POV-Ray : Newsgroups : povray.unix : Wine on 64 bit linux Server Time
23 Dec 2024 10:57:05 EST (-0500)
  Wine on 64 bit linux (Message 1 to 6 of 6)
Subject: Wine on 64 bit linux
Date: 4 May 2010 04:37:57
Message: <op.vb599en2ufxv4h@go-dynamite>
I have 4Gb Ram and I'm dual-booting WinXP 32bit and Linux Ubuntu Ultimate
Edition 64Bit.
Will Pov-Ray 3.7 Beta 36 on Wine be able to use the full 4Gb RAM?
I'm a total n00b at Unix. I've installed Pov-Ray 3.6 on Linux via the
software manager, but I obviously can't get the beta there. I also have
yet to figure out how to use Pov-Ray on Linux :)
-Nekar Xenos-
Subject: Re: Wine on 64 bit linux
Date: 4 May 2010 06:12:00
Message: <4bdff2f0$1@news.povray.org>
> Edition 64Bit.
   I'm not sure as I didn't find a clear answer to this, but it seems so.
   My preferred method is to have a file manager window showing the scene
folder, then I open the scene/include files with my favorite editor, and
also a terminal to type the command line:
   http://www.ignorancia.org/uploads/images/Screenshot.jpg
   If you are using nautilus as file manager, there is an additional package
which adds the ability to open a terminal on the current folder: it's very
useful. As for the editor, I use SciTE: it has a POV language definition for
syntax coloring, and manages *big* files pretty well.
   The typical command line would be something like:
   povray +Itest.pov +w800 +h600
   Usually you type this one time, as later you can go back on the command
line history by using the keyboard arrows, change the resolution or add more
options, and render again.
   Hope this short intro helps...
Jaime Vives Piqueres
Date: 4 May 2010 06:27:43
Message: <op.vb6fcgm5ufxv4h@go-dynamite>
On Tue, 04 May 2010 12:16:05 +0200, Jaime Vives Piqueres
>> Ultimate
>> Edition 64Bit.
so.
ve
ene
nd
> package
> very
on
> for
> command
d
> more
Thanks for the help, Jaime.
-Nekar Xenos-
Date: 4 May 2010 06:42:15
Message: <4bdffa07@news.povray.org>
>>> the software manager, but I obviously can't get the beta there.
   I forgot to say that you probably will prefer to go by the Wine route for
the beta. Just install wine, the double click on the msi you downloaded from
the POV-Ray site. Nicely, all your POV files will get associated on nautilus.
   It's slow to start, but then it works pretty well if you don't have the
desktop effects enabled. There is a little problem with the tool buttons not
showing at times, but if you re-size the window they will appear.
   For me it works like a charm under Fedora 11. In fact, the scene I'm
rendering in this very moment is almost 6 times faster than 3.6 or MegaPOV,
when it should be only 2 times faster at most... this might be a very rare case.
Date: 4 May 2010 07:03:23
Message: <4bdffefb@news.povray.org>
> for the beta. Just install wine, the double click on the msi you
> downloaded from the POV-Ray site. Nicely, all your POV files will get
>  not showing at times, but if you re-size the window they will appear.
> MegaPOV, when it should be only 2 times faster at most... this might be a
> very rare case.
  Oh... and don't forget to turn off auto-reload, or it will hang when you
switch to other app.
Date: 4 May 2010 14:14:34
Message: <4be0640a$1@news.povray.org>
> Ultimate Edition 64Bit.
> Will Pov-Ray 3.7 Beta 36 on Wine be able to use the full 4Gb RAM? I'm a
> total n00b at Unix. I've installed Pov-Ray 3.6 on Linux via the software
> manager, but I obviously can't get the beta there. I also have yet to
Depends on whether you use the 64-bit version of WINE or not - but it
seems it would be better to use the Linux build, no?
Jim
