POV-Ray : Newsgroups : povray.unix : Error(s) compiling on Ubuntu 14.04 : boost thread library solution fails Server Time
9 May 2025 05:06:49 EDT (-0400)
  Error(s) compiling on Ubuntu 14.04 : boost thread library solution fails (Message 1 to 5 of 5)
Subject: Error(s) compiling on Ubuntu 14.04 : boost thread library solution fails
Date: 16 Apr 2016 06:30:00
Message: <web.5712135af8ae692887cb7b50@news.povray.org>
Hello
I am trying to install PovRay on Ubuntu 14.04.
I think I have followed the guideline given in this newsgroups. But it still
doesn't work.
I've checked that all dependencies are updated.
libboost-dev
zlib1g-dev
libpng12-dev
libjpeg8-dev
libtiff5-dev
libopenexr-dev
I followed the instructions given in github
% cd unix/
% ./prebuild.sh
% cd ../
% ./configure COMPILED_BY="your name <email@address>"
% make
but the 'make' doesn't work
sudo ./configure COMPILED_BY="FredDM<dae### [at] bluewinch>"
leads to this error with the boost thread library
configure: error: in `/home/fred/Programmation/PovRay/povray-3.7-stable':
configure: error: cannot link with the boost thread library
It is a known error, but the solution provided
sudo ./configure COMPILED_BY="FredDM<>" LIBS="-lboost_system -lboost_thread"
leads to a new error
Programs
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: C compiler cannot create executables
I have checked gcc
fred@Flat-Ubu:~/Programmation/PovRay/povray-3.7-stable$ gcc --version
gcc (Ubuntu 4.8.4-2ubuntu1~14.04.1) 4.8.4
If anyone can give me a clue, I would be very glad.
Thanks in advance
Fred
Subject: Re: Error(s) compiling on Ubuntu 14.04 : boost thread library solution fa=
Date: 16 Apr 2016 07:20:00
Message: <web.57121f16411ded5f9a4230a50@news.povray.org>
"Fred DM" <dae### [at] bluewinch> wrote:
> Hello
> doesn't work.
> libboost-dev
> zlib1g-dev
> libpng12-dev
> libjpeg8-dev
> libtiff5-dev
> libopenexr-dev
> % cd unix/
> % ./prebuild.sh
> % cd ../
> % make
> Programs
> I have checked gcc
> Thanks in advance
> Fred
i know nothing about linux but i do this compilation chore regularly, the last
time yesterday or the day before.  i use xubuntu which does not have some stuff
that is normal or expected, apparently.  here is a list i made the last time, as
i was tired of not having it down in one place, of the stuff listed as needed,
the versions i installed using synaptic, and some stuff not listed that was
needed;
libboost-dev            libboost1.55-dev
libboost-date-time-dev  libboost-date-time1.55-dev
libboost-thread-dev     libboost-thread1.55-dev
zlib1g-dev              zlib1g-dev
libpng12-dev            libpng12-dev
libjpeg8-dev            libjpeg8-dev
libtiff5-dev            libtiff5-dev
libopenexr-dev          libopenexr-dev
g++-4.8                 g++ version 4:4.8.2-1ubuntu6
autoconf                autoconf version 2.69-6
automake                (already had Automake 1.14)
Subject: Re: Error(s) compiling on Ubuntu 14.04 : boost thread library solution fails
Date: 16 Apr 2016 08:51:19
Message: <57123547$1@news.povray.org>
Am 16.04.2016 um 12:27 schrieb Fred DM:
I recommend using the latest master branch instead of the stable.
Subject: Re: Error(s) compiling on Ubuntu 14.04 : boost thread library solution fail=
Date: 16 Apr 2016 15:15:01
Message: <web.57128e35bdd08cd887cb7b50@news.povray.org>
Thanks to clipka and to green for your quick answer.
I tried both solutions.
the added libraries didn't solve the problem.
But the use of the master branch did it.
Compilation went through without any problems.
Pov-Ray is working well.
Thanks a lot
I am sorry but I am new to this. I did compilations of small projects that I
created,but I never went through compilation of a real software before.
Can you explain me the difference between Master Branch and Stable Branch.
I had the wrong intuition to use the stable release.
Fred
Date: 16 Apr 2016 15:25:00
Message: <web.5712902f2cb4e04f7a3e03fe0@news.povray.org>
> Thanks a lot
> Fred
..../configure COMPILED_BY="you name" --prefix=/usr --with-x LIBS="-lboost_system
-lboost_thread -lboost_date_time"
specfile:
%define PKGRELEASE 3.7
Summary: The Persistence of Vision Raytracer
Version: 3.7.1.hg
Release: %mkrel 1
Group:  Sciences/Computer science
License: POV-Ray
# http://www.povray.org/distribution-license.html
URL:  http://www.povray.org
Source:  povray-%{version}.tar.bz2
Source1: %{name}.bash-completion
BuildRequires: zlib-devel
BuildRequires: libx11-devel
BuildRequires: libxpm-devel
BuildRequires: libpng-devel
BuildRequires: libjpeg-devel
BuildRequires: libtiff-devel
BuildRequires: svgalib-devel
BuildRequires: OpenEXR-devel
BuildRequires: SDL-devel
BuildRequires: boost-devel
%description
The Persistence of Vision Ray tracer creates three-dimensional,
photo-realistic images using a rendering technique called ray tracing.
It reads in a text file containing information describing the objects and
lighting in a scene and generates an image of that scene from the view
point of a camera also described in the text file. Ray tracing is not
a fast process by any means, (the generation of a complex image can
take several hours) but it produces very high quality images
with realistic reflections, shading, perspective, and other effects.
%prep
%setup -qn povray-%{version}
%build
cd unix
../prebuild.sh
cd -
CXXFLAGS="-Wno-multichar"
%configure2_5x --with-x COMPILED_BY="%_vendor" LIBS="-lboost_system
export LDFLAGS="${LDFLAGS} -L/usr/lib64"
%make
%install
%makeinstall_std
install -d -m 755 %{buildroot}%{_sysconfdir}/bash_completion.d
install -m 644 %{SOURCE1} %{buildroot}%{_sysconfdir}/bash_completion.d/%{name}
%files
%config(noreplace) %{_sysconfdir}/bash_completion.d/%{name}
%config(noreplace) %{_sysconfdir}/%{name}/%PKGRELEASE/povray.conf
%config(noreplace) %{_sysconfdir}/%{name}/%PKGRELEASE/povray.ini
%doc doc/*
%doc %{_mandir}/man1/povray.*
%{_bindir}/povray
%{_defaultdocdir}/%{name}-%PKGRELEASE
%{_datadir}/%{name}-%PKGRELEASE
