POV-Ray : Newsgroups : povray.unix : Installation script + RPM Server Time
22 Apr 2025 04:03:14 EDT (-0400)
  Installation script + RPM (Message 1 to 8 of 8)
Subject: Installation script + RPM
Date: 16 Sep 2002 17:04:29
Message: <3D8643D1.2080100@caramail.com>
I have uploaded an installation script (for the tar.gz archive) for
Pyvon along with a RPM package for the Mandrake and RED-HAT systems.
Please tell me if you have any problem.
htt://pyvon.sourceforge.net
Fabien H.
Subject: Re: Installation script + RPM
Date: 22 Sep 2002 01:34:09
Message: <3d8d5650@news.povray.org>
> Fabien H.
Hi
I'm using Redhat 7.3 and installed pyvon from the .tgz.  Never used povray
or pyvon before, so this is an experiment.
Redhat installs both python and python2 (installer complains about
dependancies if you try to only install python2).
I found I had to edit res.py with
#!/usr/bin/python2
and edit the os.system line for python2.
Seems to work ok.
How do I get pyvon to save the image?
Or do I have to run povray itself to do that?
thanks
Peter
Date: 22 Sep 2002 18:17:39
Message: <slrnaosfu8.2kl.steve@zeropps.org.uk>
For the install script the instructions should say that you need to be
root to run the script.  Apart from that it seems to work great.
On running Pyvon the line at the bottom that allows you to add paramaters
such as output file is bunched up against the main editing window so that
it can't be seen, hence the question from the other user about saving
the image file.  Why do you change defaults from what they are in the
.povrayrc file?  Pyvon sets a default of no output file and overrides
the local POV configuration.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 22 Sep 2002 18:17:40
Message: <slrnaosgas.2kl.steve@zeropps.org.uk>
On Sun, 22 Sep 2002 17:33:59 +1200, Peter wrote:
> Hi
> #!/usr/bin/python2
> Seems to work ok.
Hi Peter, you need to take the mouse pointer right to the botom of the
main Pyvon window and hold the pointer over the border and pull it down,
then a new input line will become visible entitled paramaters, you can
specify the output file here, eg adding:
-o money.ppm
But there seems to be some other problems too, like it wont find the POV
executable for a second render even after restarting Pyvon and reselecting
the executable.
                                             or http://start.at/zero-pps
 11:10pm  up 87 days,  9:36,  3 users,  load average: 1.04, 1.08, 1.11
Date: 23 Sep 2002 00:02:19
Message: <3d8e924a@news.povray.org>
> -o money.ppm
> the executable.
thanks - I'm completely new to povray & 3D stuff.
I haven't had your problem though, for me pyvon does repeated renders on
different files, different resolutions, etc.  Appears ok.
cheers
Peter
Date: 28 Sep 2002 10:14:24
Message: <3D95B862.3010807@caramail.com>
>>Hi
>>#!/usr/bin/python2
>>Seems to work ok.
For the command line that disappears, I still have to do some debugging.
> -o money.ppm
> the executable.
What do you have in the pyvonrc file in your home directory ?
When you exit from pyvon, it stores in pyvonrc the location of the pov
executable. I'll double-check if I did not comment out that line.
You have to be root to install it, but a normal user to use it.
Date: 28 Sep 2002 10:25:50
Message: <3D95BAFE.70703@caramail.com>
> the image file.
I have to rewrite the interface to place properly the widgets, so that
the command line parameters entry is not hidden when you change the font
size.
> ..povrayrc file?  Pyvon sets a default of no output file and overrides
I had to add a default command line in case Pyvon does not find any
pyvonrc file ( That's what happens when it is run for the first time).
This prevents the user from getting an error.
I am going to replace the -f by a mere space.
Date: 30 Sep 2002 13:03:51
Message: <slrnapg48n.so5.steve@zeropps.org.uk>
That sounds much better.
  9:53am  up 94 days, 20:19,  2 users,  load average: 1.00, 1.00, 1.00
