POV-Ray : Newsgroups : povray.programming : POV-Ray as WASM module Server Time
31 May 2026 04:49:54 EDT (-0400)
  POV-Ray as WASM module (Message 1 to 10 of 10)
Subject: POV-Ray as WASM module
Date: 9 Nov 2025 20:01:32
Message: <6911396c$1@news.povray.org>
I have an idea how to combine web interface and ray tracing calculations
using the WASM technology:
https://webassembly.org/. With a WASM it will be possible to use POV-Ray
API from Javascript/Typescript and the scene can be stored in JSON
format.
Having raytracing right inside the browser will open the way for
creating online editor with many pleasant features, such as spline
editor, for example:
https://threejs.org/examples/?q=spline#webgl_geometry_spline_editor
I know this assumes a huge amount of work and before diving into this
inferno, I would like to ask you about possible approaches to start
with. If I understand well from reading previous posts about related
refactoring, the main problem is separating a scene description and
tracing parts from the parser.
Could you please point me to the modules I should examine first of all
to create a work plan ?
YB
Subject: Re: POV-Ray as WASM module
Date: 10 Nov 2025 13:40:00
Message: <web.6912311dd8d72d8f7f81dbac25979125@news.povray.org>
> format.
> YB
Thank you, Sergei.
I'm really glad that you joined us and are also thinking about these things -
and DOING them.
I had one of the demonic AI's look it over and give me its summary, because
blindly picking my way through tens of thousands of lines of opaque code was
beyond my present capabilities.
https://news.povray.org/povray.pov4.discussion.general/thread/%3Cweb.6900faee20e0e8051af05c025979125%40news.povray.org%
3E/
(I can keep hammering on this, is we think we can assemble the breadcrumbs it
drops into a map...)
I know that Chris Cason mentioned that he had some plans of his own, so maybe he
might chime in on this.
If there's some way to scan through the old newsgroup posts to get a summary of
what clipka said about disentangling the parser from the raytracer, then that's
an avenue I'd explore as well.  I think Jim Henderson has some sort of fu that
applies in that area.
- BW
Date: 10 Nov 2025 14:30:00
Message: <web.69123ce7d8d72d8f7f81dbac25979125@news.povray.org>
"Can you identify where parsing, scene description, and raytracing get
interwined in the povray source code https://github.com/POV-Ray/povray and
suggest methods to separate them?"
Here's how parsing, scene description, and raytracing are intertwined in the
POV-Ray codebase, along with suggestions for separating them into cleaner,
modular layers:
## 📦 Where Parsing, Scene Description & Raytracing Intersect
### 1. **Parsing Initiates Scene Construction**
- The parsing pipeline is implemented in **source/parser/**:
  - `scanner.cpp` and `rawtokenizer.cpp` handle **lexical analysis**,
  - `parser.cpp`, `parser_expressions.cpp`, etc., build a detailed **scene
representation** (objects, materials, lights, cameras) in memory .
### 2. **Parser Pulls in Raytracing Code**
- `parser.cpp` directly includes raytracing and rendering headers like:
  ```cpp
  #include "core/lighting/lightsource.h"
  #include "core/bounding/boundingsphere.h"
  This indicates parsing is aware of and uses classes from the core rendering
engine .
### 3. **Scene Graph & Core Raytracing Tied Together**
- As parser builds the scene graph (objects, primitives), it instantiates core
structures like light sources and bounds, which are immediately used by the
raytracer.
- This blending makes it hard to swap or reuse the scene representation
independently of rendering.
## 🛠 Suggestions for Modular Separation
### A. **Isolate Parsing into a Dedicated API Layer**
- Extract parsing into a standalone module exposing a clean interface, e.g.:
  ```cpp
  Scene *ParseScene(const std::string &filename);
- Internally use parser/scanner/tokenizer, but externally depend only on a
minimal scene structure.
rendering abstractions.
- Adapt parser to build this neutral graph.
- Develop adapter layers to feed core raytracer components from this graph.
### C. **Use Adapter Patterns to Insert Decoupling Layers**
1. **Parser → SceneGraph Adapter**
   - Parser outputs SceneGraph objects, not `core::lightsource`.
2. **SceneGraph → Raytracer Adapter**
   - Convert graph nodes into permanent raytracer types within a separate
module.
   - Benefits: easier to reuse graph for other backends (e.g. viewport preview,
real-time path tracing).
### D. **Decouple Symbol Table & Expression Evaluation**
- Implement two roles:
  - **Compile-time AST** building,
  - **Runtime evaluator** invoked during rendering, possibly embedded in scene
description rather than renderer.
### E. **Refactor Code Responsibilities**
- Maintain clear boundaries:
  - **Parser module**: handles parsing, tokenization, AST building.
  - **Scene builder**: constructs neutral scene graph.
  - **Raytracer**: consumes scene graph for rendering.
- Requires removal of `#include` dependencies in parser on core/light and
bounding headers.
## ✅ Summary of Actions
| Layer             | Responsibilities                               | Proposed
Refactoring |
| **Parser**        | Lexing, parsing, AST construction              | Outputs
to SceneGraph interface |
| **SceneGraph**   | Neutral representation of objects and settings | No
rendering dependencies |
| **Adapters**     | Convert SceneGraph to Core types              | One
directional mapping layer |
| **Raytracer**    | Rendering based on core objects               | Independent
from parser |
This structure isolates parsing, scene representation, and raytracing into
Date: 10 Nov 2025 14:35:00
Message: <web.69123e2fd8d72d8f7f81dbac25979125@news.povray.org>
No idea if any of this mechanical parroting will make any sense or yield fruit,
but I have a little time before heading out for the night.
"Show a code sketch of the decoupling and Suggest tests for each module"
raytracer in POV-Ray, followed by test suggestions for each module.
Code Sketch: Modular Decoupling
1. SceneGraph Module (Neutral Representation)
// scenegraph/Scene.h
#pragma once
#include <vector>
#include <memory>
#include "Object.h"
#include "Camera.h"
#include "Light.h"
class Scene {
public:
    std::vector<std::shared_ptr<Object>> objects;
    std::vector<std::shared_ptr<Light>> lights;
    std::shared_ptr<Camera> camera;
    void AddObject(std::shared_ptr<Object> obj);
    void AddLight(std::shared_ptr<Light> light);
    void SetCamera(std::shared_ptr<Camera> cam);
2. Parser Module (No Rendering Dependencies)
// parser/SceneParser.h
#pragma once
#include <string>
#include "../scenegraph/Scene.h"
class SceneParser {
public:
    static std::shared_ptr<Scene> ParseFromFile(const std::string& filename);
3. Adapter Module (SceneGraph → Core Raytracer)
// adapter/SceneAdapter.h
#pragma once
#include "../core/RenderScene.h"
class SceneAdapter {
public:
    static std::shared_ptr<RenderScene> ConvertToRenderScene(const
std::shared_ptr<Scene>& scene);
4. Raytracer Module (No Parser Dependencies)
// core/RenderScene.h
#pragma once
#include <vector>
#include "RenderableObject.h"
#include "LightSource.h"
#include "Camera.h"
class RenderScene {
public:
    std::vector<RenderableObject> renderables;
    std::vector<LightSource> lights;
    Camera camera;
    void Render();
 Suggested Tests for Each Module
🔹 Parser Module
Unit Tests
Parse valid scene file → returns correct SceneGraph structure.
Parse invalid syntax → throws descriptive error.
Parse edge cases (empty file, nested macros, etc.).
Mock Tests
Mock file input and assert SceneGraph output structure.
🔹 SceneGraph Module
Unit Tests
Add/remove objects and lights.
Validate camera assignment.
Ensure deep copies or shared_ptrs behave correctly.
Integration Tests
Construct a Scene manually and verify structure.
🔹 Adapter Module
Unit Tests
Convert SceneGraph with known contents → RenderScene with expected
renderables.
Handle missing camera or lights gracefully.
Mock Tests
Mock SceneGraph and assert correct RenderScene output.
🔹 Raytracer Module
Unit Tests
RenderScene::Render() with minimal scene → produces image buffer.
Test bounding volume hierarchy, intersection logic, shading.
Performance Tests
Render large scenes and measure frame time.
Date: 10 Nov 2025 14:45:00
Message: <web.69123fe2d8d72d8f7f81dbac25979125@news.povray.org>
can you compare the structure of povray's source code to that of other
raytracers and summarize the similarities and differences that might inspire a
concrete plan for refactoring povray's codebase to separate the parser from the
other raytracing functions?
Copilot said:
insights can directly guide a concrete refactor plan to cleanly separate parsing
from rendering responsibilities in POV‑Ray.
🧭 POV‑Ray Architecture
Monolithic structure: Parser, scene, and renderer modules are tightly interwoven
under source/, with parser directly including core renderer headers.
github
+1
Parser builds "final" core objects: Scene description parser creates instances
like core::lightsource, boundingsphere, etc., effectively merging parsing and
rendering payload construction.
github
+1
No abstract scene interface: There is no neutral, shared representation (scene
renderer-specific structures.
🧱 PBRT (Physically Based Rendering Toolkit)
Clear parser-render separation:
parser.cpp reads scene files and invokes methods in a ParserTarget interface.
pbr-book
+1
BasicSceneBuilder, implementing ParserTarget, translates parsing events into a
neutral scene format, independent of rendering.
pbr-book
Modular architecture:
Parsing → abstract operations → scene builder → later delivery
to rendering engine.
The rendering system consumes scene data only through this abstract interface.
Advantages:
Dramatically easier to test parsing separately.
Enables preview tools, scene validation, and modular pipeline extensibility.
⚙️ LuxCoreRender
Explicit modular structure:
luxparser/: scene description parser module.
slg/: scene layout generator (scene object assembly).
luxrays/: low-level raytracing engine.
luxcore/: high-level API layering.
deepwiki
+2
Strict role separation:
Parsers feed into scene structure objects.
Raytracer consumes the high-level scene structure without any parser
dependencies.
Interfaces provide clear boundaries and prevent coupling.
Benefits:
Enables multiple front-ends (e.g., Blender exporter).
Clean CI with parser tests, unit tests, and renderer benchmarks.
📊 Comparison Overview
Feature POV‑Ray PBRT LuxCoreRender
Parser + Renderer coupling Tight (direct includes) ✅ Loose via
ParserTarget interface ✅ Loose via scene modules
scene builder ✅ Yes, slg layer
modular
API, exporter
🔧 Concrete Recommendations for POV‑Ray Refactoring
Extract ParserTarget-like interface:
Define abstract methods (Shape(), Light(), Camera(), etc.) instead of
constructing core objects directly.
Introduce SceneBuilder layer:
Implement new SceneBuilder that receives parser events and constructs an
intermediate, neutral graph (objects, lights, cameras).
Create Core-Adapter layer:
Convert SceneBuilder output into core:: rendering types such as LightingSource,
RenderableObject, etc.
Decouple parser from core headers:
parser/ should only include parser and scenebuilder headers; it must not depend
on core/.
Refactor core/ to consume only neutral scene format:
Move all rendering initialization to accept the neutral structure.
Modular testing strategy:
Parser: syntactic/semantic SDL tests invoking parser against various inputs.
SceneBuilder: tests checking neutral graph correctness.
Adapter: verifying translation to renderer types.
Renderer: test rendering of minimal scenes and scene consistency semantics.
✅ Steering Toward a Targeted Refactor
Initial step: define the IParserTarget interface for parser outputs.
Next: build SceneBuilder implementing this interface to collect parsed elements.
Then: implement an adapter to convert to core types.
Finally: adjust core renderer to consume adapter-produced objects, removing all
SDL-specific includes from core/.
independence, modularity, testability, and flexibility for future front-ends.
Date: 10 Nov 2025 15:05:00
Message: <web.69124338d8d72d8f7f81dbac25979125@news.povray.org>
When I was actively working on reproducing Steven Marschner's
"Simulating the structure and texture of solid wood", I noticed that he used
the Mitsuba renderer.
https://www.mitsuba-renderer.org/
So, it seemed to me that if it was easy for his team to add the custom BRDF's
and other parts of the wood texture to the renderer, then that would be
something we'd be seriously interested in drawing inspiration from.
Now, granted, the AI word-soup is awash with generalities, however coupled with
the Mitsuba github repository, it might give us concrete ideas about some
actionable plans for refactoring POV-Ray.
"can you provide an overview of how the mitsuba renderer works?
https://github.com/mitsuba-renderer/mitsuba3 "
architecture and core systems:
## 🏗️ High-Level Architecture
**Mitsuba 3** is a modular, research-oriented renderer implemented in C++17,
centered around the **Dr.Jit** Just-In-Time (JIT) compiler. It supports multiple
### Key Components:
- **Core System**: Fundamental math types, structures, utilities.
- **Build System**: Manages plugins and selectable variants via CMake .
- **Plugins**: Encapsulate BSDFs, shapes, emitters, sensors, integrators.
- **Python Bindings**: Full-featured Python interface and JIT compilation,
enabling dynamic scripting and differentiability .
## 🌳 Scene Representation
The **Scene** class serves as a unified container for geometry, materials,
emitters, sensors, media, and their acceleration structures .
### Responsibilities:
- Hosts collections of shapes, emitters, sensors, media.
- Functions for ray intersection and visibility testing:
  - `ray_intersect()`, `ray_test()`, and `ray_intersect_preliminary()` for
different use cases .
- Works with multiple acceleration backends (CPU KD-tree, Embree; GPU OptiX) .
## 🔦 Rendering Pipeline
The core rendering workflow comprises the following:
1. **Integration**: Integrators perform Monte Carlo sampling and solve light
transport.
2. **Sampling & Ray Generation**: Samplers and sensors generate rays through
pixels.
3. **Ray Tracing**: Ray-scene intersections via the Scene class.
4. **Shading**: BSDFs handle surface-material responses; emitters add radiance.
5. **Accumulation**: Results are aggregated in a Film/ImageBlock and
post-processed .
### Notable Integrator Types:
- `PathIntegrator`, `VolumetricPathIntegrator`, `DirectIntegrator`,
`AOVIntegrator`, etc. .
## 🛰️ Ray Tracing Subsystem
- The **Scene** class provides core intersection queries:
  - Full surface interactions (`SurfaceInteraction3f`).
  - Visibility-only checks (`ray_test()`).
  - Preliminary intersection data (`PreliminaryIntersection3f`) .
- Supports SIMD/vectorized execution and mask-based coherence for performance .
## 🧩 Plugin & Variant System
- **Plugins** cover a wide array of BSDFs, media, sensors, etc., each separately
compiled.
- **Variants** enable multiple execution modes: CPU vs. GPU, RGB vs. spectral,
differentiable rendering, etc. .
## ✅ Summary Diagram
```text
[Dr.Jit Variant System]
  │Parser & │        │Plugins     │
  │Scene    │── feeds → BSDFs,     │
  │System   │        │Shapes,      │
      │Emitters,    │
        │            │Sensors, etc.
[Compose Scene Object: geometry, materials, lights, cameras, media]
[Scene: acceleration + intersection API]
Integrators + Samplers + Sensors
      [Ray Tracing]
    [Shading & Sampling]
     [Rendering Output]
Film/ImageBlock → Image File
## 💡 Why it Inspires Refactoring
- **Clear modularization**: Core scene, plugins, and rendering separated.
- **Abstraction layer**: Normalized scene description before processing.
- **Extensibility**: Plugins and variants enable flexible composition.
1. Introduce **variant/backend system** for flexibility (CPU/GPU, plain vs.
differentiable).
2. Separate **scene representation** from raytracing entirely.
3. Organize features as **plugins**, e.g. SDL parser, BSDFs, shapes,
integrators.
4. Provide **clear interfaces** between parsing, scene assembly, raytracing, and
image output.
This modular, plugin-centric organization combined with variant-based
flexibility makes Mitsuba 3 a strong reference model.
Date: 10 Nov 2025 23:13:25
Message: <6912b7e5@news.povray.org>
On 10/11/2025 21:38, Bald Eagle wrote:
> Thank you, Sergei.
> and DOING them.
Well, but before doing something I am prefer thinking :).
Thanks, Bill, for sharing the results of your experiments with AI, but
unfortunately they will not help us anyway. Code is too complicated
for AI at present time besides the noise it can not give us anything.
Let's wait 10-20 years, and then maybe ...
The main question for me now is it worth to mess with ray tracing, while
we have WebGL/WebGPU now that's enough for most tasks ?
I guess POV-Ray is very good for math experiments, like fractal
rendering, blobs interactions, etc. to produce unusual effects
and artifacts (attached) that can be treated as modern art. The same
thing are possible with other instruments, but most of them use
Python, which I don't like.
YB
Download 'art4.png' (219 KB)
Preview of image 'art4.png'
Date: 12 Nov 2025 12:55:00
Message: <web.6914c8e2d8d72d8f76d02faa25979125@news.povray.org>
yesbird wrote:
 The same
Yeah - I didn't like Python much when I had to use it for something.
What do you think of this:
https://netbeans.apache.org/tutorial/main/tutorials/nbm-povray-1/
Date: 13 Nov 2025 09:17:36
Message: <6915e880$1@news.povray.org>
Honestly, I think that both are outdated - Net Beans and Pov-ray :).
YB
Date: 13 Nov 2025 11:40:45
Message: <69160a0d$1@news.povray.org>
On 12/11/2025 18:50, Bald Eagle wrote:
> yesbird wrote:
>   The same
I respect everyone's choice, but Python is a very unpleasant language.
Hum... what a complicated factory!
kurtz le pirate
compagnie de la banquise
