POV-Ray : Newsgroups : povray.unofficial.patches : problem with MegaPOV MechSim_Show_Patch(). Server Time
24 Dec 2025 20:39:03 EST (-0500)
  problem with MegaPOV MechSim_Show_Patch(). (Message 1 to 4 of 4)
Subject: problem with MegaPOV MechSim_Show_Patch().
Date: 29 Jan 2003 21:25:03
Message: <web.3e388c0bc659ba77adf806de0@news.povray.org>
I tryed to add seperate MechSim_Show_Patch() for each pice of cloth in
tshirt.pov (included in MegaPOV 1.0), instead of the show_all().
-there are some visable errors:
  -a line appears on 2 of the 6 cloth pices
   (i use the color=stress option)
  -there is a strange edge on 3 of the 6 cloth pices
-the last pice only works if i make it one row smaller
  -i suspect some problem in counting/using the face_index, but i have not
   been able to find errors in my povray code.
i have put together a small HTML page with some pictures at:
http://www.geocities.com/jwstolk/tshirt_jws_problem.htm
is this a known problem ? or dit i make a mistake somewhere ?
thanks, Jaap. jws### [at] yahoocom
Subject: Re: problem with MegaPOV MechSim_Show_Patch().
Date: 30 Jan 2003 09:03:34
Message: <3E3930B6.75569F31@gmx.de>
Jaap wrote:
> Hi,
This is a known problem of the MechSim_Show_Patch() macro - i already
posted a workaround somewhere IIRC.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 30 Jan 2003 14:05:07
Message: <web.3e3976d068f71ba1adf806de0@news.povray.org>
thanks, i can stop looking for what i dit wrong now...
i looked around a bit, but can findo no mention of this problem,
(and no work around either.)
can you give a small hint in this ?
 - i tryed using slightly different patch_index numbers (+/- 1 etc.)
   is this the way to go?
 - fixing the src code (is it realy a bug, or more like a limitation ?)
 - don't use MechSim_Show_Patch(), but something else. (what?)
what i would like to do is simple patern and image mapping. i don't realy
need the "show stress" texture.
i also would like to try if it is possible to generate the pices of
cloth in a differnt way:
 -manualy connecting mass/patch pices together
 -generate a half-round version of the flat pice of cloth
 -"cutting" a pice of cloth using boolean operations (or somthing like that)
 -use a mesh-generating algo to fill anny shape with triangles of reasonably
  simmilar size.
 -etc. (i think that enof for this weekend..)
a related Q:
 -how fast/eff is pov-ray SIM ? would it be more sensible to use/write a
  seperate program to do simulation, and let is produce pov-files ?
jaap.
Date: 1 Feb 2003 09:47:39
Message: <3e3bde0b$1@news.povray.org>
"Jaap" <jws### [at] yahoocom> wrote in message
news:web.3e3976d068f71ba1adf806de0@news.povray.org...
Hi Jaap,
Christoph posted the fix in a reply to one of my posts.. just search for my name and
you
should find it, it's fairly recent (I set my posts to expire so I can't tell you which
one
exactly)
All the best,
Andy Cocker
