![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I want to experiment with the pov-mode in Emacs, but am getting an error. I
untarred the three files into /usr/share/emacs/21.2/list/textmodes. I did
not have an .emacs file in my home directory, so I created one whih now
contains only:
(autoload 'pov-mode "pov-mode.el" "PoVray scene file mode" t)
(setq auto-mode-alist
(append '(("\\.pov$" . pov-mode)
("\\.inc$" . pov-mode)
) auto-mode-alist))
(require 'pov-mode)
When I attempt to start Emacs, or when I remove the last line, start Emacs,
and then try to M-x to pov-mode, I get the following error:
Wrong type argument: listp, "/usr/share/emacs/21.2/etc/"
I know that the pov-mode files are in the load path. Emacs does bagin to
load pov-mode before displaying the error. I can switch to perl-mode,
cc-mode, etc. without a problem.
Any help appreciated.
-Shay
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Warp" <war### [at] tag povray org> wrote in message
news:3f5b8678@news.povray.org...
| I don't know if it's of any relevance to your problem,
| but my .emacs has a bit different lines:
Thanks, Warp. Unfortunately, this did not make a difference. I also
tried backing up one of the other .el files, copying the pov-mode.el
body into that file, and then attempting to load it. That didn't work
either.
I am guessing that, since other modes work, and I can find no mention of
this problem here or on Google, this is a bug or incompatibility
specific to this particular version of Emacs. Tonight, I am going to
experiment with commenting out portions of the pov-mode.el file to see
if I can isolate the problem.
-Shay
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Den Sun, 07 Sep 2003 09:21:04 -0500 skrev Shay:
> contains only:
> ) auto-mode-alist))
> (require 'pov-mode)
Hi
I'm using emacs 21.3.1 and does not have this problem. if you enable
"Enter debugger on error" (it should be in the options menu), and then
paste the result here. But first, you should download the latest version
of povmode (I made a mistake while packaging it, and forgot the files
that belong to the insertmenu).
/Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>contains only:
>> ) auto-mode-alist))
>>(require 'pov-mode)
> Hi
> /Peter
I have installed the latest pov-mode.el (Aug 29 2003), and I have the
following message in *Messages* buffer.
File mode specification error: (void-function pov-im-make-menu)
The file mode stays as fundamental-mode. I am using Emacs 20.7.
Thanks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
could not find the answer to this problem. anyone?
emacs 21.2.1 redhat 9
k.
> contains only:
> (append '(("\.pov$" . pov-mode)
> ("\.inc$" . pov-mode)
> ) auto-mode-alist))
> (require 'pov-mode)
> -Shay
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> contains only:
> ) auto-mode-alist))
> (require 'pov-mode)
> -Shay
i use xemacs and have put the pov-mode files under
/home/stephen/.xemacs/modes
i've attached the files i use, had to modify to path of
/home/stephen/.xemacs etc in /home/stephen/.xemacs/custom.el
i'm currently playing with povmode.el and it is now NON standard,
i'm trying to add a local include path /home/stephen/includes
currently the Render button finds the filename of the buffer, and works
High render goes looking for OBJECT.POV, only tried High though
any ideas appreciated
stephen
Download 'us-ascii' (79 KB)
Download 'us-ascii' (4 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
