POV-Ray : Newsgroups : povray.unofficial.patches : radiosity samples: 255x255x255 probably isn't enough Server Time
14 Mar 2026 22:35:59 EDT (-0400)
  radiosity samples: 255x255x255 probably isn't enough (Message 13 to 22 of 32)
Subject: Re: radiosity samples: 255x255x255 probably isn't enough
Date: 7 Jan 2003 20:06:46
Message: <3e1b79a6$1@news.povray.org>
"Apache" <apa### [at] yahoocom> wrote in message
news:3e1b6a20@news.povray.org...
> I use this function in radiosit.cpp:
>   dest_vec[Z] = sqrt(1. - pow(src_vec->x, 2.)-pow(src_vec->x, 2.));
I'm assuming that you meant: dest_vec[Z] = sqrt(1. - pow(src_vec->x,
2.)-pow(src_vec->y, 2.));
If you just cut and pasted this code then you may want to re-run your tests,
because this would make a huge difference.
And I would at least expand pow function to square a value into a single
multiplication for efficiency.
--- Troy S. Ristow
Date: 8 Jan 2003 01:49:46
Message: <3e1bca0a$1@news.povray.org>
Thanks! Stupid typos ....  :-)  Haven't run the code yet, because I'm
waiting for a set of 12000 samples to finish.
Date: 8 Jan 2003 02:00:19
Message: <3e1bcc83@news.povray.org>
news:3e1bca0a$1@news.povray.org...
Keep in mind that the reason (in my belief) that the sample set is difficult
to create, is because it must not only be valid for 12000 samples, but also
the first 9000 of that set and the first 6000 and... etc.  (sorry for the
run-on.)
I have worked with creating dither patterns that are built up in this way.
When I get some time I will try to articulate the algorithms I used about 8
years ago to generate a cascading set of blue noise at various intensity
levels.  In the mean time, carry on with the tests, I have a few (always
have something) running in the background.
--- Troy
Date: 8 Jan 2003 09:03:13
Message: <3e1c2fa1$1@news.povray.org>
I have come up with a new algorithm that creates exactly the same set with
extremely high speed. First have to implement it. but probably I can get it
to create a set of 65535 samples in an acceptible time :-)
Date: 8 Jan 2003 10:04:18
Message: <3e1c3df2@news.povray.org>
That's exactly what I've kept in my mind all the time :-) I think "my" set
is pretty good at it.
Date: 8 Jan 2003 10:09:07
Message: <3e1c3f13$1@news.povray.org>
3e1c2fa1$1@news.povray.org...
it
Just a general comment about this "search for more radiosity" samples, which
I sincerely hope will be fruitful and lead to better, faster radiosity.
In my experience, "more samples" doesn't mean "better radiosity". In fact,
this is true between, say, 0 and 500, but after that, having more samples
just doesn't address the artefact issues : radiosity-created splotches just
tend to get smoother and more organised (with some luck, they may look like
natural dirt...) but they're still there and I'm not sure that raising the
count will make them disappear, i.e. more samples will lead asymptotically
to "nice", regular artefacts instead of messy ones. There are even some
cases where having less samples results in locally better results, something
puzzling enough to suggest that some sort of adaptive sampling could be used
(I'm clueless about the whole thing, don't ask for details!).
Anyone has investigated this problem or will raising the count to 65000
actually solve it ?
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Subject: pow()??? (Re: radiosity samples: 255x255x255 probably isn't enough)
Date: 8 Jan 2003 11:58:44
Message: <3e1c58c4@news.povray.org>
Why on Earth are you using such an expensive thing as pow() here? It is slow
as hell compared to simple multiplication. What's the catch? Am I missing
something?
Subject: Re: pow()??? (Re: radiosity samples: 255x255x255 probably isn't enough)
Date: 8 Jan 2003 12:08:02
Message: <3e1c5af2@news.povray.org>
Maybe you're right. I don't know. But I know that x*x is faster than
src_vec->x*src_vec->x. Haven't thought about it really. I have this blurry
and faint feeling that the power function is incorporated in most cpus. If
not, please tell me.
Date: 8 Jan 2003 12:09:28
Message: <3e1c5b48@news.povray.org>
I haven't investigated it. If 65000 samples doesn't help, we can always try
to go to 2^32 samples  :-)
Date: 8 Jan 2003 12:14:30
Message: <3e1c5c76$1@news.povray.org>
A reasonably smart compiler will optimize "src_vec->x * src_vec->x" to "x =
src_vec->x; x * x", but I doubt it would change "pow(x, 2)" to "x * x".
Even if pow is included on the CPU, multiplication is much faster (AFAIK).
Anders
#macro E(D)(#if(D<2)D#else#declare I=I+1;mod(pow(.5mod(I 6))*asc(substr(
"X0(1X([\\&Q@TV'YDGU`3F(-V[6Y4aL4XFUTD#N#F8\\A+F1BFO4`#bJN61EM8PFSbFA?C"
I/6 1))2)<1#end)#end#macro R(D,I,T,X,Y)#if(E(D))R(D-1I,T,Y/2X)R(D-1I,T+Y
/2Y/2X)#else box{T T+X+Y pigment{rgb E(2)*9}}#end#end R(10,5z*3-1v*2u*2)
