POV-Ray : Newsgroups : povray.unofficial.patches : (simple?) Isosurface patch request Server Time
1 Apr 2026 12:07:15 EDT (-0400)
  (simple?) Isosurface patch request (Message 1 to 10 of 26)
Subject: (simple?) Isosurface patch request
Date: 13 Aug 2004 16:25:11
Message: <411D2304.50603@hotmail.com>
Hello, all who frequent this group, and greetings to Wolfgang Weiser.
I'm sorry if this request has been made by someone else; I made a real
effort to avoid asking an already-answered question. It doesn't appear
this is available for Windows.
My request is simple. It involves having somebody compile the POV-Ray
3.6 for Windows executable, and for a certain piece of the code to be
altered.
The patchwork is already done. On his webpage,
http://www.cip.physik.uni-muenchen.de/~wwieser/render/povray/patches/isoacc-patch/
Wolfgang describes what seems to be a perfect fix for a common problem
with rendered isosurfaces: black spots and 'chopped up' surfaces. He
shows which piece of POV source must be altered to allow "linear
interpolation after the final bisection step." The results are astounding.
Normally, we are forced to lower the accuracy to make such artifacts
disappear. This leads to longer render times and sharper edges.
Sometimes we don't want sharp edges at all. This new patch presents us
with a two-in-one improvement for isosurface rendering. I believe his
code will allow us to turn an ordinary isosurface cube into a bevelled
isosurface cube.... simply by raising the accuracy. A bevelled cube
which renders (theoretically) faster than a sharp-edged cube!
Now, if somebody were to compile this patch, I have a kind of
compensation planned. I will test techniques (using the patch) and
create an HTML documenting my efforts. It will be conclusive no matter
what: either we have another technique for bevelling iso objects, or it
didn't work, because artifacts still appear. I doubt the artifacts will
be too noticable, though. The page will be published either by me, or
somebody with a more stable webspace.
I don't want to tear anybody away from 'POVComp time', but if the
isosurface improvement is as good as I think it is, it will make POV
look a LOT better when all the entries come streaming in. Faster
isosurfaces :)
-Sam
Subject: Re: (simple?) Isosurface patch request
Date: 13 Aug 2004 17:45:01
Message: <cfjcgg$vkg$1@chho.imagico.de>
That is not true.  Black spots on isosurfaces can have multiple reasons,
the most common being an insufficient max_gradient.  The idea of using
interpolation for the final root position is good but it is not a
panacea for all kind of isosurface problems.  In other words it will
only improve the results if the isosurface root finder has already
successfully found the root.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 13 Aug 2004 18:53:44
Message: <411D45D6.5050706@hotmail.com>
> Christoph
I understand this, but did you look at the comparison images?
Interpolation after the last step 'glues' the isosurface together, so it
doesn't have holes that really shouldn't be there in the first place.
The isosurface renders up to (and more than) two_times_faster. His patch
sure seems like a bug fix to me.
Max_gradient issues are, IMO, easy to fix. You raise the max_gradient.
Done. No amount of that, however, can fix problems not related to
insufficient max_gradient values....
-Sam
Date: 14 Aug 2004 02:55:02
Message: <cfkcpl$2oc$1@chho.imagico.de>
>> reasons, the most common being an insufficient max_gradient.  The idea
>> of using interpolation for the final root position is good but it is
>> not a panacea for all kind of isosurface problems.  In other words it
>> will only improve the results if the isosurface root finder has
>> already successfully found the root.
No, the examples Wolfgang shows on his page show the patch improving the
results in cases of self shadowing and intersecting surfaces.  None of
the samples shows a case where the root is not found reliably (no holes
in any of the images).
There is no speedup either but a slight slowdown in fact, the faster
results are due to the use of a higher accuracy value which will work
well in cases like these where the accuracy is much smaller than the
features of the isosurface function anyway but this can't be
generalized.  A two times speedup in all isosurface renders because of
this change is illusory.
Date: 14 Aug 2004 08:53:12
Message: <411e0b37@news.povray.org>
What Christoph said here and in the previous posting is certainly correct.
Once a isosurface root is found, the linear interpolation step gives us
a better guess of the true postion of the root (expect one or two orders
of magnitude for well-behaved functions).
This means:
(1) It is not meant as a way to generate bevel edges.
(2) It cannot make black regions disappear which occur because of
   not found roots (such as missed roots due to incorrect max_gradient).
(3) It does greatly improve the actual surface accuracy. While the current
   code will have the real root depth within the specified accuracy, the
   patched code will have it within 1/10 to 1/100 (typ.) of the accuracy.
   This in turn means, that one can render equally-well images with smaller
   accuracy and hece faster. See below, too.
(4) The black dots on my images are IMO due to the shadow rays (i.e. the
   ones from the light source to the object) come _really_ flat above
   the surface. I did no detailed investigation on why exactly the black dots
   disappear with my patch. However, a linear interpolation after a bisection
   algorithm is the most common way to go numerically and there is no reason
   why we should not do that here.
Well, the overhead can really be neglected.
> the faster results are due to the use of a higher accuracy value
("higher value" = "less accuracy", i.e. 1e-3 instead of 1e-5)
> which will work
This is correct. If you really want the _isosurface_ of a function to get
plottet in a numerically usable way, you need to have
"accuracy" < "characteristic surface feature grain size".
It seems that you are/were using hyper fine structure in some landscape/...
renderings with structure size about as large as accuracy (?).
But from the numerical point of view, this does not make much sense.
It's more like "art produced by numerical errors from the solver" in case
it is visible at all.
> but this can't be
Not for "all" but for "a lot of real-life relevant" isosurfaces.
And after all, I cannot see major disadvantages from using it.
BTW, talking about isosurface speed, I very much like the idea of your
patch presented here:
http://www-public.tu-bs.de:8080/~y0013390/fast_iso/patch.html
Will this patch be made available sometimes somewhere (such as in
the next megapov version)?
Wolfgang
Date: 14 Aug 2004 09:40:02
Message: <cfl4h7$mjb$1@chho.imagico.de>
Wolfgang Wieser wrote:
>>which will work
Your numbers what factor you can reduce the accuracy settings are quite
wild guesses.  It depends on how well the linear interpolation
approximates the real change of the function in the final interval.  If
it does this badly you won't have such a gain (factor 10 would already
be extremely good).  Also note the normal vector calculation uses the
accuracy value as well so by increasing the accuracy setting you also
influence the calculation of the normal vector.
Sure, some time.
> (such as in
No.
Date: 14 Aug 2004 09:58:52
Message: <411e1a9b@news.povray.org>
>>>which will work
This is certainly correct. That's why I put the "well-behaved" in there :)
It turns out that the "wild guesses" are fulfilled quite good for smooth
if one is rendering the Mars topography since the function in question
is a linearly interpolated image map itself.
> If
> be extremely good).
Yes. But OTOH it is _very_ unlikely to get below factor 2.
(And actually no reason not to use it.)
Yes, I saw that because my initial guess for the reson of the black dots
was problems in the numerical differentiaion. And actually, numerical
diff is one of the most critical things. There simply isn't a perfect
solution for the problem -- especially no cheap one.
> Sure, some time.
Well... "some time"...
Do you mean I need to code it myself if I want functionality like that
this year?
Wolfgang
Date: 14 Aug 2004 11:20:01
Message: <cfla9q$sc6$1@chho.imagico.de>
>>Sure, some time.
> this year?
I don't know but don't conclude from the fact that the technique can be
explained in a few paragraphs that it is simply to implement.
Date: 14 Aug 2004 13:11:09
Message: <411E25C9.4050703@hotmail.com>
<snip>
> This means:
I understand this. But if we *can* get bevelled edges using higher
accuracy values, why not let people use it that way? My preliminary
tests (without the patch) indicate that a simple min(..) of two
functions can be bevelled, saving lots of csg-coding time. Incidentally,
it would render faster, too, because of the high accuracy values.
I don't have this problem. Some people might, but I seem to always be
able to find the right max_gradient early on.
This is what's really frustrating me.... I know the patch is better when
it comes to accuracy. With the 'official' isosurface, we have to use
accuracy values which are MUCH SMALLER than the needed 'grain size', or
resolution of the isosurface to rid ourselves of the black dots.
Can I give you an example isosurface statement, to test my theory on
this? I've seen the problems; I believe your patch fixes them. If we
break even on render time, so be it. A fix is a fix.
>>but this can't be
I can only see advantages.
> Wolfgang
*Sigh* I wish I knew how to compile POV's source code... :c/
-Sam
Date: 14 Aug 2004 13:25:05
Message: <cflht3$u8$1@chho.imagico.de>
You should really better show an example.  Black dots are nearly always
an indication of unsuccessful root finding and then this patch would not
help as explained.
