POV-Ray : Newsgroups : povray.unofficial.patches : Possible bug in Radiance HDR output code Server Time
16 May 2026 20:40:58 EDT (-0400)
  Possible bug in Radiance HDR output code (Message 1 to 8 of 8)
Subject: Possible bug in Radiance HDR output code
Date: 3 Feb 2006 18:10:41
Message: <43e3e2f1$1@news.povray.org>
Line 393 of module hdr.cpp rev 1.16, MegaPOV 1.2,
function void HDR_Image::Write_Line(COLOUR *line_data):
    if (width < MINELEN | width > MAXELEN)
The '|' symbol might need to be '||'.
Ray Gardener
Daylon Graphics Ltd.
Subject: Re: Possible bug in Radiance HDR output code
Date: 3 Feb 2006 18:58:56
Message: <43e3ee40$1@news.povray.org>
Oh, ditto for line 717, same file, function
void Read_HDR_Image(IMAGE *Image, char *filename)
     if ((width < MINELEN) | (width > MAXELEN))
Ray
Date: 4 Feb 2006 04:40:03
Message: <ds1sp6$jhp$1@chho.imagico.de>
This making what difference for both arguments 0 or 1?
Note BTW that the original Radiance code does exactly the same.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 4 Feb 2006 04:55:22
Message: <43e47a0a@news.povray.org>
  That doesn't mean it's correct or good coding. ;)
Date: 4 Feb 2006 17:33:21
Message: <43e52bb1$1@news.povray.org>
It's actually a good example of code that might work most or all of the
time, but it reduces readability because it's not a standard way to code
a logical OR expression. The second version has parantheses around the
inequality tests, so I suspect the original author ran into trouble and
'fixed' that line by forcing the operator precedence, but '||' would
have been the better choice.
Ray
Date: 4 Feb 2006 18:36:15
Message: <43e53a6e@news.povray.org>
Ray Gardener <ray### [at] daylongraphicscom> wrote:
> but '||' would have been the better choice.
  Or, since we are using C++, just 'or'.
  (Stroustrup himself doesn't seem to consider 'or' (and the other
similar keywords) to be a more recommendable way of doing a comparison
for some reason. He mentions in his book that these keywords were
added "only" for those who can't write '|' in their system... go figure.
  However, personally I think 'or' is in every way much better than the
more cryptic '||'.)
Date: 4 Feb 2006 19:45:09
Message: <ds3hko$c75$1@chho.imagico.de>
Well - all i wanted to say is that there isn't any urgency in making
such a change since it does not in any way affect program operation.
Date: 4 Feb 2006 20:49:21
Message: <43e559a1$1@news.povray.org>
Oh, certainly. I'm just reporting things as long as I'm spotting
something out of the ordinary anyway.
Oh, it's on line 506 too. Just to be safe I did a testapp and yes,
there's no danger with the original code; it's only a readability issue.
To some extent open source projects have a higher emphasis on
readability, since they're intended for public consumption, but of
course it's the maintainer's call as to how to follow up.
MSVC issues this, interestingly enough:
warning C4554: '|' : check operator precedence for possible error; use
parentheses to clarify precedence
So if someone had a treat-warnings-as-errors compiler setting, the build
would fail, but that's not the same as a runtime issue for sure. And I
imagine those doing a build would probably know enough coding or their
compiler settings to resolve the issue locally. It depends on what build
experience a provider is aiming for; totally turnkey or
some-assembly-required. I imagine given MegaPOV's nature of
experimentation it's more the latter; official POV-Ray might lean to the
the former.
Ray
