POV-Ray : Newsgroups : povray.unofficial.patches : Megapov 1.2 - mechsim - How can I remove a mass Server Time
13 Jan 2026 11:57:55 EST (-0500)
  Megapov 1.2 - mechsim - How can I remove a mass (Message 1 to 5 of 5)
Subject: Megapov 1.2 - mechsim - How can I remove a mass
Date: 12 Aug 2005 10:30:01
Message: <web.42fcb156b3e0fe5273647170@news.povray.org>
Unless I've missed something in the docs , I cannot find a way to remove
mechsim objects from a scene short of hacking on the MSIM file itself.
I'm trying to expire a mass after it reaches a certain distance , does
anyone have any pointers?
Subject: Re: Megapov 1.2 - mechsim - How can I remove a mass
Date: 12 Aug 2005 12:25:01
Message: <ddiiap$8bn$1@chho.imagico.de>
That is correct - there isn't currently any way to do this except
modifying the data file.  To be more precise: access to simulation data
from the scene file is completely read-only.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 14 Aug 2005 08:20:01
Message: <web.42ff363ba3e0ebc673647170@news.povray.org>
So something like this might be called right after load_file , expires some
mass objects . It would require either careful use of concat() and str() or
a shell-out to something that can read a file listing the mass indexes to
expire. ??
#macro ExpireMass_Distance( Point, Distance )
#if (mechsim:mass_count)
 #while (Cnt<mechsim:mass_count)
  #local Mass_Pos = mechsim:mass(Cnt):position
  #if (vlength( Mass_Pos - Point ) < Distance )
    //Do nothing mass in still in range
  #else
    //Mass is out of range and should be removed
    //Write sim data to a temporary file?
    // Or write Cnt to a temporary file and shell-out to script to remove
from MSIM
 #local Cnt=Cnt+1;
Is that by design or simply that it's not a often requested feature?
Date: 14 Aug 2005 09:20:02
Message: <ddng62$67o$1@chho.imagico.de>
> expire. ??
The mechsim data file format can't be read using the SDL file reading
features so you would need an external tool for this.
By design to some extent.  It would not really be difficult to add this
from side of the mechsim patch but the POV-Ray scene description
language currently does not offer any comparable feature so it would
change the nature of the language to have such a function.
For example offering something like
mechsim:mass(Cnt):remove()
would be possible but it would be a function which returns nothing -
something that currently does not exit in POV-Ray.
Another possibility would be to have the topology{} block and topology
elements be declarable:
#declare Obj = topology { load_file "test.dat" }
and allow access to its elements via
Obj:mass(i)
this way you would have completely free control over the simulation data
from the scene file.  But this would also be something completely new in
terms of language design.
Date: 23 Aug 2005 06:05:01
Message: <web.430af447a3e0ebc673647170@news.povray.org>
Rather convoluted but successful , Find below - a macro that identifies
masses that are greater than 'Distance' from 'Position'. Expired mass
indicies are written to 'ExpireFile' seperated by newlines , with the first
line containing the name of 'LoadFile' from which these masses were chosen.
Also find perl code that when called will load the file named as it's first
argument (the expiry file) , then parse the named msim datafile , remove
the masses at indicies listed and out (hopefully) correct msim data to
STDOUT.
BUGS: mechsim_expire.pl is completly ignorant of the connections of masses
to other mechsim objects , hence connections would snap to different
apparent masses . It is by no means complete , but does all I need it to
right now.
// "mechsim_expire.inc"
#version unofficial MegaPov 1.2;
#macro ExpireMasses(LoadFile,ExpireFile,Position,Distance)
 #local Cnt = 0;
 #fopen Expiry ExpireFile write
 #write ( Expiry , LoadFile, "n" )
  #local Mass_Pos = mechsim:mass(Cnt):position;
  #local Length = vlength( Mass_Pos - Position );
  //#debug concat( str(Cnt,0,0) , " has vlength from origin of " ,
str(Length,3,3) , "n")
  #if ( Length  < Distance )
  #else
 //#debug concat ( "Mass" , str(Cnt,0,0) , "is out of range!n")
 #write ( Expiry , Cnt , "n" )
    // Cnt to a temporary file and shell-out to script to remove
 //from MSIM
 #local Cnt=Cnt+1;
// mechsim_expire.pl
#!/usr/bin/perl -w
use strict;
my $expiry = shift @ARGV;
die "mechsim_expire.pl <filename>
Will read a target file and list of indices from <filename> , remove the
listed mass(es) and write MSIM data to STDOUTn";
die "$expiry does not exist " unless -f $expiry;
open ( my $exp , $expiry ) or die $! ;
my $target = <$exp>;
my $destination = <$exp>;
chomp($target,$destination);
open ( my $fh , $target ) or die "Cannot open target MSIM file $!";
my @expired = <$exp>;
chomp (@expired);
my $MSIM = ParseMSIM($fh);
RemoveExpired( @expired , $MSIM );
Output($MSIM);
sub Output {
 my $data = shift;
 print $data->{version};
 print $data->{info};
 print $data->{timing};
 print @{$data->{mass}} if @{$data->{mass}};
 print @{$data->{face}} if @{$data->{face}};
 print @{$data->{connection}} if @{$data->{connection}};
 print @{$data->{viscoelastic}} if @{$data->{viscoelastic}};
sub RemoveExpired {
 my $expired = shift;
 my $data = shift;
 ## remove mass elements
 foreach my $dead ( @$expired  ){
 $data->{mass}->[$dead] = undef;
 my @remain = grep { defined } @{$data->{mass}};
 $data->{mass} = @remain;
 warn scalar @remain , " masses remainingn";
 my @info = split ' ' , $data->{info};
 $info[1] -= scalar(@$expired);
 $data->{info} = join (" " , @info) . $/;
sub ParseMSIM {
 my $msim = shift;
 my $version = <$msim>;
 my $info = <$msim>;
 my $timing = <$msim>;
 my @mass;
 my @connection;
 my @viscoelastic;
 my @face;
 while (my $line = <$msim>) {
 my $type = substr($line,0,1);
 push @mass , $line if ('M' eq $type);
 push @connection , $line if ('C' eq $type);
 push @viscoelastic , $line if ('V' eq $type );
 push @face , $line if ('F' eq $type);
 my %data;
 @data{qw/version info timing/} = ($version , $info , $timing);
 @data{qw/mass connection viscoelastic face/} = (@mass , @connection,
@viscoelastic, @face);
 return %data;
