POV-Ray : Newsgroups : povray.unofficial.patches : Sphere-sweep Variations Server Time
23 Mar 2026 13:09:56 EDT (-0400)
  Sphere-sweep Variations (Message 1 to 5 of 5)
Subject: Sphere-sweep Variations
Date: 10 Jan 2000 10:46:49
Message: <3879FD6F.9EAE9648@shinbiro.com>
Dear all,
   I understand there is a sphere-sweeping function(sphere-sweep-spline)
in the superpatchPOV. Would it be possible to start from something else
other than a
sphere? For example, sweeping with some egg-like primitives, or
triangle-shaped sphere-variants, or torus along a predefined curve/path.
If I could possibly choose a torus as a starting primitive for the
sweeping, that would generate a hollow tube, or pipe.
 I would like to know whether this is some sort of built-in function by
changing some options  in the patch, or somewhat involving task like
writing lines-and-lines of programming.
Thanks in advance,
  Jong
Subject: Re: Sphere-sweep Variations
Date: 10 Jan 2000 11:46:39
Message: <qqm66x13mds.fsf@goldach.fmi.uni-konstanz.de>
J Kim <sjy### [at] shinbirocom> writes:
> other than a
As far as I know, it the latter case is true. The implementation of the
sphere_sweep object is tied with the shape of a sphere. In fact, there is
no object swept internally. The shape of the sphere_sweep has been
calculated "by hand" up to parameterization. By this, the intersection of
the ray and the sphere_sweep can be determined efficently.
Perhaps you should have a look at the original page of the creator of this
patch:
http://www.informatik.uni-bremen.de/~vader/pss/pss.html
When you want to sweep other objects, I suggest that you create a bunch
of objects. This can be done either directly or with one of the various
macros mentioned by others.
On the other hand, substracting two sphere_sweeps with different radii
may be close to your desired torus_sweep.
Happy tracing
http://thomas.willhalm.de/ (includes pgp key)
Date: 10 Jan 2000 11:50:09
Message: <387A0B9E.B5D7C7DB@pacbell.net>
This is an interesting macro that might do the job -
http://members.xoom.com/dvarrazzo/epov.htm
Date: 11 Jan 2000 20:15:26
Message: <387BD5A5.1411B85B@mm.ewha.ac.kr>
Dear Thomas,
 I really appreciate your help.
Jong.
> > other than a
> patch:
> Happy tracing
> Thomas
Date: 11 Jan 2000 20:24:13
Message: <387BD7B5.4DFD9A77@mm.ewha.ac.kr>
Dear Ken,
 I really thank you for your help.
Jong
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
