POV-Ray : Newsgroups : povray.pov4.discussion.general : POV-Ray 4 SDL: Some concrete proposal Server Time
16 May 2024 23:18:42 EDT (-0400)
  POV-Ray 4 SDL: Some concrete proposal (Message 18 to 27 of 27)
Subject: Re: POV-Ray 4 SDL: Some concrete proposal
Date: 18 Apr 2009 13:15:01
Message: <web.49ea09ed3a7e550eaddfbead0@news.povray.org>
"MessyBlob" <nomail@nomail> wrote:
.... my point being that (with appropriate assignments) you can already know the
existing size of the sphere, given that the whole scene was constructued using
declarative statements.
Date: 24 Apr 2009 15:08:15
Message: <Xns9BF7D700B958Eseed7@news.povray.org>
in news:web.49e39942d93ad1dd2dae03a10@news.povray.org clipka wrote:
> I'll try to describe what I have currently in mind. But first let me
> present to you a kind of "hello world" scene written in that
> language:
> include "colors.inc";
include colors
> SphereCenter = <0,1,0>;
Spherecenter = <0,1,0>
Sphereradius = 1
> sphere {
>   center: SphereCenter;
>   radius: 1 as SphereRadius;
>   texture {
>     pigment { color: #<1,0,0> }
> } as MainSphere;
MainSphere = sphere {
  center = SphereCentre,
  radius = SphereRadius,
    color = <1,0,0>
    //(if we need more than a 3-vector define the kind rgbf<1,0,0,1>)
... the as SphereRadius is confusing and obfusicating.
read http://docs.python.org/tutorial/controlflow.html#defining-
functions and espacialy the next section.
the alternative of the above Mainsphere thus should be:
  SphereCentre,
  SphereRadius,
    color = <1,0,0>
... kind of exactly the same as we have now :)
taking it a bit further, the way to declare macros should be exactly as
done in Python, but then in SDL:
macro Sphere(spherecentre=<0,0,0>,sphereradius=1, ...etc)
so using the Sphere macro in the scene looks exactly like using the
built in sphere.
Now Warp will of course argue that this new Sphere thing should not be
a macro but a class that inherits from the "objects" class so all the
texture etc. stuff is readily available and he's right.
class Sphere(object){
  sphereradius=1
  and all kinds of clever code to generate the object
> modify MainSphere {
>   radius: 0.9;
MainSphere.radius=0.9
MainSphere{radius=0.9} could be mistaken for the declaration of a new
sphere with radius, using the default centre and texture.
I realy like Python, but don't use it as an SDL but steal as much
possible from it and use it in a sytax as close as possible tot the
current SDL as possible and read:
The Zen of Python
    Beautiful is better than ugly.
    Explicit is better than implicit.
    Simple is better than complex.
    Complex is better than complicated.
    Flat is better than nested.
    Sparse is better than dense.
    Readability counts.
    Special cases aren't special enough to break the rules.
    Although practicality beats purity.
    Errors should never pass silently.
    Unless explicitly silenced.
    In the face of ambiguity, refuse the temptation to guess.
    There should be one-- and preferably only one --obvious way to do
it.
    Although that way may not be obvious at first unless you're Dutch.
    Now is better than never.
    Although never is often better than *right* now.
    If the implementation is hard to explain, it's a bad idea.
    If the implementation is easy to explain, it may be a good idea.
    Namespaces are one honking great idea -- let's do more of those!
Ingo
Date: 13 May 2009 13:00:19
Message: <4a0afca3@news.povray.org>
> current SDL as possible and read.
This may seem a little odd, but why not use Python as an SDL?  I've used the
C/C++ API before, and it would give us a mature, byte-compilable language
that could easily link to a render module.  I think the license is
acceptable, and it's certainly more optimized than anything we could easily
come up with.
We basically would end up using the C API to compile the actual ray-
intersection code, the actual 'raytracer'.  Callbacks can give Python the
ability to shoot extra rays, and would potentially even allow the definition
of objects' ray-intersection functions from SDL.
If not Python, then perhaps some other established language should be
considered.
 - Peter Hokanson
Date: 13 May 2009 13:20:01
Message: <web.4a0b00b73a7e550e405e15c60@news.povray.org>
> considered.
This has already been discussed quite a lot and quite often.
I am by now convinced that with *all* well-established languages, such an
approach would invariably lead to an SDL that may be quite fitting for
programming complex stuff, but cumbersome for the most essential tasks the SDL
will have to be used for: Describing the actual scene elements to instantiate.
I think the right way to go is take an established free open-source language
(which should be bytecode-based, have a very simple core, and designed to be
embedded into other software; my current champion for this would be Lua) and
replace or heavily modify its parser to suit the specific needs of POV-Ray.
If there's one thing a new SDL *must not* do, then it's making plain-vanilla
scene description significantly more cumbersome than with the current SDL.
Date: 13 May 2009 14:07:19
Message: <4a0b0c57$1@news.povray.org>
> language (which should be bytecode-based, have a very simple core, and
> designed to be embedded into other software; my current champion for this
> would be Lua) and replace or heavily modify its parser to suit the
While I do see your point, I think that Python has some features that might
make this manageable.  For example:
from povray import *
MyTex = texture(pigment=(1,1,1))
sphere((0,0,0),5,texture=MyTex)
Even if this isn't the default interface, it would be nice to have the
programming capabilities of Python to use in a POV-Ray scene.  I've thought
about writing something similar myself, but it would be a lot of work.
Also, Python is pretty fast, and could implement custom features/shaders
without recompiling POV:
class MyCam(camera):
	def makeRay(x,y):
		"""Define a ray from the camera from x,y pixels"""
		return ray(...)
def myfunc(x,y,z):
	"""We could use traditional Python functions for isosurfaces and similar"""
	return x+y+z
One of the things that has annoyed me about the existing SDL as of late is
that not all blocks can be declared (patterns and others cannot be).
Date: 13 May 2009 14:30:00
Message: <web.4a0b10f43a7e550e405e15c60@news.povray.org>
Fine. Can we also write this as
  sphere((0,0,0),5,texture(pigment=(1,1,1)))
How about more complex scenarios, like multi-layered textures for instance?
>  def makeRay(x,y):
>   return ray(...)
See MegaPOV for how such a thing can be done even with the POV 3.6 framework.
> def myfunc(x,y,z):
>  return x+y+z
I see no valid point of using "traditional Python functions" in favor over any
other "traditional <YourFavoriteLanguage> functions" (including traditional POV
3.x SDL functions, the only ones to which I would attribute some inherent
favorability in this context).
That's a totally different story. I guess *any* new SDL should address that -
and I guess any new SDL *will* address that, provided it is designed with a
sufficient degree of inherent formalism.
At its core, a next generation SDL should not know about spheres, textures,
patterns etc - all these should be just specific objects to the SDL, and
therefore all handled basically the same: They should use the same basic syntax
to create them, be all storable in variables, use the same syntax to evaluate
such a variable, etc.
The only things that might be worth treating specially are vectors and colors I
guess, as these are about as essential to POV as numbers and strings.
Date: 15 May 2009 04:50:01
Message: <web.4a0d2b9c3a7e550e44daeae0@news.povray.org>
I think this can be done with positional arguments. The constructor for a type
would have to accept variable arguments  and then determine if there is more
than one texture by if more than one argument is a texture object:
class baseobject:
  def __init__(self, *args):
    for i in *args:
      if isinstance(i, texture):
        self.textures.append(i)
        self.texture_transforms.append(transform())
      if isinstance(i, (transform, rotate, scale, translate)):
        self.transform_matrix.update(i)
        for j in self.texture_transforms:
          j.update(i)
class sphere(baseobject):
    # Extract sphere-specific arguments first and pass the rest to the base
    baseobject.__init__(self, ...)
mysphere = sphere(
  (0, 0, 0), 5,
  scale(4), # Doesn't affect any texture
  texture(
    pigment(
      checker(0.5, color(0.0, 0.0, 0.0, 0.5), color(0.5, 0.5, 0.5, 0.5))
    finish(...),
  scale(x=4, y=1), # Affects the first texture only
  texture(...),
My question would be, how to differentiate between creating an object or just
declaring it.  Maybe a special function to add the object to the scene:
add(sphere(
or perhaps a special global object that if in the attributes would cause it not
to be added to the scene list
class Dummy:
  pass
nocreate = Dummy()
class baseobject:
    create = True
    for i in args:
      if i is nocreate:
        create = False
    if create:
      scene_objects.append(self)
mysphere = sphere(..., nocreate)
Date: 15 May 2009 11:55:00
Message: <web.4a0d90493a7e550ef708085d0@news.povray.org>
> add(sphere(
This seems unnecessarily cumbersome to me (like a few other details of your
suggestion)...
.... while this seems to me like a conceptual kludge. I don't think it would be
wise starting a new SDL with kludges already. They tend to accumulate anyway
over time.
I also note that your variable-parameters approach relies heavily on individual
object classes doing parsing-related work. We would end up with much of the
parser de facto implemented in individual object classes, which would be prone
to making the language inhomogenous.
I think that instead, objects should just expose certain properties and
"actions" in a standardized manner, which the parser/runtime module should
"drive", with the objects being completely oblivious of the language's details.
Note that this idea includes a separation between the basic language syntax, and
the actual obejcts, properties and actions available.
Date: 14 Aug 2019 11:00:10
Message: <XnsAAABACF7A68A3seed7@news.povray.org>
>> be considered.
> such an approach would invariably lead to an SDL that may be quite
> fitting for programming complex stuff, but cumbersome for the most
> essential tasks the SDL will have to be used for: Describing the
> and designed to be embedded into other software; my current champion
> for this would be Lua) and replace or heavily modify its parser to
> plain-vanilla scene description significantly more cumbersome than
10 years ago this was written.
Sorry for diggin up a thread this old, but, how a bout a concept like in
the Seed7 extensible programming language
http://seed7.sourceforge.net/faq.htm#extensible_programming . That would
make it possible to write and render include files and when all is fine
(trans)compile them so they become 'part' of the SDL. (This without regard
of the choise for actual syntax.)
Ingo
Date: 16 Aug 2019 14:00:01
Message: <web.5d56eec43a7e550e884ec9560@news.povray.org>
> >> be considered.
> Ingo
Hi, you probably missed it, otherwise your post could have been an answer to
this one posted in the last few weeks which received no answer:
http://news.povray.org/povray.pov4.discussion.general/thread/%3Cweb.5d421a0f46a21447884ec9560%40news.povray.org%3E/
