POV-Ray : Newsgroups : povray.unofficial.patches : How many lines of code: eliminate plateaus in noise3d by interval change Server Time
24 Jun 2026 19:57:04 EDT (-0400)
  How many lines of code: eliminate plateaus in noise3d by interval change (Message 1 to 10 of 18)
Subject: How many lines of code: eliminate plateaus in noise3d by interval change
Date: 21 Mar 2000 08:21:21
Message: <38D77653.600EB09D@my-dejanews.com>
We have all discussed the issue many times without answering the
following question:
How *hard* would it be to "fix" pov to eliminate the plateuas that exist
in the noise3d function?
I think that someone once said that pov used an unorthodox interval in
setting up its noise, something like [0,1.0] when the rest of the world
uses [-0.5,0.5], or vice versa.
If this were the case, could one simply change a half dozen CHARACTERS
and fix the problem?
Noise3d is my favorite function for a number of reasons, and those
plateaus are bugging me!
_________________
Greg M. Johnson
povray is the only programming language I know.
Subject: Re: How many lines of code: eliminate plateaus in noise3d by interval change
Date: 21 Mar 2000 10:26:24
Message: <38d794a0$1@news.povray.org>
>following question:
It's not a question of how hard it would be, it's a question of how many
scene files it would break.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 21 Mar 2000 10:48:04
Message: <38d799b4@news.povray.org>
But, you (programmers) have always said that you could add something for
backward compatibility. Why don't you just fix it and add a #version thingy
to use the old noise?
Date: 21 Mar 2000 12:30:04
Message: <38d7b19c@news.povray.org>
How about calling it noise3d2,  noisepf, noisegmjipitn,  noiseII, coolnoise ?
While I am truly appreciative of the giants who have given us this thing
called povray, I'd guess plateaus broke more scenes than a change would
break.
> >following question:
Date: 21 Mar 2000 15:59:17
Message: <38d7e2a5@news.povray.org>
Greg M. Johnson <gre### [at] my-dejanewscom> wrote...
> following question:
7 lines of code (plus comments).  ...and then some parser stuff for adding
backwards compatibility.
Could be fewer, but I was going for code clarity.  :-)
-Nathan
Date: 21 Mar 2000 17:15:22
Message: <38D7F37A.58E14AB4@my-dejanews.com>
So how 'bout a   noise3dg(x,y,z)   for v. 0.5?
> -Nathan
Date: 21 Mar 2000 17:33:55
Message: <chrishuff_99-745758.17360021032000@news.povray.org>
In article <38D7F37A.58E14AB4@my-dejanews.com>,
"g" meaning what?
I personally would prefer rnoise(v) and rnoise3d(x,y,z).(Meaning
raw-noise and raw-noise3d. Of course, the one dimensional version isn't
really necessary, you could just use the same value for x, y, and z or
set two of them to a fixed value, I just think it would be good to have.)
Christopher James Huff
Personal e-mail: chr### [at] yahoocom
Date: 21 Mar 2000 18:13:40
Message: <38d80224$1@news.povray.org>
I am not any form of expert on this or any subject for that matter. So,
please understand my naivete on this subject. I am worried that I may just
    Up to recently I have been a programmer, of 20 years experience in
non-related subjects, before my disability put a period on the end of my
career. As I read the quoted message, I began to think, as I would back
then. I wondered if the following was possible. I know the people here are
the true experts and will know the feasibility of my idea in an instant. I
hope they will correct me if wrong, just not too harshly...
    I would approach this problem by creating a global variable, an optional
arg to the command, or ini/inc file entry. So legacy POV programs
using/requiring the older form of the variable data is unaffected. This
would be because the default value will remain the original value. In
addition, those wishing a different one can just add the optional arg, set
the global, or make an ini/inc file entry.
    I do not know if this is a good idea or not. Nevertheless, hope it will
help. There may be another way to do it that I, do to my lack of knowledge
of POV, do not know...
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:38d794a0$1@news.povray.org...
> >following question:
Date: 21 Mar 2000 19:41:36
Message: <1hXYOOGigZhtLjnb8ms1QVWiooct@4ax.com>
On Tue, 21 Mar 2000 18:16:24 -0500, "JR McConnell" <sno### [at] homecom>
The creators of POV-Ray, more precisely those responsible for the
#version directive, must have been thinking along the same lines :)
As Tony suggested, making sure that #version 3.1; uses the old method
should suffice. I too hate to see them plateaus with height fields and
normals and would love to have them gone.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 22 Mar 2000 02:20:05
Message: <38d87425@news.povray.org>
Nathan Kopp wrote in message <38d7e2a5@news.povray.org>...
>> following question:
Would that also remove the plateaus from the bozo pattern?
Gail
* gsh### [at] monotixcoza              * Reality.dat not found         *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* Document program code? Why do you think it's called code?        *
