POV-Ray : Newsgroups : povray.unofficial.patches : How to postprocess instead of re-render in MegaPOV Server Time
2 Jun 2024 12:24:45 EDT (-0400)
  How to postprocess instead of re-render in MegaPOV (Message 1 to 5 of 5)
Subject: How to postprocess instead of re-render in MegaPOV
Date: 29 Jul 2005 06:35:01
Message: <web.42ea050141587f4c8fd3abd0@news.povray.org>
Hi!
Just switched from PovRay to MegaPOV to create a depth map using the
PP_Init_Depth_Output() / PP_Depth(min,max) postprocessing feature.
Unfortunately the postprocessing is currently a re-rendering, getting image
+ depth map takes twice as long as getting only the image (also in the +D0
graphical output I see the depthmap being rendered line by line on top of
the image).
So I figured that the internal storage of the depth information does not
work during the main render pass (even though I used PP_Init_Depth_Output),
and MegaPOV has to render a second time.
I looked for additional options to activate an internal buffer and saw that
old PovRays supported 'Buffer_Output' and 'Buffer_Size'. Or what else do I
need to activate?
Many thanks for your help and the great work on MegaPOV,
Elmar
Subject: Re: How to postprocess instead of re-render in MegaPOV
Date: 29 Jul 2005 06:50:02
Message: <dcd1d5$5r2$1@chho.imagico.de>
Elmar Krieger wrote:
> Hi!
That's not correct.
> getting image
> the image).
That is quite possible.
No, the current post processing is simply not very efficient (it is
designed to be very flexible but this limits performance quite
significantly).  What you think is a second render is simply gathering
the depth information from the data stored during the main render.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 29 Jul 2005 09:15:00
Message: <web.42ea2b8a8cf789648fd3abd0@news.povray.org>
Thanks for your quick reply Christoph.
Is there maybe a trick to bypass the macro bottleneck and quickly dump the
collected depth + normal information into a binary file which I can then
analyze myself? (especially the edge detection is a factor 100 slower than
the actual rendering).
Greetings,
Elmar
Date: 29 Jul 2005 09:30:02
Message: <dcdanf$7tf$1@chho.imagico.de>
What macro bottleneck?
> analyze myself?
The data is written to a temporary file.  The format of this is
currently not documented though.
Date: 29 Jul 2005 09:31:30
Message: <qcbke1l3nvq9novb26suq8gqeltbkpjs6c@4ax.com>
On Fri, 29 Jul 2005 09:13:46 EDT, "Elmar Krieger" <elm### [at] cmbirunl> wrote:
If you only need depth and normal, I do not understand why you need MegaPOV.
trace() functions does it in POV-Ray. But indeed it can be simpler sampling
over camera_view during parsing and skip rendering part. Would that be
sufficient temporary solution?
ABX
