POV-Ray : Newsgroups : povray.unofficial.patches : Radiosity question Server Time
2 Nov 2024 09:21:36 EDT (-0400)
  Radiosity question (Message 1 to 10 of 14)
Subject: Radiosity question
Date: 23 Nov 1999 02:48:00
Message: <383A472A.888C6A74@umh.ac.be>
Hello,
I understand all well in the new implementation of the radiosity by
Nathan, but not this thing
max_sample 2         // CHANGE - this should be the same as the
brightest object
adc_bailout 0.01/2   // CHANGE - use adc_bailout = 0.01 /
brightest_ambient_object
what is the brightest object, where I find the number 2 in my scene?
Thanks,
Fabian.
Subject: Re: Radiosity question
Date: 23 Nov 1999 10:17:13
Message: <383aaff9@news.povray.org>
Fabian,
By "brightest object", I mean, "If you shoot rays into your scene, turn the
colors to grey-scale, what will be the biggest number, ignoring specular and
phong highlights?"
For example, if you have all "diffuse 1.0" objects with pigment colors no
greater than <1,1,1> and the sum of your light sources is 1.5, then the
brightest any object can look is 1.0*1.0*1.5 = 1.5.  On the other hand,
let's say one object is supposed to act like a light source, so you use
"ambient 20" with that object.  In that case, your brightest object will be
20 and you'd want to use a max_sample of 20 and a radiosity adc_bailout of
0.01/20.
-Nathan
Fabian Brau <fab### [at] umhacbe> wrote...
> Hello,
> brightest object
> Thanks,
> Fabian.
Date: 23 Nov 1999 11:01:32
Message: <383aba5c@news.povray.org>
Couldn't this be calculated automatically? For example in the mosaic
previews?
Date: 24 Nov 1999 00:30:35
Message: <383B7893.D69DCEBB@peak.edu.ee>
You couldn't quarantee that the brightest object is hit during the preliminary
pass.
Margus
> previews?
Date: 24 Nov 1999 03:29:45
Message: <383BA275.71D6E721@umh.ac.be>
Nathan,
Thank you very much for your answer.
Fabian.
Nathan Kopp wrote:
> Fabian,
> phong highlights?"
> 0.01/20.
> -Nathan
> > Hello,
> > brightest object
> > Thanks,
> > Fabian.
Date: 24 Nov 1999 11:52:39
Message: <383c17d7@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote:
: You couldn't quarantee that the brightest object is hit during the preliminary
: pass.
  Then the object is so small that it doesn't affect the scene anyways.
  And if there were any problem, you could always specify the correct value
by hand...
Date: 25 Nov 1999 02:12:46
Message: <383CE16E.CA653F42@atos-group.com>
> : pass.
> by hand...
Just an idea...
Not as obvious at it may seems, but the object may be out of the image.
If you're doing an animation with a traveling,
the appearing/vanishing objects with radiosity may just impacts a lot
the brightness of the consecutive images.
Now, the question is "is using radiosity in an animation a reasonable thing ?".
Date: 25 Nov 1999 07:29:19
Message: <383d2b9f@news.povray.org>
J. Grimbert <jgr### [at] atos-groupcom> wrote:
: Not as obvious at it may seems, but the object may be out of the image.
  It doesn't matter. It will be hit in the mosaic preview anyways (that's
what radiosity is about).
: Now, the question is "is using radiosity in an animation a reasonable thing ?".
  Why it shouldn't?
Date: 25 Nov 1999 12:47:12
Message: <383D76BD.2F70BCAC@peak.edu.ee>
How much an object affects the scene depends on the balance of size and
brighness. Smaller objects just have to be brighter, proportionally to the area
of their projection, to give the same effect (not accounting for increased
statistical error due to limited sample rays)
Margus
> by hand...
Date: 26 Nov 1999 05:53:22
Message: <383e66a2@news.povray.org>
Perhaps there could be a special keyword that you could apply to objects
which tells povray "this object is very small and very bright, so send more
radiosity rays here".
