POV-Ray : Newsgroups : povray.unofficial.patches : Retaining persistent variables in MegaPov 1.0 Server Time
5 Apr 2026 17:32:19 EDT (-0400)
  Retaining persistent variables in MegaPov 1.0 (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Retaining persistent variables in MegaPov 1.0
Date: 8 Oct 2003 13:45:36
Message: <4si8ovsu7bgdaato8e14rf9lf3bonc7rf0@4ax.com>
On Wed,  8 Oct 2003 13:27:52 EDT, "sups" <sbh### [at] lycoscom> wrote:
> I have tried the file I/O feature. Due to the very
> large size of the file (476 Kb), reading seems extremely slow, almost same
> time as generating the data. e.g.
What method do you use to perform writing/reading ?
Do you use #write #read ? Perhaps reading through #include would be faster ?
Perhaps writing it into array would offer later fastest #include? Perhaps
other trick could be possible as well - for example you could write data into
ascii image and then read it through evaluation of colors on pigment. I
suggest to seeking for workarounds temporary as long as persistent variables
are not available.
ABX
Date: 8 Oct 2003 14:02:02
Message: <jtvd51-41u.ln1@triton.schunter.etc.tu-bs.de>
sups wrote:
> Hi ABX!
> Thank you for both your replies. From your previous reply it was clear that
> persistent variables may not have made it to MP1.0. But in the manuals of
> MP1.0, nowhere it has been explicitly mentioned. Therefore I had the
> slightest hope that this feature may be accesible in some other way. It
> would be really nice to get this feature back since my code is not
> compatible with MP0.7.
It is not very likely that this will happen any time soon.  The
persistence of variables patch was somewhat ugly and Nathan was probably
the only one who really understood it.
I would also prefer a different syntax for such a patch.  Like for
example a new #persistent directive which works like #declare and #local
but stores the data differently so it is not cleared after each frame.
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 8 Oct 2003 14:10:01
Message: <web.3f8452f2b6855006d467bfc30@news.povray.org>
Right now, I have used the #read and it seems too slow. I will try #include
and let you know what happens. I also agree with Chris on the syntax of
persistent variables.
thank you
Sup
>are not available.
>ABX
Date: 8 Oct 2003 14:19:21
Message: <Xns940ECEBB9AD8Bseed7@netplex.aussie.org>
in news:jtv### [at] tritonschunteretctu-bsde Christoph Hormann
Just an idea, how about something inspired by Pythons pickle and shelve:
http://www.python.org/doc/current/lib/module-pickle.html
http://www.python.org/doc/current/lib/module-shelve.html
You could make not just variables persistent but whole objects or scene
sections.
Ingo
Date: 9 Oct 2003 08:39:32
Message: <3f855704$1@news.povray.org>
#declare_persistant = XXXX;
This seems like the best way. This would work for objects as well I would
assume. Just my thoughts.
news:jtv### [at] tritonschunteretctu-bsde...
> sups wrote:
> > Hi ABX!
that
of
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 9 Oct 2003 13:09:31
Message: <cjameshuff-C6E436.13070809102003@netplex.aussie.org>
In article <3f855704$1@news.povray.org>,
Simply #persistant should be enough, and consistent with the existing
#declare, #local keywords. And it should be possible without too much
work for anything that can be declared...but I haven't really looked at
the changes that would need to be made.
http://tag.povray.org/
Date: 9 Oct 2003 13:36:32
Message: <rk6bov0qt73b9hmm5af9oj8tgibihbemgb@4ax.com>
On Thu, 09 Oct 2003 13:07:08 -0400, Christopher James Huff
I suppose it will be more difficult at least because of functions existence.
#declare C=function{pigment{object{sphere{0,1}rgb 0 rgb 1}}}
#persistent D=function{C(x,y,z)+1}
BTW I would prefer #persist more than #persistent
ABX
Date: 9 Oct 2003 22:09:05
Message: <3F861502.C70467C8@pacbell.net>
I would agree with that.
Ken Tyler
Date: 9 Oct 2003 23:08:23
Message: <cjameshuff-88ED7F.23055809102003@netplex.aussie.org>
In article <rk6bov0qt73b9hmm5af9oj8tgibihbemgb@4ax.com>,
Well, it doesn't fit in with either of the the other commands. #declare
is an action, you declare a variable. #local is a descriptive word like
#persistent. You can't persist a variable...it is the variable that
persists. But you can declare a persistant variable. The word "persist"
just doesn't seem to fit into the language.
Date: 10 Oct 2003 03:49:41
Message: <7l3i51-8u1.ln1@triton.schunter.etc.tu-bs.de>
I agree.  You can also say #local implies a 'declare' -> 'to declare sth
local(ly)'.  #persistant would be logical in the same way.
