POV-Ray : Newsgroups : povray.programming : [RFC] Increasing Rendering Speed: Idea and Implementation Server Time
16 Dec 2025 13:03:38 EST (-0500)
  [RFC] Increasing Rendering Speed: Idea and Implementation (Message 1 to 10 of 29)
Subject: [RFC] Increasing Rendering Speed: Idea and Implementation
Date: 1 Feb 2003 17:52:28
Message: <3e3c4faa@news.povray.org>
[POVRay developers, please make sure to read part 2.3.]
Okay, let's come straightly to the point:
Rendering complicated scenes can take ages, especially if you render
animations. While this is often acceptable for the final rendering, it
really has potential for improvement if you're just interested in
a preview during modelling.
Often, degrading quality (+Q0) is not an option because e.g. you need
the shadow to better view the object orientation in space, etc.
So, let's discuss a different idea (which I do not claim credit
for [1]):
The principle is to only render some pixels and calculate the color of
other pixels using interpolation.
I read some papers which indicate that (if done properly) speed can be
increased by an order of magnitude while nearly not affecting quality
(depending on the scene, of course). The stuff in question is called
Directional Coherence Map.   [ Wow. Sounds cool, right? ;) ]
My first question is: Is somebody working on that for POVRay?
Are there patches addressing this issue?
Being a passionate C/C++ programmer I thought that it is probably no
good idea to wait until the POV Ray team implements something like that.
So, I had a look at the source code myself two days ago.
Let's come to the points which have to be discussed:
1. (Mosaic) Preview:
The current mosaic preview adds rendering time because the pixels
rendered in the preview are not used in the final rendering.
So, I think, one could use a fixed-grid (e.g. 8x8) bilinearly
interpolated preview instead. This should be sufficient for a quick
view of the image before actually rendering it and would produce
nicer images than an 8x8 mosaic preview.
I implemented that and it works fine.
2. Actual image rendering:
The more interesting part.
The easiest approch is to render every 8th pixel in X and Y direction.
4 pixels ( (x,y), (x+8,y), (x,y+8), (x+8,y+8) ) build a block. If
these four pixel differ less (in color) than a specified threshold,
the whole 8x8 block is evaluated using bilinear interpolation.
Else, the block is divided into 4 blocks of size 4x4 requiring that
5 more pixels are rendered. Then, you subdivide into 2x2 and finally
you render all the left pixels.
This is what I implemented yesterday. To keep mem usage low, I am
using a buffer of 9 image lines. The pixels rendered during the
preview are stored in a separate width/8 x height/8 buffer and
being re-used. [Dumb algo? - Read 2.3.]
However, there are several issues:
2.1. First, the povray code structure:
Some easy modifications would have to made (better control when
plot_pixel() actually calls XPutImage() by adding a plot_flush(x,y,w,h)
function, etc).
More seriuos are:
Prune_Vista_Tree()
  I don't know if it is speed critical but it has to be called much
  more often, because 8x8 blocks are rendered sequentially which means
  that the Y coordinate changes freqently.
Do_Cooperate().
  Don't know when it should be called or if it can cope with the
  situation. Could someone enlighten me on POVMS? It seems to deal
  with "messages", "queues" and "objects" but I have no clue.
Current_Line_Number and Current_Line.
  These are global vars and the latter is hard to grep because of
  the similarity with the first one. I don't use them as I use my
  own line buffer (9 lines).
Field_Render_Flag:
  Seems to be some strange thing skipping odd or even lines.
  Probably not 100% incompatible but I currently see no reason for
  supporting it. Maybe anyone has arguments [explain why useful].
Antialiasing:
  Not supported but there is currently not much point in it as we
  are talking about rendering more quickly.
2.2. Evaluation order:
I am currently rendering a rough preview and then rendering the image
top to bottom, 8 lines at a time. This requires "only"
9*width*sizeof(COLOUR) bytes of buffer memory. 8x8 blocks are computed
sequentially.
The other idea would be to keep the whole image im memory and execute
the stages of the algorithm sequentially on the complete image. Nicer
to look at but requires much more RAM (6 Mb for 640x480). No
possibility to resume a half-done image.
2.3. The algorithm itself:
As you probably guessed, I only explained the first step of the
algorithm. After evaluating the 4 corer pixels one could render a
complete rectangle border (32 pixels). Then apply the directional
coherence map.
However, after having rendered the 4 corner pixels, the main problem
is to decide on how to go on. Using a checker plane, I currently get
ugly 8x8 alias effects; objects like thin cones can be skipped
completely (which is extremely annoing in animations).
One idea would be to save which object had most influence on the
color of the ray. If the 4 corner pixels come from different objects,
do not interpolate immediately.
Obviously, textures don't work well with the algorithm because they
behave like fine detail. [2] suggests applying them afterwards but
I doubt that this is feasible for povray. OTOH, you normally don't
use lots of textures if you render a preview.
MOST CRITICAL is the detection if there is more than one object
inside the 8x8 block. A routine doing a quick test on that would
come quite handy. Problems may occur with partial reflection or
interior (ior) etc. but returning (false) positives for some parts
of the scene is acceptable. Unfortunately, I am not familiar with
the innermost workings of the POVRay "engine" so help is appreciated.
[Hope someone is still reading this.]
Wolfgang
References:
[1] Baining Guo, Progressive Radiance Evaluation Using Directional
      Coherence Maps, SIGGRAPH '98 Proceedings
Source code of my patch is delivered on request and may be used
under the POV license as well as under the GNU GPL.
It is not limited to 8x8 blocks but I used that here for
simplicity. It is work in progress and far from complete but if
anyone wants to comment on it i'll be happy.
Subject: Re: [RFC] Increasing Rendering Speed: Idea and Implementation
Date: 1 Feb 2003 18:34:21
Message: <3e3c597c@news.povray.org>
  You should be really careful here. Read povlegal.doc carefully to see
if you can do this.
Date: 1 Feb 2003 18:46:27
Message: <3e3c5c53$1@news.povray.org>
In article <3e3c4faa@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
In simpler terms: It is a kind of adaptive antialiasing on pixel blocks.
None that I know about.
Yes.  I know it is intentional, but I do not know why.
> function, etc).
I assume XPutImage is some platform specific function.  I am not sure where
you are going here or what exactly you are talking about.  Please clarify.
> Do_Cooperate().
POVMS is a way to abstract the different output streams and render control
in a way more suitable for GUI platforms.  It has nothing to do with the
actual ray-tracing core.  In future releases of the POV-Ray 3.5.x the other
means of handling output will be gradually removed and replaced by a
POVMS-only system with default code for command-line versions.
Some code depends on them.  So be careful, things may fail in unexpected
ways.
> Field_Render_Flag:
It is an easy way to create animations for interlaced display devices (aka
televisions).
The object found is always on the intersection stack, so you can use that.
    Thorsten
Date: 2 Feb 2003 06:54:35
Message: <3e3d06fb@news.povray.org>
> if you can do this.
Please explain the problem.
I remember the paragraph
"WHY ISN'T POV-RAY OPEN SOURCE ?"
in povlega.doc,
What I stated in these 2 lines just wants to express that my patch
is covered by povegal.doc but there is no problem with my code if
POVRay goes GPL.
Date: 2 Feb 2003 06:56:23
Message: <3e3d0765@news.povray.org>
Kind of, yes.
But the algorithm doing the adaption should be more clever than the
current one and it is not about averaging supersample colors but
guessing colors from fewer samples.
One doesn't need a mosaic preview for the final rendering so there is no
problem with additional time, I think. However, for a quick preview
it would be nice to re-use the pixels like I do.
>> function, etc).
> where
Okay the problem is simple:
Calling plot_pixel() should display the pixel on the screen (SVGAlib, X11
or whatever). However, e.g. for X11, plot_pixel() just puts the pixel in
offscreen storage and actually flushes the buffer once a complete image
line was plotted (x coord == width-1) or some time elapses.
Now, the problem is that I do not render lines from left to right, one
at a time which breaks the simple update logic.
So, I would introduce a flush function which explicitly tells
the underlaying display routine to put some part on screen. For SVGAlib
this would be a no-op. This would require a trivial one-line patch
at two or three other positions where plot_pixel is used.
Nothing really complicated.
>> Do_Cooperate().
> other means of handling output will be gradually removed and replaced by a
Okay, but when should I call Do_Cooperate()? And what does the param
(int level) mean?
I always read something about "well documented" and "cleanly coded"
patches to POVRay, so please look at povray.cpp (!)
* FUNCTION
*   Do_Cooperate
* INPUT
* OUTPUT
* RETURNS
* AUTHOR
*   POV-Ray Team
* DESCRIPTION
* CHANGES
Sorry, but that's just [wasted] 312 bytes of source code telling
essentially nothing just make it harder to keep an overview.
[Don't want to start flame war and don't take that personally.]
> ways.
I'll check that.
>> Field_Render_Flag:
> televisions).
...and seems to do some sort of antialiasing?
I doubt it's worth the increased complexity for my patch, especially
as most people probably watch previews on their computer screen.
Maybe it can be added in the end.
...found in frame.h, struct istk_entry, struct istack_struct.
So, if I understand you correctly, then the object hit by the ray
is found on top of intersection stack (istk_entry.Object)
once the ray is completely traced?
- How can I get access to the stack head.
- What happens when the ray hits an object with 50% reflection?
  (Thus the color of the pixel is determined by 2 objects.)
  How can I tell looking at the stack?
The other point is that the algorithm would take most advantage if we
can determine (quickly) if all the rays in the complete 8x8 _BOX_ hit
the same object (without tracing the complete box). It's like shooting
a ray with a diameter > 0.
This way one can't leave out a horizontal 7 pixel thick cylinder which
could currently be completely missed.
How could one achieve that? It does not have to be 100% accurate,
meaning that false positives are allowed (i.e. if we traverse an object
with ior!=1).
Wolfgang
Date: 2 Feb 2003 07:25:33
Message: <3E3D0E3D.FFD75638@gmx.de>
> > if you can do this.
> in povlega.doc,
> POVRay goes GPL.
The thing Warp probably was trying to point out that there is no use in a
POV patch outside POV-Ray so the 'double licencing' is either not of any
use or tries to imply that POV-Ray with this patch can be distributed
under GPL which is not true.  It is very unlikely that POV-Ray will be
licenced under GPL anytime.
Another thing is that it would be more in the spirit of POV-Ray to make
the patch available without the necessity for a request.  Of course no one
forces you to publish your modifications at all but if you do they should
be freely available.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 2 Feb 2003 07:56:20
Message: <3e3d1574@news.povray.org>
In article <3E3D0E3D.FFD75638@gmx.de> , Christoph Hormann
<offtopic>
In fact it will never be released under the GPL.  The GPL comes with a
political message that is not acceptable to all team members.  It certainly
isn't acceptable to me.
</offtopic>
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 2 Feb 2003 07:58:51
Message: <3e3d160a@news.povray.org>
No problem, I'm developing GPL software which can be downloaded by
anyone, so it is also "in my spirit" to make it available.
Just that it is highly experimental stuff...
So, I cleaned it up a bit.
The patch is available at
http://www.cip.physik.uni-muenchen.de/~wwieser/povray/
[Don't take the content of this "home page" seriously. Basically
SOMETHING had to be put there...]
Please note that it patches povray in a way that it will always
use my interpolated tracing -- no non-adaptive or adaptive tracing
unless you change the lines in povray.cpp.
Wolfgang
Date: 2 Feb 2003 08:10:26
Message: <3e3d18c2@news.povray.org>
In article <3e3d0765@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
Ah, but that is a platform specific problem.  So you should deal with
something like this in platform specific code and not add functions to
POV-Ray.  Just flush in plot_pixel or buffer calls to plot_pixel to flush
multiple pixels at once (in case you are concerned about performance).
> (int level) mean?
Look what the function does (it is really trivial) and then find out what
the macros inside do.  They are documented.
Well, guess how the code ended up in its current state ... you should really
think more about your argument before complaining.
It is there so it can be added when somebody finds the time.  You are free
to go through the whole source code and document everything if you want ;-)
No, it just "skips lines".  Read the documentation about this feature to
find out more.
Basically yes, check function Trace, variable Best_Intersection.
Beam tracing is not available in POV-Ray.
> with ior!=1).
Not at all in a ray-tracer.
    Thorsten
Date: 2 Feb 2003 10:20:10
Message: <3e3d372a@news.povray.org>
>> if you can do this.
  Your words seem to imply that your patched version of POV-Ray could be
published under the GNU GPL. As far as I know, that would be an outrageous
violation of the POV-Ray distribution license.
  If you didn't mean that, you should express yourself more clearly and
unambiguously.
