POV-Ray : Newsgroups : povray.unix : Compiling PoV-Ray 3.7 under Linux Server Time
26 Mar 2026 16:58:19 EDT (-0400)
  Compiling PoV-Ray 3.7 under Linux (Message 1 to 10 of 35)
Subject: Compiling PoV-Ray 3.7 under Linux
Date: 8 Nov 2011 13:52:20
Message: <4eb97a64$1@news.povray.org>
Hi(gh)!
About two weeks ago, I tried compiling 3.7 under Linux (Debian, kernel
version 2.6)... I soon realized that I would have to install some
ominous "boost" packages. But as nobody could tell me exactly which of
these packages I would have to install, I simply tried apt-get install
boost* - and, promptly, blew my system completely as the system
partition ran full.
After I managed to get the system working once more, I still have no
clue what boost packages to install...
See you in Khyberspace!
Yadgar
Subject: Re: Compiling PoV-Ray 3.7 under Linux
Date: 8 Nov 2011 14:11:06
Message: <4eb97eca@news.povray.org>
> partition ran full.
  I would recommend that if you want to compile your own programs, you
acquire more disk space and install boost using the package manager of
your linux distro (ie. apt-get in your case), rather than trying to
kludge povray to compile with partial boost manual installations. Free
some space of buy a bigger hard disk.
Date: 8 Nov 2011 14:13:34
Message: <4eb97f5e$1@news.povray.org>
See http://povray.org/beta/source/unix-src-INSTALL.txt
Section 2.2, "Required Support Libraries".
Jim
Date: 8 Nov 2011 15:44:47
Message: <4eb994bf@news.povray.org>
Hi(gh)!
Now I downloaded version 1.47 of the boost libaries from www.boost.org,
unpacked it into /usr/local/ and then this:
"To compile anything in Boost, you need a directory containing the
boost/ subdirectory in your #include path."
(http://www.boost.org/doc/libs/1_47_0/more/getting_started/unix-variants.html#get-boost)
What is the #include path? Where do I find it?
Why are these things so brain-shreddingly complicated?
Yadgar
Date: 8 Nov 2011 17:04:19
Message: <4eb9a763$1@news.povray.org>
> Hi(gh)!
> kernel version 2.6)... I soon realized that I would have to install
> some ominous "boost" packages. But as nobody could tell me exactly
> which of these packages I would have to install, I simply tried
> apt-get install boost* - and, promptly, blew my system completely as
> the system partition ran full.
   Here on Ubuntu, I had to install libboost and libboost-dev... I
suppose it should be the same for Debian.
Jaime
Date: 8 Nov 2011 18:02:21
Message: <4eb9b4fd$1@news.povray.org>
> boost/
The path used for #include in *nix is specified with the -I parameter for
the 'make' command or is specified in the Makefile.
"man make" will tell you what you need to know.
Do you often build software on Linux?  If you don't, you might want to
start with a tutorial on how to build software in general before diving
in to build POVray.
Jim
Date: 8 Nov 2011 18:23:43
Message: <4eb9b9ff$1@news.povray.org>
Am 08.11.2011 21:44, schrieb Jörg 'Yadgar' Bleimann:
Seems to be typical for libraries. I have yet to see any that comes with
an easy-to-use build system. Or at least some /standardized/ one, for
that matter. The tendency there seems to be to try make life for the lib
developers as easy as possible by using some home-brewn build system
custom-tailored to their needs, but at the same time making life
annoyingly difficult for application developers (or end users), forcing
them to dig through all those different build systems of the libraries
the app is using.
Okay, maybe I'm exaggerating here. Never mind...
Date: 8 Nov 2011 19:07:03
Message: <4eb9c427$1@news.povray.org>
Hi(gh)!
I only could successfully install libboost-dev - libboost does not exist
on the repositories for my distro (which is Debian aptosid, kernel 2.6.9).
<yaz### [at] gmxde>", firstly all went fine... until configure complained:
configure: error: cannot find a suitable ZLIB library
What went wrong now? Or should I better first compile and install the
whole boost v1.47 package from www.boost.org?
Yadgar
Date: 8 Nov 2011 19:09:18
Message: <4eb9c4ae@news.povray.org>
Hi(gh)!
No - it's the very first time in my life (after one or two early aborted
attempts in the past few years)!
> in to build POVray.
And where do I find such a tutorial (no, I don't believe in Google being
my friend!)?
Yadgar
Date: 8 Nov 2011 19:13:38
Message: <4eb9c5b2$1@news.povray.org>
Hi(gh)!
> the app is using.
I'm about to give up... and remorsefully crawling back into
Micro$lavery! Obviously, it is IMPOSSIBLE for an average DAU (to the
non-German speakers: Most Stupid User To Assume!) to build any software
under Linux!
Yadgar
