POV-Ray : Newsgroups : povray.unix : Naming of source file (povuni_s.tgz) Server Time
10 Jun 2026 20:19:02 EDT (-0400)
  Naming of source file (povuni_s.tgz) (Message 1 to 7 of 7)
Subject: Naming of source file (povuni_s.tgz)
Date: 26 Mar 2003 13:24:23
Message: <3e81f057$1@news.povray.org>
Hi!
I recently discovered a (minor) annoyance in regard to the naming of the
source file for UNIX. I'm running Gentoo Linux, which downloads the
source files from the mirrors provided by Gentoo, and when they can't be
found there, it fetches the files from the original site, in this case
www.povray.org. When it has the source files it does an md5 digest to
verify the size and integrity of the file. However, it happily downloads
the file, since it is always called 'povuni_s.tgz' but the digest fails
when there is a new version of the source files up.
  So what I am wondering is if it would be possible to release the
source code with the version number included in the name a la GNU and
many other packages. Something like 'povray-3.50c.tar.gz' would be
sufficient for the build procedure to aqcuire the right files, and leave
the old versions up for a while.
Thanks for a super great software package!
Best regards,
Subject: Re: Naming of source file (povuni_s.tgz)
Date: 26 Mar 2003 13:42:04
Message: <3E81F47B.60207@free.fr>
>  So what I am wondering is if it would be possible to release the source
> code with the version number included in the name a la GNU and many
> other packages. Something like 'povray-3.50c.tar.gz' would be sufficient
	It's been a bit discussed recently under p.programming in the thread
[patch] Suggesting trivial patch (again)
	by Wolfgang Wieser.
	I kinda suspect that this useful filenaming convention won't be used
before a while for *nix releases...Or maybe it's just that I'm in a bad mood
today  ;-)
Date: 26 Mar 2003 17:35:56
Message: <3e822b4c$1@news.povray.org>
>> sufficient
>     by Wolfgang Wieser.
> mood
> today  ;-)
Ah, I see. I read the thread you mentioned, and it seemed to veer off
the whole subject after a while and then got dropped.
   I hope Thorsten Froehlich or anyone else in the POV team reads this
thread also, I don't like crossposting ;-)
   All the while I've been using POV-Ray for many years now, both on
Windows and GNU/Linux, there's always been the annoyance with the naming
of the source file(s). Now, while people download the files manually,
this is not a big or serious problem, since it's easy to rename them.
   But when you depend on md5sums and other means of verification of
downloaded files it just breaks things whenever _anything_, even a
single byte, with the source files change. When scripts are getting
source files in a number of slightly different sizes and versions, but
all with the same name they simply fail, with ensuing confusion for the
users.
   It would be a BIG help to the people out there providing POV-Ray to
users (Gentoo Linux being just one example) if the names of the source
tarballs uniquely identified a particular instance or release of the
source code, even if it's just a minor bugfix, at least for the UNIX
releases.
   It would still be possible, maybe even desirable, to provide the
povuni_s.tgz file for DOS users, a symlink or a plain copy could provide
that name for the latest release to them, if there's still anyone out
there seriously running POV-Ray on DOS.
Thanks
Date: 27 Mar 2003 05:33:48
Message: <3e82d38c$1@news.povray.org>
Well, that is to be expected if the archive changes, isn't it?  So you get
the new archive and use it.  If somebody else creates an md5 of some old
archive, well, that is _their_ problem, so complaining to them is the
appropriate thing to do.  If they want to make POV-Ray available this way
they can just mirror the archive they used; which is nicer anyway as it
reduces povray.org server traffic.
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Mar 2003 06:57:38
Message: <3e82e732@news.povray.org>
I do see your point, and bug reports have been filed to the right
instance in this case (Gentoo bugzilla).
   www.povray.org is used as a 'last resort' for the scripts that
fetches the files. But - the mirrors are always supposed to be current
and they do carry the 'right' release for which the scripts are built.
Problems arise when the downloading fails from the mirrors and
www.povray.org gets used instead. (See
http://bugs.gentoo.org/show_bug.cgi?id=18206 ). Since the name of the
source file is still the same, it gets downloaded but fails the
verification check.
   It just seems that it would be a fairly easy thing provide an aliased
name of the tarball, which would make it more convenient to track
updates and keep both people and automated scripts happy.
   I'll suggest to the Gentoo people that they change the name of the
source file to an unambiguos 'povray-3.50c.tar.gz', but I think it would
be a nice service from the POV team to do this as well. :-)
>     Thorsten
Date: 27 Mar 2003 10:08:28
Message: <3e8313ec@news.povray.org>
To the contrary, because you would then download an outdated version and
never know that a more recent version is available.
    Thorsten
Date: 27 Mar 2003 10:38:58
Message: <3e831b12@news.povray.org>
Well, it's just as difficult to know that now. The only indication you
get in this particular instance is when installation breaks, because of
the reasons outlined above. The POV-Ray 'bug' was discovered two days
ago, when people realized that povray-3.50c was out, but only because of
the installation script failing, but if I am not mistaken it has been
out for a couple of months now?
   IMHO, it's better to have a slightly outdated version in a particular
distribution that _always_ works, then the maintainers of the
distribution specific package can monitor minor releases and bugfixes on
the POV site and releasing a new package with the new version to the
users when they are ready.
   I suppose major releases will have more prominent announcements,
which are easier to track, and does not confuse anyone.
   But even for minor bugfixes, an announcement on the www.povray.org
website when a new source release is available would suffice, or a
message on povray.announce
   People (like me) watches POV-Ray pretty closely, and even if there
are no announcements updates would be discovered anyway.
   Now I understand that you all do this on your free time, and it is
greatly appreciated, but would the POV team please at least take the
aforementioned suggestion under consideration? It would be a big help to
both users and maintainers of distribution packages of POV-Ray for
different platforms?
   And with symlinks, it would be possible to have the best of both worlds!
   I won't bug you anymore, but... can we have it, please? :-)
Humbly,
>     Thorsten
