POV-Ray : Newsgroups : povray.unofficial.patches : Tessellation Server Time
27 Jul 2026 02:29:29 EDT (-0400)
  Tessellation (Message 11 to 16 of 16)
Subject: Re: Tessellation
Date: 11 Oct 2001 11:37:08
Message: <slrn9sbf55.cj4.ron.parker@fwi.com>
On Thu, 11 Oct 2001 16:40:24 +0200, Nicolas Calimet wrote:
>> I think you're thinking of something besides Delaunay triangulation.  That's
>> a purely 2d technique and has nothing to do with meshes.
>	Mhhh, guess you're wrong, sorry.
>	Delaunay triangulation is commonly used in 3D (and maybe more dim.)
>to create meshes from different kind of data, e.g. a cloud of points. I had
>got a lot of internet references when looking at a related problem (mesh
>simplification) but unfortunately lost all while moving. Probably worth to
>search again since there might have new stuffs appearing  :o)
But it's not triangulation in that case; it's a more generalized sort of
related thing involving solids.  The whole idea of triangulation doesn't
make sense unless all of the points are in a plane, because the notion of
"none of the other points fall in the circumscribed circle" doesn't make
sense.  You can construct a Voronoi diagram of sorts in 3-space and then
take something that resembles a dual of that, but it wouldn't be quite the
same sort of dual (because it swaps volumes with vertices and faces with
edges, rather than the 2d version that swaps faces with vertices and has a
1:1 correspondence between the two sets of edges) and it shouldn't be
called a Delaunay triangulation (if for no other reason than that the
mathematically interesting part of the result isn't the triangles, but the
solids that they bound.)
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 11 Oct 2001 11:40:42
Message: <slrn9sbfbs.cj4.ron.parker@fwi.com>
Here's a good place to start (and they call the 3d process tetrahedralization,
which is a better word.)
http://www.ics.uci.edu/~eppstein/pubs/geom-tri.html
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 11 Oct 2001 14:43:04
Message: <3BC5E837.961D789F@free.fr>
	Okay, I won't discuss about terminologies since my skills in maths
are fairly limited, not yours  ;o)  I was just recalling about those possi-
bilities of constructing meshes in a similar way the Delaunay triangulation
works (and yes I remember about the relation with Voronoi diagrams)
> [from your second answer]
	Fine for me. Now I feel a bit more mathematician  :o)
	Wow, I forgot that D. Eppstein works on so many things... I actually
did some recent (and current) work using graph theory and did not remind that
he was also publishing on this mesh problems. I'm sure this link it basically
the first one I found at that time... Thanks for pointing it out again !
	- NC
Date: 11 Oct 2001 15:02:41
Message: <slrn9sbr6j.cn1.ron.parker@fwi.com>
I have to confess that I'm an afficionado of his Geometry Junkyard; I'm
always scrounging around there looking for stuff I can turn into cool
textures or primitives or whatever.  Lately I've been slumming in the
"tilings" section, trying to get up the nerve to write a penrose pattern.
(For those playing along at home, the Geometry Junkyard is at
http://www.ics.uci.edu/%7Eeppstein/junkyard/topic.html )
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 11 Oct 2001 18:00:06
Message: <Xns913847D18Cseed7@povray.org>
> pattern.
Pure penrose or this n-dimensinal quasicrystal thing?
http://www.math.ubc.ca/~robles/tiling/quasitiler.html
http://www.math.ubc.ca/~robles/tiling/quasiinfo.html
Ingo
Date: 12 Oct 2001 09:04:58
Message: <slrn9sdqjr.fkv.ron.parker@fwi.com>
>> pattern.
Penrose tiles are a subset of the quasicrystals, so I'd obviously go with
the more general case.  But of course I won't have time to even think about
that until after 3.5.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
