POV-Ray : Newsgroups : povray.text.scene-files : L*C*h(uv) functions Server Time
13 Sep 2025 17:11:09 EDT (-0400)
  L*C*h(uv) functions (Message 1 to 10 of 26)
Subject: L*C*h(uv) functions
Date: 21 Nov 2016 12:33:04
Message: <58332fd0@news.povray.org>
Here are the L*C*h(uv) functions I created. How do I turn them into
pigments?
Mike
Download 'cielch_color_solid_cylinder_iso.pov.txt' (5 KB)
Subject: Re: L*C*h(uv) functions
Date: 21 Nov 2016 15:05:00
Message: <web.583352ca926db0d9c437ac910@news.povray.org>
> pigments?
> Mike
http://www.povray.org/documentation/view/3.6.1/378/
Date: 21 Nov 2016 15:10:06
Message: <5833549e$1@news.povray.org>
>> pigments?
>> Mike
I have three separate functions for R, G and B.
#declare convertLCH2RGB_R = function(L,C,H)
{correctRGB1(funcXYZ2RGBb1(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb2(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb3(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))))}
#declare convertLCH2RGB_G = function(L,C,H)
{correctRGB2(funcXYZ2RGBb1(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb2(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb3(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))))}
#declare convertLCH2RGB_B = function(L,C,H)
{correctRGB3(funcXYZ2RGBb1(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb2(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))),funcXYZ2RGBb3(funcLAB2XYZb1(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb2(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H)),funcLAB2XYZb3(funcLCH2LABa1(L,C,H),funcLCH2LABa2(L,C,H),funcLCH2LABa3(L,C,H))))}
Actually, I can create a pigment already. But I don't know how to use
the functions in a isosurface or a parametric to make the 3D object the
pigment gets applied to, if possible.
Mike
Date: 21 Nov 2016 15:15:02
Message: <web.58335567926db0d9c437ac910@news.povray.org>
Mike,
FYI:
you define
#local VRGB = <funcXYZ2RGBb1(VXYZ.x,VXYZ.y,VXYZ.z),
funcXYZ2RGBb2(VXYZ.x,VXYZ.y,VXYZ.z), funcXYZ2RGBb3(VXYZ.x,VXYZ.y,VXYZ.z)>;
and then (re)define the same variable in the very next line:
#local VRGB = <funcRGB2RGBa1(VRGB.x,VRGB.y,VRGB.z),
funcRGB2RGBa2(VRGB.x,VRGB.y,VRGB.z), funcRGB2RGBa3(VRGB.x,VRGB.y,VRGB.z)>;
Date: 21 Nov 2016 15:28:05
Message: <583358d5$1@news.povray.org>
On 11/21/2016 3:13 PM, Bald Eagle wrote:
> Mike,
> FYI:
> you define
The second function takes RGB as input and outputs RGB as well, so I
didn't rename the variable. You can change the variable name if that
suits you.
Mike
Date: 21 Nov 2016 15:29:23
Message: <58335923$1@news.povray.org>
>>> pigments?
>>> Mike
> Mike
Oops! You'll need to know these as well.
#declare correctRGB1 = function(R,G,B) {min(max(R,0),1)}
#declare correctRGB2 = function(R,G,B) {min(max(G,0),1)}
#declare correctRGB3 = function(R,G,B) {min(max(B,0),1)}
Date: 21 Nov 2016 15:57:01
Message: <58335f9d$1@news.povray.org>
>>>> pigments?
>>>> Mike
>> Mike
That is wrong. The RGB values should *not* be corrected. In fact, if any
of R, G or B are outside the range of 0 to 1, then the coordinate/color
should be discarded. Sorry!
Mike
Date: 21 Nov 2016 16:23:44
Message: <583365e0$1@news.povray.org>
Am 21.11.2016 um 21:56 schrieb Mike Horvath:
>>> Mike
So if I understand you correctly, the shape you want is exactly the
volume for which R, G and B are all within the range from 0 to 1.
That sounds like a job for an isosurface to me.
Variant A: Create six isosurfaces, each representing one of the
boundaries (R<0, G<0, B<0, R>1, G>1, B>1), and intersect them.
Variant B: Refactor the functions from variant A, so that they have the
same threshold, combine them using max() or min() to achieve the
intersection effect, and turn that into a single isosurface.
Date: 21 Nov 2016 16:33:30
Message: <5833682a$1@news.povray.org>
>>>> Mike
Yes, exactly!
I don't know how to do either variant. :(
Mike
Date: 21 Nov 2016 16:49:44
Message: <58336bf8$1@news.povray.org>
>> same threshold,
How to cook a haggis:
First catch your Haggis then...
Don't ya just love it when someone says "Simply..." ;)
Regards
