POV-Ray : Newsgroups : povray.unofficial.patches : relativity Server Time
18 Mar 2026 21:54:12 EDT (-0400)
  relativity (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: relativity
Date: 2 Dec 2002 03:16:25
Message: <3DEB1661.AEA494BD@nospam_zip.to>
> You are probably thinking of -
> http://www.anu.edu.au/physics/Searle/Obsolete/Raytracer.html
Nah - it was definately a POV patch
I found it thanks to google -
http://www.cs.mu.oz.au/~andrbh/raytrace/raytrace.html
Now why didn't I do that before?
Bye,
Pabs
Date: 2 Dec 2002 03:29:18
Message: <3DEB1967.CDCB5250@nospam_zip.to>
Theres a couple of cool mpg demos at http://www.cs.mu.oz.au/~amb/rrt/
Date: 2 Dec 2002 05:39:08
Message: <3DEB389B.8ECFC618@pacbell.net>
I stand corrected. First time I have heard of that patch. So much for knowing
"everything".
Ken Tyler
Date: 2 Dec 2002 15:36:38
Message: <3debc456@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:3de7034b@news.povray.org...
> "Rohan Bernett" <rox### [at] yahoocom> wrote in message
> news:web.3de6ef98c20e2bf3c571aa6c0@news.povray.org...
> > Would it be possible to create a patch for Povray that would allow it to
> > turn it into a relativistic raytracer?
> Practically impossible. You would be much better off writing a
relativistic
> raytracer from scratch. POV is big and complex, you would have to change
> pretty much everything, and not everything it does would even make sense
in
> a relativistic raytracer. It isn't something you could just patch into
POV.
> It would be much more productive to work on Backlight instead: it already
> does the basics.
Perhaps it's not possible for the reasons you state, but it seems to me that
those effects could be approximated by camera manipulations and a little
post-processing.  Of course, that assumes a static scene where only the
camera is moving relative to the scene.  Obviously, if multiple objects are
moving with different velocity vectors that wouldn't work.
It depends on whether you are trying to approximate relativistic effects or
actually model them.
Subject: :)
Date: 2 Dec 2002 22:00:50
Message: <3DEC1DCC.B350EE83@nospam_zip.to>
> I stand corrected... So much for knowing "everything".
> Ken Tyler
: ) I think that must be the quote of the month if not year.
JJ
Bye,
Pabs
Date: 3 Dec 2002 20:29:00
Message: <chrishuff-D904E1.20255803122002@netplex.aussie.org>
In article <3DEB1661.AEA494BD@nospam_zip.to>,
Huh...it modifies POV-Ray 2.2, quite a bit easier to do than a more
recent version. I wonder if it does anything more than just changing the
camera ray directions, or if he had to disable any features...it looks
like it just adds one camera parameter.
http://tag.povray.org/
Date: 4 Dec 2002 03:30:06
Message: <web.3dedbae45d040d8dc571aa6c0@news.povray.org>
Assuming we want to be able to model the actual effects, would it be
possible to do it by modifying the POV source code?
Rohan _e_ii
Date: 4 Dec 2002 14:09:30
Message: <chrishuff-9BC854.14063004122002@netplex.aussie.org>
In article <web.3dedbae45d040d8dc571aa6c0@news.povray.org>,
I don't think you can write something that simulates *all* the effects,
it is probably completely impractical to do. The answer depends on how
much you want to simulate in POV, but doing anything of any complexity
would take a huge amount of work. Also, POV is not a simulation program,
it's a renderer. Many things are "faked" for speed.
It would be possible, but impractical. More work than starting from
scratch, and wouldn't have any real advantages.
Date: 19 Jan 2003 23:25:02
Message: <web.3e2b79695d040d8dcaa7dedc0@news.povray.org>
>Rohan _e_ii
Rohan -
Are you still interested in adapting POVRay to Relativistic Ray Tracing?
I have an interest in such a project, if POVRay proves to be sufficiently
adaptable to allow it.
I have been comparing the Backlight solution to the POVRay solution.
I have compiled and tested both.  The POVRay 2.2 adaptation appears
to be one dimensional, since it will only render properly with the
velocity component along the Z axis (into or outof the screen).
Backlight works fine and is not limited to a Z velocity. But there is
the animation issue, as you said.
I need to modify the source code for a few added features for my
research. No decision as to which package to modify.  POVRay is a
candidate, as is Backlight, and a number of other similar pacakges.
You can find more information on my progress here:
http://www.HyperVisualization.com
I am interested in hearing about what you have learned, so far.
- Digital Don
  dbl### [at] dcgFXcom
  1-949-548-1969
Date: 28 Sep 2004 05:20:00
Message: <web.41592c505d040d8d5dc6697f0@news.povray.org>
This discussion may well be dead, but if anybody is listening,
you'll find a modified version of Povray 3.5 at
http://www.maths.monash.edu.au/~leo/relativity/sr-photography/
You'll find sample images, animations and source files.
This version produces relativisticly correct images when the camera moves
relative  to the other objects in an other wise non-relativistic scene
(i.e. relativistic effects are only accounted for between the camera and
objects). This version also ignores any colour or intensity shifts that
arise from the relativistic motions.
Leo
