POV-Ray : Newsgroups : povray.unix : Pyvon 1.3 Server Time
21 Apr 2025 18:20:39 EDT (-0400)
  Pyvon 1.3 (Message 1 to 10 of 14)
Subject: Pyvon 1.3
Date: 28 Jan 2003 13:09:16
Message: <3e36c74c@news.povray.org>
I have uploaded a new release of Pyvon with the numerous changes below.
As there are quite a few changes, there might be problems with previous
versions. If so, just uninstall pyvon or delete the directory
/usr/local/pyvon and reinstall it.
d42 - 28/01/2003 - Pyvon 1.3
'Beautify' the code : Replaced spaces with tabs inside the code
Much remains to be done
Use the Python optimization starting Pyvon -> It should be somewhat faster
d38 - 20/01/2003 - Pyvon 1.3
Added small tips when moving the mouse over the interface
Added the translations for the tips.
Added the names of the translators in the language files and in the help
menu
Show a warning if the +sc or +sr value in the partial render are greater
than the +ec or +er values (Thanks Bonsai!)
d37 - 14/01/2003 - Pyvon 1.3
Changed the structure of the Insert directory
When selecting a font, pyvon searches all the available fonts in the
system and displays them.
A small label shows what the font looks like if you want to apply it in
the editor.
Added an entry in the menu for a pyvon help window
   for the keyboard shortcuts
On the web page, I have also added the mlpov 0.82 binary (HDRI) compiled
on my system. It is dynamically linked.
One more thing :
Thanks to the translators and to the people who just dropped me an email
of encouragments.
http://pyvon.sourceforge.net
Fabien HENON
Subject: Re: Pyvon 1.3
Date: 28 Jan 2003 13:25:18
Message: <3e36cb0e@news.povray.org>
Ooops I used the email of my girl-friend for posting the message above.
> menu
> the editor.
> One more thing :
> of encouragments.
> Fabien HENON
Date: 28 Jan 2003 15:27:53
Message: <3e36e7c9@news.povray.org>
  I don't understand how this "beautifies" the code. If anything, it only
causes problems.
Date: 28 Jan 2003 16:01:31
Message: <3e36efab@news.povray.org>
In article <3e36e7c9@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> causes problems.
All official POV-Ray editors support tabs properly.  Only some people in the
terminal world seem to prefer outdated editors without proper tab support.
Those people need to realize that they are running software that has been
outdated for two decades and that they should really move on.  Tabs are the
future, spaces are a thing of the past many here don't even remember because
they could neither read or write back then...
    Thorsten
e-mail: tho### [at] trfde
Date: 28 Jan 2003 17:47:58
Message: <3e37089e@news.povray.org>
> causes problems.
Indeed you did not understand. I meant I began to beautify the *PYTHON*
code of pyvon. I never wrote that pyvon beautifies pov-ray code.
I should have written : 'Beautified' the pyvon code.
Apart from
- syntax highlighting
- automatic keyword expansion
- highlights of matching braces
- customization of tab lengths (all of which are already supported in pyvon)
I do not see what else I could add to make POV-Ray script more readable.
What I meant by replacing spaces with tabs is that python language is
structured around indentation. Python does not use parentheses,
brackets, semi-colon or keywords to delimit(nest) declaration or tests ie :
if x > y :      # test                            (indentation 0)
       print x   # what to do if the test is true (indentation 1)
       if x > 0: # nested test                    (indentation 1)
            x=x+1# things to do if test is true   (indentation 2)
else:           #                                 (indentation 0)
       print y   # what to do if the test is not true (indentation 1)
d="gfdgds"      # we are out of the test here     (indentation 0)
Both spaces and tabs are accepted in a python script; and when I began
writing pyvon, I used different editors and did not want to bother to
set up the different tab lengths and went for spaces instead. (Lazy me !)
Fabien HENON
Date: 28 Jan 2003 18:06:33
Message: <3e370cf9@news.povray.org>
Entre otras cosas, Céline Castel tuvo a bien escribir:
In my system (somewhat modified RedHat 7.3), the .rpm package complains
about not having python >= 2.2 (which I have: python2-2.2.1-2) and xterm
(which was provided by XFree86-4.2.0-8). So I installed the .gz, but pyvon
didn't start, I went to /usr/local/pyvon and substituted "python" with
"python2" in res.py and pyvon. I remember it was a bit of a mess when I
installed python 2.2, because I had to keep python 1.5 for up2grade, that
could be the culprit. I guess there was a link from python to python2,
which I had to delete for up2grade to work... And then there's xterm.
Anyway, it's a useful tool and I'm glad you made it :)
Ignacio Fernández Galván
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
Date: 28 Jan 2003 20:35:39
Message: <3e372feb@news.povray.org>
> code of pyvon.
  I understood perfectly what you meant, and my question is still valid.
  You are telling about the problems of using tabs instead of spaces. That
is, they cause problems.
  I still don't see how they make the code cleaner or more "beautiful".
Date: 29 Jan 2003 11:10:04
Message: <web.3e37fc26f3d2dd347ff7c9e30@news.povray.org>
Thanks.
Does pyvon work ? Do you have a problem with xterm ?
If you know that you have the proper packages already installed you can try
rpm -ivh --force --replacepkgs the_package_you_want_to_install.rpm
This overrides the error messages and replaces all the installed packages
(if any)
Ok that's not neat but that works when the rpm database can be kept up to
date
Fabien H
Date: 29 Jan 2003 11:12:57
Message: <3E37FCBB.3040206@psico.ch>
>>causes problems.
Tabs do indeed cause problems in some cases.
For example, I use different tab sizes for different
kinds of source files, like size 4 for perl, size 2 for
python and size 8 for others.  These files won't look
very good when loaded into some other (or someone else's)
editor or viewer if I used "real" tabs!
That's just one reason why I'd never use "real tabs" in
*any* editor.
And, the editors I know of handle spaces a lot better!
This includes the povray editor, which IMHO isn't a good
text editor anyway - it's functionality is quite limited.
It can't trim trailing spaces AFAIK, and I hate that mix-
ture of spaces and tabs I'd get after editing a file for
a while, as spaces are never replaced by tabs automatically.
Upon indenting text, another tab is just inserted at the
beginning of the line, and if auto-indentation is on, the
whole indent is copied from the previous line (including
whatever combination of tabs and spaces there are).
(So much about outdated software.. I grew up with emacs
and vi, and they both could (and still can) handle both
spaces and tabs excellently! - Though I don't know if
it was those you had in mind.. ;)
I can't really see one single reason to use tabs in plain
text files. - It would be a completely different story if
you used variable width fonts (or even a word processor;
but then, tabs are handled in a different fashion anyway).
Spaces are unambiguous.
g.
mailto:gim### [at] psicoch
http://www.psico.ch/
http://psico.servehttp.com/
Date: 29 Jan 2003 13:22:03
Message: <3e381bcb@news.povray.org>
>>> causes problems.
>> in the
>> support.
>> are the
>> because
> *any* editor.
And heavy. In some cases in python scripts, if tab sizes are set to 8
(as was my case when I started using Kate), you have to type 8 times on
the space. If you have heavily nested declarations, you have to multiply
that number by the levels of nesting. Imagine what it's like in a 2000+
line script (pyvon)
I did started using spaces instead of tabs because at first I did not
bother setting up tab size on the different editors.
This way I get the same identation inside all the def().
But this is a bit off-topic in here.
Fabien H
> g.
