POV-Ray : Newsgroups : povray.pov4.discussion.general : Scale Postfixes Server Time
1 Jun 2024 11:37:02 EDT (-0400)
  Scale Postfixes (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Scale Postfixes
Date: 4 Aug 2009 21:58:03
Message: <4a78e72b$1@news.povray.org>
David H. Burns wrote:
> "Rad" and "deg" for angles and rotation
> *would* be useful.
They're already implemented.
// Declares the variable rad to be 45 degrees converted into radians.
#declare rad = radians(45);
// Declares the variable deg to be 0.3 radians converted into degrees.
#declare deg = degrees(0.3);
Chambers
Date: 4 Aug 2009 22:00:05
Message: <4a78e7a5$1@news.povray.org>
This has come up before, and I've even seen a few include files written
to standardize it.
The problem with standards, of course, is that they must be adhered to.
  Unfortunately, none of the aforesaid include files really became popular.
Perhaps adding a "metrics.inc" to the standard include files, and
requiring its use as part of the standards for the object library, would
be a good idea.
Chambers
Date: 4 Aug 2009 23:10:43
Message: <4a78f833$1@news.povray.org>
>> "Rad" and "deg" for angles and rotation *would* be useful.
They're perfectly counter-intuitive for use in "rotate" though:
    // trying to express that I intend to rotate by 45 degrees,
    // with the effect of rotating by 45 radians instead
    rotate x * degrees(45)
    // trying to express that I intend to rotate by 0.3 radians,
    // with the effect of rotating by something particularly useless
    rotate y * radians(0.3)
Date: 5 Aug 2009 03:19:55
Message: <4a79329b@news.povray.org>
> It would be neat to have an "official" set of units, but I still favor
> them as
> regular variables that are defined in terms of each other.  It could
> simplify
> the use of other people's objects, which will become more of an issue as
> the
> object collection grows.  A standard include for SI and commonly used
> non-SI
> units?
It's not going to work...
Try and render this: (with some pigments and lights...)
#declare mm = 1;
#declare  m = 1000 * mm;
#declare km = 1000 * m;
sphere{ 0 , 6400*km }
camera{ location <3000,1000,25000>*km }
Even if you define m as 1 (which would seem the most logical choice to me)
it still doesn't work.
For some reason POV doesn't like (not very) big numbers, and if you define a
certain distance as "1", some scenes are bound to break.
Date: 5 Aug 2009 03:38:19
Message: <4a7936eb$1@news.povray.org>
True, they're meant for conversion rather than designation.
Chambers
Date: 5 Aug 2009 10:15:01
Message: <4a7993e5@news.povray.org>
... which makes my point, because I'd love to have some means of
designation ;-)
Date: 5 Aug 2009 10:27:22
Message: <4a7996ca$1@news.povray.org>
I had forgotten that.
Date: 5 Aug 2009 10:30:36
Message: <4a79978c$1@news.povray.org>
True too. "Built in" unit definitions would be useful, maybe with a
default that could
be set as in calculators?
Date: 6 Aug 2009 12:49:11
Message: <4a7b0986@news.povray.org>
#declare deg = 1;
#declare rad = radians(1);
rotate x * 45*deg
rotate y * 0.3*rad
Date: 6 Aug 2009 13:14:15
Message: <4a7b0f67$1@news.povray.org>
> #declare deg = 1;
> rotate x * 45*deg
> rotate y * 0.3*rad
#declare Foo = sin(45*deg);
#declare Bar = cos(0.3*rad);
FAIL.
Which is to say: POV-Ray's current system for representing angles is
inconsistent, and a genuine built-in mechanism for specifying values as
either degree or radians would be helpful to mend this.
Note that this isn't about "how powerful is the language", but "how easy
is it to learn and use". Otherwise, we could simply refer to the
Turing-completeness of the language and be done with it.
