POV-Ray : Newsgroups : povray.unix : POV-ray 3.5 on PPC : segmentation faults Server Time
10 Jun 2026 20:18:13 EDT (-0400)
  POV-ray 3.5 on PPC : segmentation faults (Message 1 to 9 of 9)
Subject: POV-ray 3.5 on PPC : segmentation faults
Date: 7 Jan 2003 12:02:37
Message: <3e1b082d$1@news.povray.org>
Hi All,
In brief : POV-ray compiles fine, segmentation faults at runtime.
Setup :
PPC 7400 (G4) with
    YellowDog Linux ,
    2.4.20 kernel
    gcc 3.2,
    jpeg-6b,
    libpng-1.2.5,
    tiff-v3.5.7,
    zlib-1.1.4,
    povray-3.50c
Makefile mods :
src/Makefile :
DEFS
= -DPREFIX=\"$(prefix)\" -DPOV_LIB_DIR=\"${prefix}/share/povray-3.5\" -DCOMP
ILER_VER=\".Linux.$(CC)\" -DSYSCONFDIR=\"$(sysconfdir)\" -DUSE_IO_RESTRICTIO
NS=\"$(ac_use_io_restrictions)\" -DX_DISPLAY_MISSING=1
CFLAGS
= -O3 -mcpu=7400 -finline-functions -ffast-math -fomit-frame-pointer -funrol
l-loops -fexpensive-optimizations -foptimize-sibling-calls -Wno-multichar
CXXFLAGS =
$(NOMULTICHAR) -O3 -mcpu=7400  -finline-functions -ffast-math -fomit-frame-p
ointer -funroll-loops -fexpensive-optimizations -foptimize-sibling-calls -Wn
o-multichar
When rendering the abyss demo with :
povray +F -D abyss.pov (slightly adapted, i admit)
i get :
Creating bounding slabs.
Scene contains 44551 frame level objects; 1 infinite.
Creating vista buffer.
Creating light buffers
  -:--:-- Rendering line    1 of  240. Segmentation fault
Subject: Re: POV-ray 3.5 on PPC : segmentation faults
Date: 7 Jan 2003 12:06:03
Message: <3e1b08fb$1@news.povray.org>
Sorry, hit the send button before completing the post.
It should read :
Any help MOSTLY appreciated, thanks !
bye !
Jan Dewerchin
"Jan Dewerchin" <jdw### [at] fabricom-idsbe> wrote in message
news:3e1b082d$1@news.povray.org...
> Hi All,
> Setup :
> PPC 7400 (G4) with
>     YellowDog Linux ,
>     2.4.20 kernel
>     gcc 3.2,
>     jpeg-6b,
>     libpng-1.2.5,
>     tiff-v3.5.7,
>     zlib-1.1.4,
>     povray-3.50c
> Makefile mods :
> src/Makefile :
> DEFS
> CFLAGS
> CXXFLAGS =
> o-multichar
> i get :
Date: 7 Jan 2003 12:40:12
Message: <3e1b10fc@news.povray.org>
One more comment :
I only get this with abyss.pov until now....
strange........
Jan Dewerchin
> Hi All,
> Setup :
> PPC 7400 (G4) with
>     YellowDog Linux ,
>     2.4.20 kernel
>     gcc 3.2,
>     jpeg-6b,
>     libpng-1.2.5,
>     tiff-v3.5.7,
>     zlib-1.1.4,
>     povray-3.50c
> Makefile mods :
> src/Makefile :
> DEFS
> CFLAGS
> CXXFLAGS =
> o-multichar
> i get :
Date: 7 Jan 2003 14:17:31
Message: <3e1b27cb@news.povray.org>
In article <3e1b082d$1@news.povray.org> , "Jan Dewerchin"
> Setup :
> PPC 7400 (G4) with
Do you really have a G4 or did you only compile for it?
    Thorsten
Date: 8 Jan 2003 03:59:42
Message: <3e1be87e$1@news.povray.org>
Hi Thorsten,
It's a Totalimpact Briq G4 with altivec.
(check www.totalimpact.com to see it, if you like)
It's as G4 as a G4 gets, i guess.
I would like to stress that I get this problem ONLY with abyss.pov .
As I am a complete newbie on POV-ray, I was rendering some intresting
scenes,
and abyss.pov was the only one wich gave me trouble until now.
At first I thought it was because I added a clock related camera movement
(360 spin around the sub),
but POV-ray halts whith every imaginable option.
Mind you, the same scene renders just fine with the windows version.
Jan Dewerchin
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3e1b27cb@news.povray.org...
> > Setup :
> > PPC 7400 (G4) with
>     Thorsten
Date: 8 Jan 2003 04:39:14
Message: <3e1bf1c2@news.povray.org>
In article <3e1be87e$1@news.povray.org> , "Jan Dewerchin"
Did you compile all libraries for the G4 as well?
How about using the debugger?  That will reveal where your compile crashes.
Well, that is an official compile and obviously it has been tested with all
sample scenes...
    Thorsten
e-mail: tho### [at] trfde
Date: 8 Jan 2003 08:43:41
Message: <3e1c2b0d@news.povray.org>
Thorsten,
Most likely, the problem lies in one of the external libraries as you
pointed out.
What puzzles me is the fact that apparently, there is a special feature used
in abyss.pov
that isn't used in other scenes. Or perhaps it's the number of objects in
the scene.
The thing I will look into is the fatc that I get loads of warnings like :
bsphere.cpp:516: warning: assignment to `int' from `double'
I'll try to fix this after I recompiled the libs for G4.
Thanks for your comments !
Jan Dewerchin.
news:3e1bf1c2@news.povray.org...
crashes.
all
> sample scenes...
>     Thorsten
Date: 8 Jan 2003 11:08:19
Message: <3e1c4cf3$1@news.povray.org>
Thorsten,
The problem is located here, according to gdb :
#0  0x1009c9a8 in buildsturm (ord=-25, sseq=0x7fffd7b8) at polysolv.cpp:273
273           *fp /= f;
Tracing backwards I found a very strange situation :
#1  0x1009c91c in buildsturm (ord=-25, sseq=0x7fffd7b8) at polysolv.cpp:265
#2  0x1009bb68 in Solve_Polynomial (n=2147473744, c0=0x10100000,
r=0x7fffe0d8,
    sturm=269481264, epsilon=-0) at polysolv.cpp:1674
#3  0x10046b18 in intersect_lathe (Ray=0x7fffe898, Lathe=0x108c6fb0,
    Depth_Stack=0x10302f10) at lathe.cpp:440
look at #2, the value of n (2147473744), where all the calls to
Solve_Polynomial are done with values
2,4 or 6 in the function intersect_lathe. Notice the value of sturm
(269481264). Looks like a pretty serious corruption to me.
It's obvious that the corruption is not caused by a coding error , but by
some compiler setting. I'll try to build without the -mcpu setting.
Any further ideas ?
Jan Dewerchin
crashes.
all
> sample scenes...
>     Thorsten
Date: 8 Jan 2003 12:59:09
Message: <3e1c66ed$1@news.povray.org>
In article <3e1c2b0d@news.povray.org> , "Jan Dewerchin"
Don't worry about those warnings, just turn them off.
    Thorsten
