POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov 0.6a Available Server Time
18 Apr 2026 19:58:48 EDT (-0400)
  MegaPov 0.6a Available (Message 1 to 10 of 19)
Subject: MegaPov 0.6a Available
Date: 16 Oct 2000 01:23:22
Message: <39ea90ca$1@news.povray.org>
We are happy to announce the release of MegaPov 0.6a.  This is a bugfix
release to clean up some problems with MegaPov 0.6.
Windows:
http://nathan.kopp.com/patched.htm
Macintosh:
http://users.skynet.be/smellenbergh
DOS:
http://www.stuartgibson.com/
The demo scenes can be viewed on-line at Smellenbergh's site:
http://users.skynet.be/smellenbergh (click on the "Demos" link in the
navigation bar on the left).
Here are the changes for MegaPov 0.6a:
* Fixed a bug in the proximity patch. If no sample_weight vector was given
it was filled with random values, giving different results for each
rendering.
* In isosurface statistics, max gradient is reported again
* Fixed more memory leaks in isosurface
* julia sqr and power (^) now allowed without version unofficial xx
specifier: it is a legal keyword in POV-Ray 3.1
* In the manual updated section 8.9 displace warp
* In the manual corrected  9.20: the formula used is:
Red*0.3+Green*0.59+Blue*0.11
* In DoPostProcess() in postproc.c give an error if for some reason the
input file could not be opened. Previously MegaPOV would crash.
* density file is now positioned from 0 to 1 again. We changed that in 0.6
but obviously this was incorrect. It crashed MP often too. Files written by
the df3 patch are now flipped so that the result is correct.
* df3 in i_dat3d now works again. This was listed as fixed in MP 0.6 but
only now in 0.6a this is realy fixed!
* Updated the displacement warp patch to MP+0.3.2. This adds the type
keyword.
* Fixed bug in transform when used like this: "transform {
DeclaredMyTrans }"
Enjoy!
-The MegaPov Team
Subject: Re: MegaPov 0.6a Available
Date: 16 Oct 2000 03:09:06
Message: <39EAA9D8.6DD00C80@aetec.ee>
I'm happy to hear this!
But during testing of my patch I've found memory leak in old version
(0.6) and seems like it ain't fixed in new version either:
Function InitMallocCaches in file lighting.c allocates cache sizes
(ShadowMediaListCacheSize, LightingMediaListCacheSize &
MediaIntervalCacheSize), but does not free them in DeInitMallocCaches.
Date: 16 Oct 2000 05:44:06
Message: <icjlus49878d8q9ng8k5nivdvq4vigm2ri@4ax.com>
  Thanks much, Nathan and others on the WinMegaPov Team.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 16 Oct 2000 08:18:02
Message: <39EAF1FB.A3CD8C43@schunter.etc.tu-bs.de>
Nathan Kopp wrote:
> Enjoy!
> -The MegaPov Team
I do !  :-)
Date: 16 Oct 2000 10:06:41
Message: <39EB0A26.9D68228A@my-dejanews.com>
all charioteers : Ben Hur  :: all programmers : MegaTeam
all woodsmen : Davy Crocket :: all programmers : PovTeam
> Windows:
> Macintosh:
> DOS:
> rendering.
> keyword.
> DeclaredMyTrans }"
> Enjoy!
> -The MegaPov Team
Date: 16 Oct 2000 10:22:36
Message: <39eb0f2c@news.povray.org>
Some files have capital letters in their names but they are included all
in lower-case.
  This is a problem. The #included file name should be exactly the same as
the file name (case sensitive). Either the #include has to be renamed or
the file name itself has to be renamed to lower case (probably best solution).
  I can automatically convert all file names to lowercase with a relatively
short unix command, but all unix users might not know enough to do it.
It would be best that the files were in lowercase in the zip-file itself.
Subject: Re: MegaPov 0.6a: manual correction for ss 8.9
Date: 16 Oct 2000 11:00:38
Message: <39EB1876.6DE59632@reading.ac.uk>
Hi Nathan,
The manual gives the displace warp syntax as
warp { displace { PATTERN, COLOR_MAP } type TYPE }
which is what went into the MP+ manual as well.
I understand the correct syntax (at least, it works for me) is
warp { displace { PIGMENT_BODY type TYPE } }
which means you can put in anything from a declared pigment name to a
full compound pigment pattern ...
Bye for now,
	Mike Andrews.
> keyword.
> Enjoy!
> -The MegaPov Team
Date: 16 Oct 2000 11:02:34
Message: <39EB1884.F97AC1BD@enst.fr>
> in lower-case.
	Unfortunately, Windows has its own ideas about which letters should be
upper case and which lower case, and AFAIK there's no easy way to change
that.
	On unix, the -L option of unzip is supposed to fix the problem...
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 16 Oct 2000 12:09:15
Message: <39eb282b@news.povray.org>
Thanks for all your efforts, much appreciated.
Mick
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:39ea90ca$1@news.povray.org...
> Windows:
> Macintosh:
> DOS:
> rendering.
by
> keyword.
> DeclaredMyTrans }"
> Enjoy!
> -The MegaPov Team
Date: 16 Oct 2000 12:24:05
Message: <39eb2ba5$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote...
> in lower-case.
solution).
relatively
I apologize for this.  It seems to me that each time I put together a
release, I'm having to fix those filenames.  I get new versions of the files
from a large variety of sources, and often times they come to me with the
first letter capitalized.  When I unzip new files, I lose the names that I
fixed last time.  And, unfortunately, I don't always catch each and every
file each and every time.  I have a little utility that renames all files to
lowercase, but I forgot to use it this time.
-Nathan
