POV-Ray : Newsgroups : povray.text.scene-files : Impossible cube Server Time
29 Aug 2025 09:11:03 EDT (-0400)
  Impossible cube (Message 1 to 10 of 11)
Subject: Impossible cube
Date: 10 Nov 2012 02:22:38
Message: <509e00be$1@news.povray.org>
Here's the source.
Enjoy.
Ger
Download 'us-ascii' (11 KB) Download 'us-ascii' (1 KB)
Subject: Re: Impossible cube
Date: 13 Nov 2012 12:25:00
Message: <web.50a2822f545ec1bdd710adaf0@news.povray.org>
Ger <ger### [at] gmailcom> wrote:
> Here's the source.
> Enjoy.
> Ger
Hello Ger,
Thanks a lot for your help but then again this is rendering code. How to I
generate an animation for this? Will I need an .ini file?
Alex
Date: 13 Nov 2012 12:41:16
Message: <50a2863c$1@news.povray.org>
>> Here's the source.
>> Enjoy.
>> Ger
> Hello Ger,
> Alex
There should be 2 files attached to the post, one is the cube source, the
other the ini file.
Ger
Date: 13 Nov 2012 12:50:00
Message: <web.50a287be545ec1bdd710adaf0@news.povray.org>
> >> Here's the source.
> >> Enjoy.
> >> Ger
> > Hello Ger,
> > Alex
> other the ini file.
> Ger
nah unfortunately they both are the same file :P
But I am now using:
; POV-Ray animation ini file
Antialias=Off
Antialias_Threshold=0.1
Antialias_Depth=2
Input_File_Name="transpAttempt2.pov"
Initial_Frame=1
Final_Frame=300
Initial_Clock=0
Final_Clock=3
Cyclic_Animation=on
Pause_when_Done=off
in an .ini file I made at I'm computing the bmp files at the moment. If you want
you can just verify I'm using the right code in my ini file. But so far the
result seems to be fine ;)
Date: 13 Nov 2012 13:04:00
Message: <50a28b90$1@news.povray.org>
>> >> Here's the source.
>> >> Enjoy.
>> >> Ger
>> > Hello Ger,
>> > to I generate an animation for this? Will I need an .ini file?
>> > Alex
>> other the ini file.
>> Ger
> But I am now using:
> Antialias=Off
> Antialias_Depth=2
> Initial_Frame=1
> Final_Frame=300
> Initial_Clock=0
> Final_Clock=3
> Cyclic_Animation=on
> Pause_when_Done=off
> you want you can just verify I'm using the right code in my ini file. But
> so far the result seems to be fine ;)
I just checked and there was a second file attached called "cube.ini"
Running that will create a 720 frame animation. Btw, clock is not used, just
frame_number count.
Ger
Date: 13 Nov 2012 13:15:00
Message: <web.50a28d04545ec1bdd710adaf0@news.povray.org>
> >> >> Here's the source.
> >> >> Enjoy.
> >> >> Ger
> >> > Hello Ger,
> >> > Alex
> >> other the ini file.
> >> Ger
> > But I am now using:
> > Antialias=Off
> > Antialias_Depth=2
> > Initial_Frame=1
> > Final_Frame=300
> > Initial_Clock=0
> > Final_Clock=3
> > Cyclic_Animation=on
> > Pause_when_Done=off
> frame_number count.
> Ger
This thread has two files named:
Your other thread holds an attachment called:
Download 'cube-hd480.mkv.dat' (2667 KB)
Date: 13 Nov 2012 13:28:53
Message: <50a29165$1@news.povray.org>
>> >> >> Here's the source.
>> >> >> Enjoy.
>> >> >> Ger
>> >> > Hello Ger,
>> >> > How to I generate an animation for this? Will I need an .ini file?
>> >> > Alex
>> >> the other the ini file.
>> >> Ger
>> > But I am now using:
>> > Antialias=Off
>> > Antialias_Depth=2
>> > Initial_Frame=1
>> > Final_Frame=300
>> > Initial_Clock=0
>> > Final_Clock=3
>> > Cyclic_Animation=on
>> > Pause_when_Done=off
>> > But so far the result seems to be fine ;)
>> just frame_number count.
>> Ger
The 11KB file is the source, the 1KB file is the ini. The mkv file is a full
blown animation of the cube.
Ger
Date: 13 Nov 2012 13:35:00
Message: <web.50a292c4545ec1bdd710adaf0@news.povray.org>
> Ger
Yes i figured that, but if you check, you have the pov source in both the files!
Date: 13 Nov 2012 13:40:36
Message: <50a29424$1@news.povray.org>
>> full blown animation of the cube.
>> Ger
> files!
Hmmm, must be a case of news reader mess-up.
Ger
Date: 13 Nov 2012 14:09:35
Message: <50a29aef$1@news.povray.org>
Yes, in Thunderbird I see cube.pov and cube.ini
Regards
