POV-Ray : Newsgroups : povray.unofficial.patches : PoPOV - second build Server Time
18 Apr 2026 23:50:38 EDT (-0400)
  PoPOV - second build (Message 15 to 24 of 24)
Subject: Re: PoPOV - second build
Date: 22 Oct 2002 12:48:12
Message: <3DB5814C.84DD1F62@gmx.de>
ABX wrote:
> Two solutions. First, I can remove my modifications and turn off warnings -
> but then incorporating new patches can have some warnings I could not catch.
> Second, I can remove old behaviours and stay with new syntax when it not
> changes features. Personally I prefer second solution but temporary I stayed
> with #ifdefs to highlight all places modified by me.
The description of your second solution seems confusing to me.  You mean
you change the code but don't mark it with ifdef's? That would be a bad
idea for a general patch collection. As several people pointed out the
basis should always be the current official version.
IMO it would be good if every patch had a clear description of it's
purpose and a list of modified places in the source in addition to the
user documentation.  Something like:
F_TRIANGLE_PATCH
introduces a new internal function 'f_triangle'.
Modified source files:
- 'fnintern.cpp'
    * several helper macros at the beginning of the file
    * f_triangle() function declaration and implementation
    * added entry to 'POVFPU_TrapTable'
    * changed 'POVFPU_TrapTableSize'
I think this is something easy to write for the author of the patch and it
would help maintaining patch collections.
Date: 22 Oct 2002 13:14:48
Message: <3DB58788.79D0B800@gmx.de>
ABX wrote:
> > You should really release
> > the source code,
> surprise at www.abx.art.pl/pov/popov :-)
Another thing about the source: Your unofficial version handling is
somewhat different from what i know from MLPov and Ryoichi Suzuki's df3
patch.  I think there should be a 'opts.Unofficial_Version' with a
seperate unofficial version number.  Your method of adding it to the main
version will at least lead to problems if there is official POV-Ray
3.51/3.6/...
Date: 23 Oct 2002 01:46:16
Message: <hfdcrug9q0sh0k6mtcmio2ce0ldl81epcc@4ax.com>
On Tue, 22 Oct 2002 19:14:48 +0200, Christoph Hormann <chr### [at] gmxde>
> 3.51/3.6/...
I think you missed flag UnofficialVersion.
I did not compared any other unofficial pack about handling it yet becouse
could not find any suggested way of making it. I have checked MegaPOV for it
but that implementation seemed overcomplicated for me.
ABX
Date: 23 Oct 2002 01:50:29
Message: <1tdcru0v4rk2jiuk6kbljsd1elg2ttrttp@4ax.com>
On Mon, 21 Oct 2002 21:30:14 +0200, Christoph Hormann <chr### [at] gmxde>
wrote:
> i somehow find it a bad habit
> to offer binaries a lot earlier than the source.
Now I have comparison. Binaries are downloaded twice more than sources.
ABX
Date: 23 Oct 2002 01:53:44
Message: <m1ecrukksd6ubqna4d9bnikmajhppqkgg4@4ax.com>
On Tue, 22 Oct 2002 18:48:12 +0200, Christoph Hormann <chr### [at] gmxde>
If there could be general agreement and knowledge what is changed then I don't
think so.
Then I prefer it as is.
> - 'fnintern.cpp'
Seems logical.
ABX
Date: 23 Oct 2002 03:57:55
Message: <3DB65684.97C7ECC1@gmx.de>
A search for 'UnofficialVersion' in your source code did not find
anything.
Here is the relevant part from MLPov:
      /*ML: version_patch*/
     #ifdef MLUNOFFICIAL
     /* parse unofficial version */
     Get_Token();
     if (pov_stricmp(Token.Token_String,"mlpov") != 0)
       Error("This version only recognizes #version unofficial mlpov\n");
     opts.Unofficial_Version = (int)(Parse_Float() * 100 + 0.5);;
     Parse_Semi_Colon(false);
     if (opts.Unofficial_Version > UNOFFICIAL_VERSION_NUMBER)
        Error("Your scene file requires MLPOV version %g or later!\n",
(DBL)(opts.Unofficial_Version / 100.0));
I think this is fairly simple (compared to megapov) and you can also quite
easily add support for multiple unofficial version strings (in case
several patches are merged and old scene files should render without
changes).
The 'Unofficial_Version_Blocking()' function seems a good idea though.
Date: 23 Oct 2002 04:07:20
Message: <3jlcruoenn8fu3k3pippr7to68a52unfr9@4ax.com>
On Wed, 23 Oct 2002 09:57:56 +0200, Christoph Hormann <chr### [at] gmxde>
> anything.
Sorry, I have wronly reported from my broken memory.
It is 'int Unofficial;' in povray.h.
I was not concerned on MLPOV becouse Mael refused :-( to participate patches
repository earlier. Perhaps he changed his opinion after current shape of
repository and PoPOV.
> changes).
I will check and reconsider it.
Thanks.
ABX
Date: 23 Oct 2002 04:47:32
Message: <3DB66224.32EF690C@gmx.de>
Well, that's just a boolean value right now.
As discussed in the 'United POV-Ray'-thread there is probably still some
way to go until there is a user friendly and well working patch
collection.  And Mael often stated his patches are strongly WIP.
Date: 23 Oct 2002 05:47:51
Message: <skocrusdc4djphqnj8ctnsdsf7r184v5b4@4ax.com>
On Wed, 23 Oct 2002 10:47:32 +0200, Christoph Hormann <chr### [at] gmxde>
Patching seems to be always WIP :-)
ABX
Date: 2 Dec 2002 10:40:06
Message: <web.3deb7ebfbb3f2c95863e7dd0@news.povray.org>
I was wandering through your website and found out that
http://abx.art.pl/pov/ contains an error: it links to
http://abx.art.pl/pov/bonus\pack.php instead of
http://abx.art.pl/pov/bonus/pack.php (the last slash is wrong)
regards,
apache
ABX wrote:
>Hi!
>New version of PoPOV is available at http://abx.art.pl/pov/popov/
>This release contains next set of patches I gathered in repository at
>http://abx.art.pl/pov/patches/ and introduce windows port. Sorry for lack of
>sources and documentation. I have to make some work on them. I hope it can be
>already usefull for community.
>Thanks to all contributors (they are listed in banners).
>Request:
>please, help me create better examples for features, in particular for normals
>in smooth heighfield. Thanks.
>ABX
