POV-Ray : Newsgroups : povray.unofficial.patches : Hey, Warp (Tesselation patch: the fire test) Server Time
27 Jul 2026 04:00:27 EDT (-0400)
  Hey, Warp (Tesselation patch: the fire test) (Message 13 to 22 of 22)
Subject: Re: Hey, Warp (Tesselation patch: the fire test)
Date: 6 Oct 2001 17:27:45
Message: <3BBF782D.A6C7FFA2@gmx.de>
> I would say it's a design assumption which turns out to be wrong, sometimes:
> The Inside test and the trace test may disagree;
> They should not, but they do in some occurences.
Is it allowed to ask, *why* there is no intersection if one point is
outside and the other inside?
Anyway, nice it works, now looking forward to the release.
Date: 7 Oct 2001 03:54:16
Message: <978urtkbo2lqtti8buc3a40mppgr7a34gs@4ax.com>
On Fri, 5 Oct 2001 17:45:10 +0100, "Mick Hazelgrove"
<mic### [at] mhazelgrovefsnetcouk> wrote:
>I look forward to seeing this patch working and integrated into the next
>incarnation of megapov based on the 3.5 code as I belive it to be
>potentially one of the most useful additions to Pov. So good luck, fingers
>crossed.
Ditto. With proper tessellation, I might start working on a doodle
I've been delaying for way too long now.
Peter Popov ICQ : 15002700
Date: 7 Oct 2001 05:45:52
Message: <3BC02718.1D0493F@free.fr>
All questions are allowed... Even "How many angels can dance on the head of a pin ?"
Getting the correct answer might be harder.
The code for inside and trace is always different (by design).
I guess that different algorithms can give different results.
(Just look at the sturm solver option for example)...
Date: 8 Oct 2001 09:28:48
Message: <slrn9s3agp.2lm.ron.parker@fwi.com>
My guess would be that you're running afoul of the provisions in all of the
intersection code that throw out intersections that are too close to the
start of the ray.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 8 Oct 2001 11:01:07
Message: <3BC1BFC0.6E9998C4@atosorigin.com>
> start of the ray.
Maybe, Maybe not. That aspect was already taken care of in the initial patch by
making the start point of the ray a little more on the outside that it would
have
been needed to if only the segment to test was really done.
There is two things in my posting of a solution:
 1. Where the bug manifest itself, and why.
 2. How to correct that.
Point 2 is probably open to wide discussion (and holy war).
    As Warp is the author of the patch, he is the one to choose.
Point 1 is hard-fact, and now that it has been found, it is easy to
demonstrate (just put a dirty "printf" before the Intersection() call,
 and another in the "then" part of the "if" that is testing the return value
of Intersection; If the assumption of design was correct, you should get
the same number of first printf than of the second; Alas, take any bogus scene
and you will see that there is more of the first!(*)
As provided, the intersection should have been tested.
My correction was to "Add the test and an else behaviour", because it
was simpler to implement and easier to prove.
Another possible may have been "Fix the parameters of Intersection so
that the problem never occurs again", which seems to me to be harder
to implement and probably impossible to prove.
A third solution was also "Fix the insideness structure on the fly so
that no tesselation of that tetrahedron will occurs", which seems a good idea
if one wants to have some goto in the code. Moreover, it may have opened a
tricky flickering case in which we would be in an infinite loop.
(*): If you do not like printf, you can simply have a ++/-- on a counter.
By the end of the tesselation, it should have been as it was before.
It will not with a bogus scene. So, you may even have a detection of the bogus
scene and have the tesselation failed at parse time, if you want.
I find that approach a little too much hostile, because the user has probably
no way to make the scene works correctly, other than playing randomly with
the tesselation parameters...
Date: 8 Oct 2001 13:01:35
Message: <3bc1dbef@news.povray.org>
:     As Warp is the author of the patch, he is the one to choose.
  I have an idea. It will probably make the tesselating slower, but if it
works, it works.
  As you say, the problem is probably in the insideness test, which can
differ slightly from what the intersection test does. Thus, we should just
get rid of the insideness test completely. (Of course as the main purpose of
the insideness test is speed, we will lose this seedup, but it seems that it's
out of question.)
  So we should do it solely with the intersection calculation. But how?
  As we know, POV-Ray doesn't start the intersection calculation from the
starting point of the ray but moves a small amount forward before actually
shooting the ray (this is necessary for many things, such as reflection,
refraction etc. where the starting point of the ray is exactly on the surface
of an object).
  I don't like the idea of moving the starting point back a bit before making
the intersection test because it can give a wrong result (it can intersect
the surface even though the tetrahedron is not intersecting it).
  However, I have another idea: Move the starting point back a considerable
amount (not a huge step, but more than just a tiny fraction; something like
0.1 units or whatever) and then get *ALL* the intersections of the ray and
the object. After this look if any of these intersection points is between
the real start and end points. If there is any, take it.
  Of course there could be more than one point between the start and end
points, but that's an accuracy thing. We take just one of them (it doesn't
really matter which).
  The advantage of this is that you don't miss points by accident (because
of the inside vs. intersection problem) and you get an accurate result (only
points which are truely at the edges of the tetrahedron are taken, not points
outside it).
  Yes, this is slow, I know. But if it works, it works...
  I have to test this when I got the time...
Date: 8 Oct 2001 13:17:44
Message: <3BC1E0A5.1BBC7E20@gmx.de>
> out of question.)
I'm not sure, but this could slow down things enormously, especially for
isosurfaces.
It would be nice to have another method and implement both to compare.
Date: 8 Oct 2001 14:14:22
Message: <3bc1ecfd@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
: I'm not sure, but this could slow down things enormously, especially for
: isosurfaces.
  Note that shadow calculations also calculate all intersections. And it
isn't that slow, is it?
Date: 8 Oct 2001 14:29:25
Message: <3BC1F140.CAB01C02@gmx.de>
> : isosurfaces.
I meant replacing insideness tests with intersection tests, this would
probably be much slower.
Date: 8 Oct 2001 15:51:04
Message: <3bc203a7@news.povray.org>
: I meant replacing insideness tests with intersection tests, this would
: probably be much slower.
  Yes, it will be slower. However, using the insideness test for speed doesn't
work. That's exactly what my original patch did.
