POV-Ray : Newsgroups : povray.unofficial.patches : Film exposure simulation patch Server Time
17 May 2026 02:29:55 EDT (-0400)
  Film exposure simulation patch (Message 1 to 9 of 9)
Subject: Film exposure simulation patch
Date: 9 Nov 2002 15:24:08
Message: <3DCD6EE6.DAC44FB5@luxlab.com>
No binaries, just a diff for official 3.5.
http://news.povray.org/povray.binaries.images/28651/
http://luxlab.com/files/exposure.diff.gz
_____________
Kari Kivisalo
Subject: Re: Film exposure simulation patch
Date: 11 Nov 2002 07:36:33
Message: <3DCFA451.E5FC2AED@luxlab.com>
Added a new keyword and documentation. The previous link is redirected.
http://luxlab.com/files/exposure.htm
_____________
Kari Kivisalo
Date: 12 Nov 2002 08:11:34
Message: <3dd0fe06@news.povray.org>
> _____________
> Kari Kivisalo
Hi Kari,
When you say
'color = exposure_gain*(1 - exp(-exposure*color))'
I guess you are applying it to each of the colour channels separately?
Could you add an option to apply it to the 'luminosity' of the pixel
instead? This would keep the 'hue' and 'saturation' of the colour
unchanged, just compress the brightness ...
Just a thought,
	Mike Andrews.
Date: 12 Nov 2002 11:16:56
Message: <chrishuff-124577.11162412112002@netplex.aussie.org>
In article <3dd0fe06@news.povray.org>,
Nice idea, but I don't think that's how either film or the eye works.
They both have red-green-blue sensitive portions that are probably
affected equally (or nearly so) by the processes that cause this.
http://tag.povray.org/
Date: 12 Nov 2002 13:26:06
Message: <3DD147BC.46DA9B4D@luxlab.com>
This is how color films work. The emulsions for primary colors
react independently.
> instead?
It could be applied to the CIE luminance component but would it
be usefull? I'll add it anyway because I'm curious :)
_____________
Kari Kivisalo
Date: 13 Nov 2002 08:09:03
Message: <3dd24eef$1@news.povray.org>
I'm sure it's not how film works. :-)
On the other hand I seem to remember reading that because of the
interconnections locally in the retina the brain tends to process
something like hue-saturation-intensity rather than RGB ... whether this
has any bearing on the matter I'm not sure.
Bye for now,
	Mike Andrews.
Date: 13 Nov 2002 08:14:36
Message: <3dd2503c$1@news.povray.org>
Is there ever a better reason ? :-)
I look forward to seeing if it makes any visual difference.
Bye for now,
	Mike Andrews.
Date: 13 Nov 2002 08:49:54
Message: <3DD25880.DE36D1D3@luxlab.com>
I'm not trying to model human visual system here. That would require
way more processing and would have to operate on the whole image.
I tested the luminance processing in Photoshop and the results didn't
look that good so at the moment I'll just stick to what I know works.
I may include it later.
_____________
Kari Kivisalo
Date: 13 Nov 2002 09:51:02
Message: <chrishuff-FBAE45.09503513112002@netplex.aussie.org>
In article <3dd24eef$1@news.povray.org>,
That may be so, but the pupil and individual rods and cones are the main
causes of brightness adaptation and other nonlinear response. If you can
produce a response using a smaller brightness range that the brain would
get from a brighter light source, the image will look brighter. Part of
why the sun in sunset images seems brighter than a white sheet of paper.
