POV-Ray : Newsgroups : povray.unofficial.patches : contained_by qiery Server Time
27 Jul 2026 04:00:27 EDT (-0400)
  contained_by qiery (Message 11 to 15 of 15)
Subject: Re: contained_by qiery
Date: 22 Jul 2001 14:51:02
Message: <chrishuff-4A1D91.13494422072001@netplex.aussie.org>
In article <3b5ae34d@news.povray.org>,
 "Thorsten Froehlich" <tho### [at] trfde> wrote:
> It used to work this way in MegaPOV, didn't it?  I remember there was some
> problem with containers...
As I recall, the problem was the other way around: the containers were
not transformed along with the function.
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
Date: 22 Jul 2001 15:04:01
Message: <3b5b23a1@news.povray.org>
In article <chr### [at] netplexaussieorg> , Chris Huff
Ah, thanks!  I knew there was something but apparently I remembered it the
wrong way.
     Thorsten
BTW, this is fixed in the most recent versions, isn't it?  If not, please
remind me in the other group.
e-mail: tho### [at] trfde
Date: 22 Jul 2001 21:43:03
Message: <3b5b8127$1@news.povray.org>
The real question is rather simple: you can define the "container" using a
shape:
 sphere <0,0,0>, 2
but you can't perform any type of modifications to that sphere, such as
sphere <0,0,0>, 2 scale * .2
so even if it is simply defining the limits of the isosurface, which I
understand, I wonder why you can't apply scale, rotate, or other
transformations to the container.
The second question is why other shapes besides the box and sphere can't be
used; does anyone know the history/reasoning behind that?
Rather than intersecting the isosurface itself with other shapes, I just
thought it might be useful to have means to transform the container or use
other shapes directly as the container; that would be the simplest solution
for my purposes.
Best,
D.
"Andy Cocker" <big### [at] mariner9fsnetcouk> wrote in message
news:3b5af336@news.povray.org...
> I may have misunderstood your problem, but couldn't you intersect the
> isosurface with your desired primitive ie cone, cylinder etc? Then you
could
> apply all your rotates and scales to the intersected primitive.
> Andy
> "Dennis Milller" <dhm### [at] mediaonenet> wrote in message
> news:3b5a415a@news.povray.org...
> > Well to clarify, the shape of the contained_by object is very clear (a
box
> > or a sphere) in some points of the animations that I am working on. I'm
> > trying to find out if there are any ways to modify those shapes, which
are
> > like a frame for the isosurface. Why you can't rotate or scale the
> > contained-by object independent of the isosurface itself or for that
> matter,
> > use other types of contained by shapes (cylinder, cone, etc.).
> > Anyone know?
> > thanks,
> > Dennis
Date: 22 Jul 2001 23:35:22
Message: <3b5b9b7a@news.povray.org>
news:3b5b8127$1@news.povray.org...
> shape:
>  sphere <0,0,0>, 2
be
solution
> for my purposes.
Simplicity of the bounding shape is most likely the reason it is box or
sphere only and not just anything else like CSG shapes, etcetera.  The
bounds must contain an equation of sorts so your suggestion is pretty much
to use an equation to contain an equation.  At least that's my uneducated
guess.
Could be much more to it than that.
Bob H.
Date: 23 Jul 2001 04:50:20
Message: <3b5be54c@news.povray.org>
In article <3b5b8127$1@news.povray.org> , "Dennis Milller"
It is just a limitation as people have pointed out before.  Historically
there were bugs when transforming isosurfaces (as I pointed out before).  As
Warp pointed out, those have been fixed and now this limitation is still
there.  MegaPOV simply contains a lot of code that is still in development.
It is the way it is until it is changed.
Simplicity of the language and isosurface implementation.  Internally an
isosurface is only calculated if a ray intersects its simple container.  For
everything else use CSG because complex intersections are the domain of CSG,
not isosurfaces.
    Thorsten
