POV-Ray : Newsgroups : povray.unofficial.patches : photons again... Server Time
11 Jul 2026 19:53:25 EDT (-0400)
  photons again... (Message 1 to 4 of 4)
Subject: photons again...
Date: 29 Aug 2001 09:52:38
Message: <3B8CF39C.2080807@xlstudio.com>
Hi.
I've just started to play with photons and:
- I didn't manage to make my area lights produce photons without
specifying the "area_light" keyword in the photon definition of the light.
- When using photons with an area light, I need a huge amount of photons
(3.000.000) to get something smooth...
- I wanted to make a mirror: a refracting glass and a reflective surface
just behind...It doesn't work...I tried to add the ignore_photon and/or
pass_through (not sure of the keyword, don't have my scene here) and
there was no result...
Can someone explain those 3 points to me ?
thanks.
                David Gemelli
Subject: Re: photons again...
Date: 29 Aug 2001 10:18:48
Message: <3b8cf9c8@news.povray.org>
gemelli david <d.g### [at] xlstudiocom> wrote:
: Can someone explain those 3 points to me ?
  Let me guess: Your area light is inside a shadowless object with no
photons_pass_through applied.
Date: 29 Aug 2001 10:22:24
Message: <3B8CFA98.7030609@xlstudio.com>
No...it is just above a box...floating in the pure empty air...
I'll do the scene again and post the code and image...
Date: 30 Aug 2001 08:22:45
Message: <3B8E3192.4119E430@reading.ac.uk>
I used an area light with photons in the angle dependent shader scene I
posted.
The source is in p.b.s-f so you can see how I did it. Just putting
    photons { count 2000000 jitter 0.5 }
in the global settings,
    photons { reflection on refraction on }
in the area light source and
    photons { target refraction off reflection on ignore_photons }
in the mirror seemed to work ...
I used PoVMan for rendering mine - which MegaPoV variant are you using?
	Mike Andrews.
gemelli david wrote:
> Hi.
> thanks.
>                 David Gemelli
