POV-Ray : Newsgroups : povray.unofficial.patches : Compiling UberPOV on Linux Server Time
25 May 2026 01:09:03 EDT (-0400)
  Compiling UberPOV on Linux (Message 1 to 6 of 6)
Subject: Compiling UberPOV on Linux
Date: 29 May 2019 18:45:01
Message: <web.5cef0ae8a9953c5e1b6c6b3a0@news.povray.org>
Hi all
Been tinkering with UberPOV on Mac for a while (thanks Yvo!) and I find myself
wanting to also use it on a recent install of Linux Mint. So I cloned it from
github and followed the unix build instructions, only to find that
boost/tr1/memory.hpp cannot be found. Some closer investigation reveals that my
version of boost is 1.65.1, but the TR1 stuff was removed in 1.65.0.
Has anyone else encountered this? Is there an easier way to solve this than
rolling back my boost version?
Bill
Subject: Re: Compiling UberPOV on Linux
Date: 30 May 2019 04:22:50
Message: <5cef92da$1@news.povray.org>
On 5/29/19 6:42 PM, Bill Pragnell wrote:
> Hi all
> Bill
My recollection is that something promised with respect to how headers
would be changed when the boost feature moved into C++ didn't happen as
expected.
There was discussion of the issue at:
https://github.com/POV-Ray/povray/pull/42
and
http://news.povray.org/povray.general/thread/%3C5a233b19%241%40news.povray.org%3E/
Christoph fixed the issue while looking at:
https://github.com/POV-Ray/povray/issues/317
and it looks like the fix took two commits:
https://github.com/POV-Ray/povray/commit/1dbca0bad858f5605cc8e3a2629eb0e0dbfbb052
and
https://github.com/POV-Ray/povray/commit/a847cb72563f9d9d072ff2f9ef5300b91c8b5839
Perhaps you can steal from some of that work. I'm not aware of anything
'easy,' so to speak, with respect to a fix.
Bill P. (The other...)
Date: 30 May 2019 05:00:00
Message: <web.5cef9b2f1d641fe3474d4c950@news.povray.org>
Aha, thanks for that. Those changes are not extensive, I'll just duplicate the
fix in my local repo. Probably 'easier' than mucking about with boost, from
where I'm sitting :)
What's the best way to get those changes into UberPOV permanently? Is it
possible to do some git magic to cherry pick those commits, or could I just
apply the fix on an UberPOV branch and push it myself?
Bill
(maybe I should start signing off as Bill P just to confuse everyone :D)
Date: 30 May 2019 05:51:41
Message: <5cefa7ad@news.povray.org>
> Bill
Christoph is the only one who can update UberPOV and he's not worked
there in a long time.
There is a git cherry picking technique. I used exactly once years ago -
meaning I don't remember how to do it! Search for 'git cherry pick'.
The complication in grabbing things out of the main POV-Ray master
branch and moving it to UberPOV is the code is in some places
significantly different. I think this a reason why UberPOV didn't take
hold as a general test bed for things. I moved one branch to UberPOV
(never merged) and it collided with UberPOV changes. It meant a lot of
work which I only ever really made sure compiled - I didn't test the
features again as part of UberPOV. Also found myself with two branches
of the same feature. One off POV-Ray master and another off UberPOV. Too
much work.
If you want to run UberPOV specifically I'd recommend creating a branch
and just letting it sit there. If it's your only UberPOV branch, compile
and run that branch. If you end up with >1 let the branches, pull each
all into an 'UberBillP' branch off the UberPOV master branch and compile.
The last is what I've been doing. Several times a year I build a version
with the features I want off the current POV-Ray master. Down side is
it's getting to be a lot of branches to rebase/merge when the master
branch changes. I'm not a git expert. Perhaps there are better ways.
Bill P.
Date: 1 Jun 2019 17:15:00
Message: <web.5cf2e99f1d641fe31b6c6b3a0@news.povray.org>
Yes, once I sat down to it, it was evident that the code in those commits you
linked to mostly isn't in UberPOV. The changes required were much the same
though, plus a missing iostream equality operator. I fixed it in my local copy,
and I guess I'll just hang on to that for the time being.
Thanks for the help!
Bill P not P
Date: 2 Jun 2019 05:40:56
Message: <5cf399a8$1@news.povray.org>
> Bill P not P
:-) Pleased to hear you worked it out.
Bill P.
