paths are
  searched now just like it is done for any include file;
* Added missing code for the isosurface object. Interacts with 'open';
* Fixed the stars post_process filter; it now adds to the background
  instead of replacing it (12.16);
* Fixed bug that caused a crash when PostProcess was running out of
  memory: error given now;
* Fixed bug with ellipsoid, removed artifacts that appeared in some
  cases (by J. Grimbert);
* Fixed a bug, reported by Nicolas Calimet, in the TransformPatch (line
  1081 in Parse_Object_Mods());
* Fixed bug with uv_mapping when uv_vectors were not specified;
* Fixed memory problems when using functions in animations: They are now
  destroyed after every frame;
* Fixed some bugs in spline and copy_splines;
* Fixed some glow bugs("size" should work properly now);
* In the MegaPov manual, the chapters (5.2.11) , (5.2.12) , (5.2.14) and
  (8.3.5) are corrected / rewritten.
MacMegaPov only:
* A bug preventing to run on some machines with a 601 PPC is fixed.
* Input for idat_3D binary is fixed. The original 3DHEAD demo from
  Suzuki now renders.
New in this version:
* Added the sample_spacing patch in media (by J. Berger) (4.2);
* Added a new type of emitting media to be used on clear backgrounds (by
  J. Berger) (4.3);
* Added new post_process filters: "curves" (12.4), "limit_brightness"
  (12.9) and "raw_color" (12.14);
* Added a new directive #set to change variables (by C. Huff) (9.22);
* Added SPLINE_IDENT(T, TYPE) syntax (by C. Huff) (5.9.3);
* Added ability to apply transforms to warps (by C. Huff) (8.12);
* Added "spline_wave" waveform for patterns (by C. Huff) (8.11.2).
MacMegaPov only:
* There is a MacMegaPov v.0.7 carbonised version working on MacOS X and
  8.1 or later. Older versions of the OS still supported!
e-mail:sme### [at] skynetbe
Subject: Re: Announce: MegaPOV v0.7 Ready for download (win,mac,dos)
Date: 6 Feb 2001 02:51:11
Message: <3A7FACF0.84AF06B@gmx.de>
That's nice,
when can we expect 0.7a?  ;-)
BTW, in the windows HLP version of the docu the links in the main index do
not work (they also appear blue instead of green here)
Date: 6 Feb 2001 05:12:06
Message: <3a7fcdf6@news.povray.org>
smellenbergh wrote in message <1enyalk.d4sf1618pbty8N%smellenbergh@skynet.be>...
great, thanks
but ... have you considered my posts ?
3a598ad0@news.povray.org - possibility of max_intersection bug p.prog
3a59dcd9$1@news.povray.org - code duplication in objects.c in p.un.patch
wait... I just downloaded sources and see second done but without note in
history.html
ABX
Date: 6 Feb 2001 06:24:37
Message: <3A7FEEF4.DEF18DB0@hlavacek-partner.cz>
Linux version will be no longer supported? I can post linux executable
on my site.
Disnel
Date: 6 Feb 2001 13:30:26
Message: <3A8042C2.61941381@ucdavis.edu>
i thought there wasn't going to be another megapov until pov3.5 came
out.  i could've sworn nathan said so anyway.
> Windows:
> Go grabb it! :-)
> The MegaPOV-Team.
>   Berger);
>   braces;
> MacMegaPov only:
>   Suzuki now renders.
>   J. Berger) (4.3);
> MacMegaPov only:
Date: 6 Feb 2001 16:03:55
Message: <chrishuff-08D5F7.16045506022001@news.povray.org>
In article <3A8042C2.61941381@ucdavis.edu>, Ryan Constantine
It wasn't planned, but I think MegaPOV 0.5 was also supposed to be the
last MegaPOV until POV 3.5. It just has some bug fixes and a few new
features, it could have been called MegaPOV 0.6b.
Christopher James Huff
Date: 6 Feb 2001 17:31:25
Message: <3A807B3D.A9D8C14B@ucdavis.edu>
has there been any consideration of including the additions made by
povman?  i actually haven't had time to use it, but at school, i've had
a ton of time to read about the renderman shading language and it seems
to be a worth while addition to the already great povray.  keep up the
> Windows:
> Go grabb it! :-)
> The MegaPOV-Team.
>   Berger);
>   braces;
> MacMegaPov only:
>   Suzuki now renders.
>   J. Berger) (4.3);
> MacMegaPov only:
Date: 6 Feb 2001 17:31:56
Message: <3A807B48.B22C1DE7@club-internet.fr>
> Windows:
> Go grabb it! :-)
> The MegaPOV-Team.
Thanks a lot to all of you for the good work!
In return, as usual, the pvm distributed version is ready:
http://www.wozzeck.net/images/pmp/
Hmmm... the version number seems a bit ahead of time, I guess ;-)
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Date: 6 Feb 2001 19:00:49
Message: <1eofdm1.1vbxjisobfnjgN%smellenbergh@skynet.be>
Not this one :-(
We try to keep track of all bugs reported bud somehow we missed this
one.
> history.html
There are more little fixes/changes that we do not mention. If we list
all changes, the list would be too long.
Smellenbergh
Date: 6 Feb 2001 22:50:07
Message: <3a80c5ef@news.povray.org>
"Francois Dispot" <woz### [at] club-internetfr> wrote...
I updated my webpage to include a link to your site.
-Nathan
