POV-Ray : Newsgroups : povray.unix : crash when using more than 4Gb memory Server Time
15 Jul 2025 22:41:15 EDT (-0400)
  crash when using more than 4Gb memory (Message 1 to 9 of 9)
Subject: crash when using more than 4Gb memory
Date: 6 Dec 2013 09:45:01
Message: <web.52a1e21f65a1b5a719fe75b20@news.povray.org>
Povray 3.7 on Ubuntu crashes as sson as it overpass 4giga of memory use.
Won't it be possible to release this threshold ?
Subject: Re: crash when using more than 4Gb memory
Date: 6 Dec 2013 10:04:15
Message: <52a1e76f$1@news.povray.org>
Can you provide a scene to reproduce ?
Which version of ubuntu ?
(IIRC, I went past the 4giga without problem in the 3.7RC series)
Have you check that your ulimit is not set to kill any process that use
more than 4 giga of memory ? (ulimit -m)
What is your memory size ?
Do you have a swap enable ?
Is povray on your system a 32 bits or 64 bits application ? Is your
system a 32 or 64 bits ?
Just because nobody complains does not mean all parachutes are perfect.
Date: 6 Dec 2013 10:30:01
Message: <web.52a1ec9086e531746ef9b64a0@news.povray.org>
https://bigfile.univ-lille1.fr/get?k=I319vBtHiACWmRtPQmr
13.10
unlimited
32g
don't know
64
Is your
64
Date: 6 Dec 2013 13:12:09
Message: <52a21379$1@news.povray.org>
Le 06/12/2013 16:26, fdecomite nous fit lire :
A dos file ?
Had to change seuilDeBase to 1.0 to get a memory hungry script
You have a division by 0 on first iteration (where level=0)
Parsing went fine to grab more than 5 giga (checked with top)
> 13.10
Same for me.
> 64
I would challenge that point:
My result for "file /usr/local/bin/povray" is:
ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically
linked (uses shared libs), for GNU/Linux 2.6.24,
BuildID[sha1]=0xadea6f17ceef66d4c66591feb618ef1a11cdba05, stripped
> Is your
> 64
Me too.
Download 'top.png' (21 KB)
Preview of image 'top.png'
Date: 6 Dec 2013 15:06:42
Message: <52a22e52$1@news.povray.org>
Am 06.12.2013 16:26, schrieb fdecomite:
> unlimited
Are you absolutely sure about this?
I can't think of any mechanism whatsoever in POV-Ray that could lead to
a hard crash at passing exactly 4GB of memory use.
If it was due to limited address space (i.e. a 32 bit version of
POV-Ray), the crash would presumably at 2GB or 3GB, as the OS usually
wants a chunk of the address space, too.
If it was due to some internal variable overflowing, the crash would be
at a much more arbitrary limit, as it would affect only an individual
data structure, with plenty of other data being around to take up
additional space.
There is also no mechanism implemented in POV-Ray to monitor memory
consumption (although such a mechanism would be useful at least on
Windows machines, in order to prevent the system from entering swap hell
when the physical memory limit is exceeded).
There is, however, that very mechanism in the Linux OS to forcefully
limit the size of any user process, and if it kicks in it will do
exactly what you see: Terminate the process hard.
Date: 6 Dec 2013 15:25:00
Message: <web.52a231bf86e53174c265ca6b0@news.povray.org>
> A dos file ?
Sorry, was level from1to7.1 to 8 should work the same
I also reached 5g. i don't understand from your mail if you also experienced a
scratch ?
> > 13.10
> Same for me.
> > 64
> > Is your
> > 64
> Me too.
Date: 6 Dec 2013 16:20:00
Message: <52a23f80@news.povray.org>
Am 06.12.2013 21:21, schrieb fdecomite:
>> A dos file ?
> scratch ?
Wait a minute - didn't you say that POV-Ray crashes as soon as it
exceeds 4GB? How could it reach 5GB then?
Please be more precise about the symptoms you are seeing, otherwise we
can't help you figuring out what's wrong.
Date: 7 Dec 2013 03:10:01
Message: <web.52a2d6ab86e53174c265ca6b0@news.povray.org>
> >> A dos file ?
> > scratch ?
Well, I said 4gb to make it simple. It was somewhere aroud 4-5g, i didn't wait
for the scratch loking the screen
Date: 7 Dec 2013 08:08:17
Message: <52a31dc1$1@news.povray.org>
Le 07/12/2013 09:04, fdecomite nous fit lire :
Do not simplify. 4gb is a classical 32bits limit, but 4-5gb is something
different.
Did you run memtest86+ recently ? (there is now a fix for it, as running
it from grub failed since 12.04, either it has reached already the
official distribution or i can search the PPA if you need it)
Testing your script with seuilDeBase = 1, and updated test of macro for
>= 7, it should generate about 21^7 objects.
Just 1 801 088 541 leaves. I do not have enough memory for that (that's
2G objects... ), but parsing went fine till 7.9g and more, (even past
8.4g is fine)
Parsing 6264062K tokens
By the time I finished that post, the memory used is at 10g and counting.
Parsing 8222562K tokens
