POV-Ray : Newsgroups : povray.unix : using both a global and a local .ini file Server Time
14 Jun 2024 22:12:27 EDT (-0400)
  using both a global and a local .ini file (Message 1 to 9 of 9)
Subject: using both a global and a local .ini file
Date: 11 Jun 2009 05:45:23
Message: <4a30d233$1@news.povray.org>
Hi!
I am using povray-3.6.1 on Gentoo. There's a global ini
file /etc/povray/povray.ini containing some Library_Path entries
for the standard libs.
I put some include files that I downloaded or created myself into
%HOME/povray/include and created a local ini file
$HOME/.povray/3.6/povray.ini containing a corresponding Library_Path
entry. When I start povray now, it seems to ignore the global ini file
and only use my local one, thus not finding the standard libraries any
more. Is there a way to tell povray to use the global file first and
then load the local one?
Klaus
Subject: Re: using both a global and a local .ini file
Date: 11 Jun 2009 08:01:30
Message: <4a30f21a@news.povray.org>
Klaus Nowikow wrote:
> Hi!
> Regards,
> Klaus
Why not just put the paths in your local ini?
This is in mine:
Library_Path="/usr/local/share/povray-3.6"
Library_Path="/usr/local/share/povray-3.6/ini"
Library_Path="/usr/local/share/povray-3.6/include"
Library_Path="/home/john/povray/include"
BTW POV doesn't care about repeated library paths
John
"Eppur si muove" - Galileo Galilei
Date: 11 Jun 2009 08:11:13
Message: <4a30f461@news.povray.org>
>> Hi!
>> Regards,
>> Klaus
> This is in mine:
> John
Sorry, forgot to add that POV will search in the order (I quote from the
manual, but the numbering is mine):
1. The place defined by the POVINI environment variable. When you want
to use an INI file at a custom location you can set this environment
variable.
2. ./povray.ini
3. $HOME/.povray/3.6/povray.ini
4. PREFIX/etc/povray/3.6/povray.ini (PREFIX by default is /usr/local)
IIRC having found one file it probably stops searching (I could be wrong)
John
Date: 11 Jun 2009 08:52:24
Message: <4a30fe08@news.povray.org>
I'd rather avoid copying the global ini, because it is not directly
under my control and I'd have to copy it again when it was updated.
But thank you for your suggestion, it is an option if anything else
fails.
> variable.
> 2. ./povray.ini
Yes, that would be consistent with my observations.
Actually, that means that if I had a project-local ini file, I'd also
have to copy my account-local ini file into that one and probably to
adapt it if I move my project to another computer -- possibly with
Windows instead of Linux, where the paths will definitely be different.
I'd rather have POV read all the ini files in the reverse order -- from
most global to most local.
Klaus
Date: 11 Jun 2009 14:20:01
Message: <web.4a314a99f13ccd8c7371b39b0@news.povray.org>
Klaus Nowikow <kla### [at] gmxat> wrote:
> Hi!
Never tried this, but I think a simple
at the beginning of your local .ini file should do the job of invoking the
global one.
Date: 14 Jun 2009 09:58:48
Message: <4a350218$1@news.povray.org>
> global one.
Just tested this. Unfortunately what seems to happen is that POV reads
the global ini but then stops reading any further in your local file :-(
I suppose you could put the line at the _end_ of your local ini but that
would be the opposite of what Klaus is trying to achieve.
One further possibility springs to mind: How about renaming your local
ini file so that POV doesn't automatically read it then referencing it
at the end of your global ini - $HOME/.povray/3.6/local.ini
John
Date: 17 Jun 2009 13:55:01
Message: <web.4a392d9ff13ccd8c7705fe780@news.povray.org>
> > global one.
In that case we have just discovered a bug; quote from documentation, section
2.2.8.2 ("Using INI Files"):
[...] You may nest INI files by simply putting the file name on a line by itself
with no equals sign after it. Nesting may occur up to ten levels deep. For
example:
  ; This is a sample INI file. This entire line is a comment.
  ; Blank lines are permitted.
  Input_File_Name=simple.pov ;This sets the input file name
  +W80 +H60 ; Traditional +/- switches are permitted too
  MOREOPT   ; Read MOREOPT.INI and continue with next line
  +V        ; Another switch
  ; That's all folks!
Date: 18 Jun 2009 13:50:14
Message: <4a3a7e56@news.povray.org>
>>> global one.
> example:
>   +V        ; Another switch
>   ; That's all folks!
I'm going to recheck this later this evening. Results will be posted
here tomorrow
John
Date: 19 Jun 2009 11:33:29
Message: <4a3bafc9$1@news.povray.org>
>>> global one.
> example:
Oops, I missed that statement in the docs. Thanks for pointing me to it.
If that worked it would be exactly what I was looking for.
Klaus
