POV-Ray : Newsgroups : povray.unix : freeBSD without X Server Time
10 Jun 2026 21:28:44 EDT (-0400)
  freeBSD without X (Message 1 to 7 of 7)
Subject: freeBSD without X
Date: 25 Nov 2002 20:20:13
Message: <3de2cc4d$1@news.povray.org>
How can I compile a command line only version of
3.5 for freeBSD 4.7-stable?
I'm experimenting with generating images from
php scripts on a web server and X just doesn't
fit into the schema.
Is this possible?
IIRC, the old DOS versions were command line ...
Is not having the splash screen come up a
show stopper for this use of povray?
Subject: Re: freeBSD without X
Date: 26 Nov 2002 03:55:40
Message: <3de3370c$1@news.povray.org>
"pan" <pan### [at] syixcom> wrote...
> Is this possible?
It seems to me that pov-ray isn't designed to be compiled under all unices.
You'll probably need to edit the generated Makefiles by hand. The install
instructions are very vague unfortunately.
/Daniel
Date: 26 Nov 2002 14:54:35
Message: <3de3d17b$1@news.povray.org>
Try the instructions in the Cygwin thread in this newsgroup.
I can't see why they shouldn't work for *BSD's too.
Dave
Date: 26 Nov 2002 18:45:24
Message: <3de40794$1@news.povray.org>
"David Burnett" <var### [at] ntlworldcom> wrote in message
news:3de3d17b$1@news.povray.org...
> Dave
Thanks,
Tried the cygwin thread suggesstions.
Got a little further, but
gmake stops with 'missing separator' errors in
/src/Makefile
fixed that by adding in the missing {tab} characters, but
gmake still stops with 'no target for' errors
atmosph.Po
 ??? no such file I can find
also DEPDIR doesn't seem to get defined anywhere
am downloading new source just in case I got a bad copy
::frustrating::
Date: 26 Nov 2002 22:55:03
Message: <web.3de4408425f1d1ba4545d010@news.povray.org>
>> Is this possible?
>/Daniel
I've recently installed OpenBSD 3.2 on a 'spare' 100 MHz Pentium.
The packages included with OpenBSD 3.2 include 'povray3.1_NO_X11'
The computer is slow, but I can run povray and copy the images it generates
to the webserver document root, where they can be viewed on a Linux
workstation.
(I don't know if I'd want PHP scripts with execution time measured in days,
however)
John.
Date: 27 Nov 2002 00:25:38
Message: <3de45752$1@news.povray.org>
"pavium" <joh### [at] engineercom> wrote in message
news:web.3de4408425f1d1ba4545d010@news.povray.org...
[snips]
> workstation.
days,
> however)
As it turns out the freeBSD maintainer for the povray package is working
on new Makefile patches right now. The change to 3.50c changes what
needs to be patched.
PHP - scripts - not sure what you mean by 'time measurd in days' ?
A php script needs only to pass a flag that signals the execution
of a script by povray - the script does that and it's done. Other,
separate, scripts collect, collate and insert data into dbs and write
the .pov files.
The renderings I'm thinking of would make simple graphics mostly using
the 3d modelling space that is not available in almost all other
graphics engines. It's either use pov or write endless graphics
primitives in php classes that call on gd.
python and ruby are overkill
gnuplot, various perl routines, etc. are all 2d and wrap graphs in
axes and scales that are not very manipulable.
c/c++ is too much like reinventing the eight blind men who
accosted the elephant ... I just want to flexibly graph some 3d data.
Date: 5 Dec 2002 02:05:09
Message: <web.3deefa6025f1d1ba4545d010@news.povray.org>
>news:web.3de4408425f1d1ba4545d010[at]news.povray.org...
>> workstation.
>days,
>> however)
>the .pov files.
Of course you'd do it that way -- it was more of a rueful comment on
the speed of my computer.
Pavium
