POV-Ray : Newsgroups : povray.programming : Re: Infinate cylinders Server Time
3 Apr 2026 07:30:42 EDT (-0400)
  Re: Infinate cylinders (Message 1 to 3 of 3)
Subject: Re: Infinate cylinders
Date: 20 Jul 1999 03:41:09
Message: <37942815@news.povray.org>
In article <3793B451.295DB2FE@hotmail.com> , our### [at] hotmailcom  wrote:
> "shapes.inc" defines a cylinder of infinite length that runs along the
> X axis as:
> #declare Cylinder_X =
>  quadric
>   {<0, 1, 1>,
>    <0, 0, 0>,
>    <0, 0, 0>, -1
> Is there some similar way to generate an infinite 2D array of these
> cylinders along with some way to either control their spacing or
> diameter?
Yes, using the #while...#end Directive:
#declare CountZ=0;
#while (CountZ < 5)
  #declare CountY=0;
  #while (CountY < 5)
    object{Cylinder_X translate <0, CountY*3, CountZ*3>}
    #declare CountY=CountY+1;
  #declare CountZ=CountZ+1;
    Thorsten
PS: The group povray.programming is for discussing the POV-Ray source code,
not scene creation problems. I have cross-posted this to povray.newusers.
Date: 20 Jul 1999 05:28:31
Message: <3794413f@news.povray.org>
In povray.newusers Thorsten Froehlich <tho### [at] trfde> wrote:
:> Is there some similar way to generate an infinite 2D array of these
:> cylinders
: Yes, using the #while...#end Directive:
  Nope. You can't make an infinite array with a #while-loop. It would take
forever.
Date: 20 Jul 1999 09:25:56
Message: <37947901.6CEE3AE3@peak.edu.ee>
Well, you can make it infinite for almost all practical purposes. But the object
count, coupled with the slow quadric, would take their toll on render/parse
time.
Margus
> forever.
Date: 20 Jul 1999 12:18:08
Message: <3794a140@news.povray.org>
In article <3794413f@news.povray.org> , Nieminen Mika <war### [at] cctutfi>
> forever.
You can...as you know the POV-Ray coordinate system is finite (yes, I know
that this is a trick, but it does its job). It will just take up a lot of
memory (the 5*5 cylinders where just an example).
     Thorsten
e-mail: tho### [at] trfde
Date: 20 Jul 1999 12:21:11
Message: <3794A17C.A9E0353F@pacbell.net>
> > forever.
>      Thorsten
Thorsten slides through with a techinical loophole... <Grin>
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 20 Jul 1999 14:03:25
Message: <3794B9EF.2F51FE64@compuserve.com>
[canceled and moved here to povray.newusers]
You can't make an infinite array of cylinders, the isosurface requires
bounds and there has to be a limit to the number of intersections
anyway. However, using either the isosurface or  the #while directive
you could make one big enough to appear infinite, or make a small array
of cylinders and put it in a mirrored box along with the camera. With
the mirrored box, the distance would be limited only by max_trace_level,
but anything else in the scene would also be replicated.
Date: 20 Jul 1999 15:53:44
Message: <3794d3c8@news.povray.org>
In article <3794A17C.A9E0353F@pacbell.net> , Ken <tyl### [at] pacbellnet>
>>      Thorsten
True ;-)
 I have to admit that I didn't read the original post correctly: I
(miss)read (or assumed) that he asked how to create a finite number of
elements...
    Thorsten
Date: 21 Jul 1999 13:12:44
Message: <37960002.6EB1A57D@ma.usb.ve>
>      Thorsten
I didn't know that. Could you tell me (us) the size of the coordinate system?
Alberto.
Date: 21 Jul 1999 14:42:52
Message: <379614ac@news.povray.org>
In article <37960002.6EB1A57D@ma.usb.ve> , Alberto <ame### [at] mausbve>
>>      Thorsten
Well, for example the ray/object intersection test will not work as expected
for objects more than 1.0e17 away. But the default maximum distance is only
1.0e7 (10.000.000) by anyway.  NOTE: These are default values, on some
platforms these values may be smaller (or larger).
So if you have enough memory (and a modified compile of POV-Ray for a 64 bit
processor (so that 'int' is 64 bit) with some adjustments) you can place
1e12 (1.000.000.000.000) cylinders in a 10*10 grid...I wounder if POV-Ray
could deal with that many objects.  I would estimate the memory need around
200 TB (tera byte).
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
