POV-Ray : Newsgroups : povray.unofficial.patches : Non-triangular patches -> triangles...? Server Time
18 May 2026 03:53:14 EDT (-0400)
  Non-triangular patches -> triangles...? (Message 1 to 6 of 6)
Subject: Non-triangular patches -> triangles...?
Date: 19 Aug 1999 13:20:46
Message: <37bc3976.5411425@news.povray.org>
Is there an accepted "safe" way of converting an unknown number of
points into a series of triangles for a mesh/mesh2?
I'm looking at the structure of .OBJ files for conversion to uvPOV (in
batches - and so far I've not found a batch OBJ to POV converter) and
while examining the data (to learn and understand the format,
basically) I've discovered several "patches" with more than 3 points.
although the most I've *seen* so far is 4 points, I can draw a 4-point
patch in 2D that'd "break" if translated simply into 2 triangles.
Help?
Oh yeah - if anyone knows of a batch OBJ -> uvPatch POV/Superpatch POV
converter then pls let me know - you'll save me a lot of work (even if
it is "fun").
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at http://www.who3d.cwc.net/
Subject: Re: Non-triangular patches -> triangles...?
Date: 19 Aug 1999 13:37:40
Message: <37BC40E0.F9B2941F@pacbell.net>
> Help?
> it is "fun").
> Cheers,
> Cliff Bowman
I don't know if it supports batch processing but it does do obj > mesh2:
http://www.warmann.com/users/broken/utils/utils.html
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 20 Aug 1999 08:04:42
Message: <37BD4511.C8170796@inapg.inra.fr>
Sorry, but obj2pov doesn't support batch processing and exports to the other
mesh syntax, not the mesh2 one. Of course you can run obj2pov in a batch
file (*.bat) but you'll have to add the texture info by hand in each obj
file before processing.
3DS2pov supports batch provessing of 3DS files and the mesh2 syntax, so if
you can export to 3DS it's a possible solution.
Gilles Tran
> Ken Tyler
Date: 20 Aug 1999 11:00:37
Message: <37BD6D72.38CBD474@pacbell.net>
> Gilles Tran
The website I referred to specifically say's that it supports the UvPov version
of meshes. I still am unsure about textures and batch files though.
Ken Tyler
Date: 20 Aug 1999 13:24:09
Message: <37bd8f45.61782948@news.povray.org>
>> Gilles Tran
Does uv mapping (not mesh2 per se but uv_mapping version of mesh) with
very little work. I know - I got OBJ2POV via your links page in the
first place!
Doesn't do batch converts though, and has been known to crash on some
(poorly designed0 .OBJ files... which is why I'm looking into the .OBJ
format myself.
Cheers,
Cliff Bowman
Date: 20 Aug 1999 13:25:48
Message: <37bd8fa0.61873922@news.povray.org>
On Fri, 20 Aug 1999 14:07:45 +0200, Gilles Tran <tra### [at] inapginrafr>
>Gilles Tran
It's a pretty good one - expect Poser seems to screw up the UV mapping
when exporting to .3DS formatting (you end up with neato-models, but
seams in the textures).
So far unless I can rely on Poser (and other programs) to adhere to no
more than 4 points making 2 simple triangles it looks like OBJ2POV
will be my best bet.
Cheers,
Cliff Bowman
