POV-Ray : Newsgroups : povray.programming : Making Light... Not act like light.... Server Time
10 Nov 2025 19:38:06 EST (-0500)
  Making Light... Not act like light.... (Message 1 to 9 of 9)
Subject: Making Light... Not act like light....
Date: 27 Jan 2010 16:45:00
Message: <web.4b60b2eeb47724fb7c20afef0@news.povray.org>
Hello Everyone,
A math teacher at my college wishes to run experiments in which he can see how
light behaves under unusual circumstances. I assume it has something to do with
quantum mechanics, string theory, and a slew of other things that I do not
understand.
He wants to be able to enter a mathematical formula into a
ray-tracing program, but make each ray of light behave according to the formula.
While the math of the subject is beyond me, I am a semi-decent programmer.  As
such, I have two questions.
1. Is POV-Ray even capable of something like this?
2. If it is, where should I start in the code? Which class controls how a ray of
light moves?
Thanks for any answers!
Subject: Re: Making Light... Not act like light....
Date: 27 Jan 2010 17:27:24
Message: <4b60bdcc$1@news.povray.org>
You might take a look at the modification done by
Leo Brevin for an older version (3.5) to adapt the
ray calculations for special relativity:
http://users.monash.edu.au/~leo/research/movies/sr/sr-wmv.html
Date: 27 Jan 2010 18:45:00
Message: <web.4b60cfdaab4ee311c2cad8f80@news.povray.org>
> light moves?
rays don't move in povray, they're just traced.  I'd look into
source/backend/render/trace.cpp first.
Date: 28 Jan 2010 04:02:02
Message: <4b61528a$1@news.povray.org>
> formula.
If you want the "light rays" to travel in anything other than straight lines
then you're going to have a *really* big job, as pretty much everything in
POV assumes this.  You would have to rewrite all the intersection code to
test for intersections between the shape and an arbitrary curved ray!  Plus,
AIUI, POV applies the inverse of any shape transforms (scale, rotate, move
etc) to the ray and then does the intersection, you'd need to work out how
to apply the inverse transforms to your curved ray.
TBH it might be easier to start from scratch without assuming straight rays!
Date: 29 Jan 2010 00:16:56
Message: <4b626f48$1@news.povray.org>
>> the formula.
> lines then you're going to have a *really* big job, as pretty much
> everything in POV assumes this. You would have to rewrite all the
> intersection code to test for intersections between the shape and an
> arbitrary curved ray! Plus, AIUI, POV applies the inverse of any shape
> transforms (scale, rotate, move etc) to the ray and then does the
> intersection, you'd need to work out how to apply the inverse transforms
> to your curved ray.
> rays!
Hmm. Actually, I had an odd thought a while back. Not variable
"internal" ior, like some people would love to see, but variable surface
ior. Use a map, just like a texture, bozo, etc., and perturb the angle
of entry and exit, based on the variability of the pattern. Yeah, yeah,
you could "sort of" do this by changing the shape of the object, but
that isn't always optimal for some applications I can think of (such as
if you where making a texture to use in something else, maybe). But, I
do wonder what the result would end up looking like.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 31 Jan 2010 13:02:20
Message: <4b65c5ac@news.povray.org>
I believe that was already possible, back when ior was part of the texture
block. Then POV-Ray added the new "interior" block which cannot be used in a
pattern.
Date: 10 Feb 2010 16:35:01
Message: <web.4b73258dab4ee311568aa1010@news.povray.org>
Thanks to everybody for their input. I will have to think on this some more.
Date: 13 Feb 2010 16:30:48
Message: <4b771a08$1@news.povray.org>
> a pattern.
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_30
Date: 13 Feb 2010 21:12:45
Message: <4b775c1d$1@news.povray.org>
>> a pattern.
Hmm. Couldn't you do a limited sort of this. Like.. use a pattern with a
known mathematical "shape", for the density, then computer where the ray
should end up, based on a computed curve, based on that pattern? It
wouldn't be perfect, obviously, but... for those patterns that could be
calculated in such a manner, it could come close. Mind, this is just
guessing...
void main () {
   else
