POV-Ray : Newsgroups : povray.pov4.discussion.general : Request for *.df4 format (ASCII text based) Server Time
15 Apr 2026 23:08:30 EDT (-0400)
  Request for *.df4 format (ASCII text based) (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Request for *.df4 format (ASCII text based)
Date: 15 Feb 2008 21:55:01
Message: <web.47b64fc7f13a83cf7ad34f770@news.povray.org>
>   Writing the current DF3 file from a program (in basically any language)
> is quite trivial. If you don't know how, just ask.
Warp,
If you every have a few moments do you think you could modify the source code
you posted at http://news.povray.org/4799ff49%40news.povray.org, so that it can
take one or more *.txt files specified in the command line (instead of the
testdata.txt) and output them into df3 format with the same name (except for
the txt extension).
If nothing is entered in the command line have it print the directions and a
"C++ Code developed by Warp". But this last part is just being needy on my part
and I can probably write that code myself.
-Jeff
Date: 15 Feb 2008 22:05:01
Message: <web.47b651dbf13a83cfae42298f0@news.povray.org>
"Woody" <nomail@nomail> wrote:
> I did check out the first website. However I found the endian preprocessor macro
> confusing. To be honest. I was never trained in plain C, only C++.
Fair enough.  It could be worse though.  I suppose I was only 'trained' (hardly)
in Visual Basic (shudder) and Fortran (marginally less shudder).  So I agree,
but maybe this would be a good start:
http://www.space.unibe.ch/comp_doc/c_manual/C/CONCEPT/bitwise.html
> I used the VC++ toolkit MS put out in 2003. Anybody know any free C compilers
> where this might work for an intel Machine?
Doesn't work in VC++?  Haven't used that compiler and for that matter I don't do
much in C++, but I would think it would be mostly compatible.
http://en.wikipedia.org/wiki/Compatibility_of_C_and_C%2B%2B
> Which Preprocessor Macro on the Paul Bourkes page should I be using?
Hmm.  One then the other?  Can never remember.  Sorry I'm just dismissing your
questions with links, but the bottom line is that C/C++ is very easy to learn
since there are so many good webpages on the matter.  Takes some time, but it's
not bad.  Good luck.
 - Ricky
Date: 15 Feb 2008 22:35:00
Message: <web.47b658cef13a83cf7ad34f770@news.povray.org>
>   Nobody would write those files by hand anyways, so what's the point in
> having them in readable ascii format?
When you say no one writes them by hand anyway, do you mean its unlikely someone
would code each individual voxel in this manner?
I just thought sinc *.pov files and *.inc files are in ascii text it would make
sense to have non standard files (standard being GIF JPEG etc) also in txt so
they would be relatively easy to edit.
But your point is taken, that you are much more likely to edit a single line of
a POV or INC file then you are to edit a single voxel in a DF3 file.
Date: 16 Feb 2008 06:10:31
Message: <47b6c4a6@news.povray.org>
> the txt extension).
  You mean with the same input file format?
  How about this:
#include <iostream>
#include <fstream>
#include <vector>
#include <string>
#include <cstdio>
int main(int argc, char* argv[])
    // Limit the size of the df3 dimensions (safeguard against invalid input).
    // Maximum df3 size will be SIZE_LIMIT*SIZE_LIMIT*SIZE_LIMIT.
    const size_t SIZE_LIMIT = 256;
    if(argc < 2)
        std::cout << "Usage: " << argv[0] << " <files>\n";
        return 0;
    for(int i = 1; i < argc; ++i) // for each input file
        std::ifstream is(argv[i]);
        if(!is.good())
            std::cerr << "Couldn't open ";
            std::perror(argv[i]);
            continue;
        size_t xSize, ySize, zSize;
        is >> xSize >> ySize >> zSize;
        if(xSize > SIZE_LIMIT || ySize > SIZE_LIMIT || zSize > SIZE_LIMIT)
            std::cout << "Skipping " << argv[i] << " (invalid input)\n";
            continue;
        std::vector<char> data(xSize*ySize*zSize + 6, 0);
        // Setup df3 header:
        data[0] = xSize/256; data[1] = xSize%256;
        data[2] = ySize/256; data[3] = ySize%256;
        data[4] = zSize/256; data[5] = zSize%256;
        // Read input data and create df3 data:
        while(true)
            size_t x, y, z, value;
            is >> x >> y >> z >> value;
            if(!is.good()) break;
            const size_t ind = x + y*xSize + z*xSize*ySize + 6;
            if(ind < data.size())
                data[ind] = char(value);
        // Write df3 file:
        std::string filename = argv[i];
        size_t ind = filename.find_last_of('.');
        if(ind != filename.npos) filename.resize(ind);
        filename += ".df3";
        std::ofstream os(filename.c_str(), std::ios::binary);
        os.write(&data[0], data.size());
        std::cout << argv[i] << " -> " << filename << std::endl;
Date: 16 Feb 2008 07:39:38
Message: <47b6d98a$1@news.povray.org>
And even if you wanted to edit a single voxel in a DF3, you could use an
hex editor :)
Date: 26 Feb 2008 17:04:58
Message: <47c48d0a$1@news.povray.org>
>> Would it be possible to include a *.df4 format where instead of dimension and
>> voxel data being in byte code, it was in some type of standard *.txt format?
>> Possibly ASCII? I realize it increase runtime (not sure how much, but I suppose
>> "Dramatically increase runtime" might be the right answer"). Even thought a
>> *.df4 option is included the *.df3 option can also be included for people where
>> runtime does matter.
But some might want to use POV-Ray SDL to write them...
Tor Olav
http://subcube.com
Date: 26 Feb 2008 18:31:05
Message: <47c4a139@news.povray.org>
  Then it would be better to enhance the SDL (or better yet, redesign it
from scratch) so that you can create DF3's with it, rather than change
the DF3 so that you can create them with the current SDL...
  The latter only helps creating DF3 files. The former helps creating
tons of other files too.
Date: 26 Feb 2008 19:36:32
Message: <47c4b090@news.povray.org>
Yes, I agree.
Tor Olav
http://subcube.com
Date: 27 Feb 2008 15:16:13
Message: <Xns9A51D85816D16seed7@news.povray.org>
> dimension and voxel data being in byte code, it was in some type of
> standard *.txt format? Possibly ASCII?
Have a look at the PGM file format
http://netpbm.sourceforge.net/doc/pgm.html it supports multiple layers. I
don't know how much of the spec is supported by POV-Ray, I doubt it deals
with multiple images.
Ingo
Date: 4 Mar 2008 11:25:00
Message: <web.47cd7729f13a83cf29aed21e0@news.povray.org>
Yes. Sometimes ago I needed to write df3 files from SDL, but that's impossible.
On the other side, Povray read only df files in binary format. I think that one
would want to create df3 files in his macros...
