POV-Ray : Newsgroups : povray.programming : qtpovray and debian Server Time
26 Apr 2024 05:39:52 EDT (-0400)
  qtpovray and debian (Message 1 to 10 of 38)
Subject: qtpovray and debian
Date: 22 Jun 2018 07:39:18
Message: <5b2cdfe6$1@news.povray.org>
I was wondering if there might be a rough, pie in the sky, timeframe for
releasing 3.8.
There are currently 3 debian packages [1]:
povray_3.7.0.0
povray-includes_3.7.0.0
povray-examples_3.7.0.0
I will add 2 more:
qtpovray_0.1
qtpovray-extras_0.1
Should I call it 0.1?  3.8?  3.8.0.1?
qtpovray contains the executable and desktop
qtpovray-extras contains the glorious insert menu
Maybe I should call qtpovray-extras just povray-extras?
I want to leverage the existing povray-includes
which requires a release of package povray-includes_3.8.0.0
to pick up /usr/share/povray-3.8/includes .
Also, to get the .ini files especially /etc/povray/3.8/povray.conf
I need package povray_3.8.0.0 and we're not ready for that.
I could release a qmake built package povray_3.8.0.0 with the unix shell
version (and the /etc/povray/3.8 files I need). But that's not my call
(or true focus).  One bleh thing about that is the executable is
/usr/bin/povray , so one can't have 3.7 and 3.8 executables installed at
the same time, even though the data is already separated by version.
dik
Rendered 328976 of 330000 (99%)
[1] Ubuntu 18 has povray_3.7.0.4 , but I'm mostly working on Ubuntu 16
which is povray_3.7.0.0
Subject: Re: qtpovray and debian
Date: 22 Jun 2018 08:48:12
Message: <5b2cf00c$1@news.povray.org>
Am 22.06.2018 um 13:39 schrieb dick balaska:
> qtpovray_0.1
> qtpovray-extras_0.1
I'd make sure that it is clear which version of POV-Ray it is based on.
For UberPOV, I'm using the scheme `vX.YZ.N` to denote versions based on
POV-Ray vX.Y.Z.
No, you should definitely not. If it's not official POV-Ray, don't make
it look like it is.
In my naive understanding of Unix package management, I would suggest
for now to release qtpovray as a collection of stand-alone packages, and
later - once an official POV-Ray package is available - update it to
make use of the official POV-Ray packages, modifying part of the
qtpovray packages to do nothing more than pull in the official packages.
I'd say that's a thing to be addressed by whoever is the maintainer of
the debian POV-Ray package. We're not doing any Unix package
maintenance, we're just providing the source code, Unix build tools, and
a bit of support. If I'm not mistaken, the configure script allows to
specify a different binary name.
If they're smart, the package also has a `/usr/bin/povray-3.7`
hard-linked to the same file (or `/usr/bin/povray` soft-linked to
`/usr/bin/povray-3.7`), so that installing another version "on top" of
it leaves an instance of the old binary available.
There's little difference there; POV-Ray v3.7.0.4 is just v3.7.0 updated
to work with the compiler and 3rd party libraries that ship with Ubuntu 18.
Date: 22 Jun 2018 11:15:01
Message: <web.5b2d11a41b94875a635cc5ad0@news.povray.org>
hi,
dick balaska <dic### [at] buckosoftcom> wrote:
> I will add 2 more [Debian pkgs]:
> qtpovray_0.1
> qtpovray-extras_0.1
fwiw, following the instructions in
http://news.povray.org/5b01fa12%241%40news.povray.org
fails to build on Slackware 14.1, a first. ;-)
jr@crow:1:povray$ make
cd qt/libpovray/ && /usr/bin/qmake /tmp/QP/povray/qt/libpovray/libpovray.pro -o
Makefile
cd qt/libpovray/ && make -f Makefile
make[1]: Entering directory `/tmp/QP/povray/qt/libpovray'
g++ -c -pipe -O2 -w -fPIC -D_REENTRANT -DQT_DEPRECATED_WARNINGS
-DOPENEXR_MISSING -DBUILD_ARCH="x86_64" -DTRY_OPTIMIZED_NOISE -DBUILD_X86
-DQT_NO_DEBUG -DQT_CORE_LIB -DQT_SHARED -I/usr/lib64/qt/mkspecs/linux-g++ -I.
-I/usr/lib64/qt/include/QtCore -I/usr/lib64/qt/include -I../../source
-I../../platform/unix -I../../platform/x86 -I../../unix/povconfig -I../../vfe
-I. -o tmp/QP/povray/source/backend/bounding/boundingtask.o
..../../source/backend/bounding/boundingtask.cpp
In file included from ../../source/backend/frame.h:57:0,
                 from ../../source/backend/bounding/boundingtask.cpp:42:
..../../source/base/configbase.h:1048:6: error: #error "This version of POV-Ray
requires C++11, which your compiler does not seem to support."
     #error "This version of POV-Ray requires C++11, which your compiler does
I know you're only concerned with Ubuntu, but thought you'd like to know.
regards, jr.
Date: 22 Jun 2018 11:20:00
Message: <web.5b2d12961b94875a635cc5ad0@news.povray.org>
hi,
> We're not doing any Unix package maintenance, we're just providing
> the source code,
maybe a wiki page where package scripts and/or links, and "tips + tricks", for
various platforms can be found?
regards, jr.
Date: 22 Jun 2018 11:20:41
Message: <5b2d13c9$1@news.povray.org>
I have a fix for that.  debuild (debian package maker) gave the same
error.  Apparently, I have some personalized qt config somewhere (?)
that throws the C++11 in there.
dik
Date: 22 Jun 2018 11:47:46
Message: <5b2d1a22$1@news.povray.org>
>> qtpovray_0.1
>> qtpovray-extras_0.1
> POV-Ray vX.Y.Z.
I can do that.  So my first would be qtpovray-3.80.1
ja?
> it look like it is.
Well, that was my first thought. But, OTOH, there is no "official"
povray, so screw all y'all. ;)
All praise to Andreas Beckmann <anb### [at] debianorg> (who I never heard of)
as the debian maintainer.
I have read so much debian foo lately. It's too much. Then I unpacked
the debian povray port, and it's all right there, with all the right
magic words to make 3 packages from one set of source.  The only hard
part was was bootstrapping qmake, for which the only documentation is a
comment in a tutorial. "How do I use qmake instead of configure?" "Since
version blah, it just magically works".
jr whined that I didn't rename my dir root from povray to qtpovray. The
fact that I didn't bit me in the butt here. Package qtpovray must be
built from dir root qtpovray. Then it sees qtpovray.pro first and
ignores any ./configure that lives there.  I'm going to have to rename
my repo.
I will do that.
Although I would prefer if the data was in /usr/share/povray/3.[78]
I will be consistent and go with /usr/share/qtpovray-3.81 to match the
existing style of /usr/share/povray-3.7
(Actually my personal preference is to keep it *all* together, i.e.
/opt/povray/bin
/opt/povray/etc
/opt/povray/var/include
I'm not a real fan of the debian model of sowing povray dust throughout
the file system.  But it works for a couple hundred million (a billion?)
installations, so it's good enough for me.
> specify a different binary name >
99% of packages don't do symlinks.  But the big boys do; gcc, python,
wish.  I will suggest this to the debian maintainer.
dik
Date: 22 Jun 2018 12:15:01
Message: <web.5b2d1fdc1b94875a635cc5ad0@news.povray.org>
hi,
> I have a fix for that.  ... some personalized qt config somewhere (?)
I'll be happy (and a little curious :-)) to try.
btw, replying to clipka you wrote: "99% of packages don't do symlinks."
the Slackware 'makepkg' does, just like .. "the big boys".  :-)
regards, jr.
Date: 22 Jun 2018 13:52:18
Message: <5b2d3752$1@news.povray.org>
Am 22.06.2018 um 17:15 schrieb jr:
> hi,
>> the source code,
If you know someone knowledgeable enough and willing to write up such a
wiki page - sure.
Date: 22 Jun 2018 13:58:35
Message: <5b2d38cb@news.povray.org>
Am 22.06.2018 um 17:47 schrieb dick balaska:
>> POV-Ray vX.Y.Z.
> ja?
I'd go for 3.80.0, but the choice is up to you.
> my repo.
There's no rule that says your local Git repo has to have the same name
as the remote.
Date: 22 Jun 2018 14:45:06
Message: <web.5b2d432d1b94875a635cc5ad0@news.povray.org>
hi,
> wiki page - sure.
I'd be happy to read up sufficient on the wiki language to add the entry for
Slackware; since all packages are built from unmodified sources, it's
essentially a link to http://www.slackbuilds.org/ where one can find the package
"ingredients" for any given os release.  the scripts are maintained and use the
3.7.0.0 source.
regards, jr.
